mar schrammeyer
385 -
Posts posted by mar schrammeyer
File/Document settings/Units
right click in the resource browser (make sure that you are in the correct file by clicking on the little house button) and choose new image, a window will open, find your jpg ......
Are your layers to the same scale? and make sure show, snap others is set
I think it means transparency but further i am no help either
Box ticked in VW prefs?
This is a part answer relating only to orientation
To stop the end of the text bumping into the start put some spaces at the end
Ticked the right boxes?
Download MagicPrefs and see screenshot for settings
You're right did not check the Ha bit is only at the bottom of the OIP and I also get a strange extra tail to my hectare which I definitely not put in.
Extra tail only happens if one continues the property line till the end, if one let the last segment happen then this tail does not appear
Oz-Cad pointed me in the right direction, the component class render to be set in "other" tab and when overriding class in a VP use the center tab of Walls
Change your units to a custom setting
yes i know, i just wanted it confirmed it is a bug not just my machine
When I export from 2012 to 2010 I lose half the roof can anyone duplicate this?
you mean you imported a sketch as pdf or jpeg? draw a rectangle around your sketch and create a viewport on a sheet layer and scale to fit.
there is a tick box in the wall attribute palette when editing wall styles
at the bottom of the section VP oip you'll see the button attributes (sorry don't know the dutch word for it) you'l see several possibilities there
clip surface
Your user library will have to be a VW file within that folder
similar to any favourite file in VW library
If the wall is unstyled you can give it a coloured fill in the attribute palette which will show in 3D when rendered.
Alternatively you can create a colour texture right click in your resource browser see screen shots and apply the texture to selected wall side
Not clear to me why it is still available as an option when in reality it is useless. Tried in 2012 VW crashed after exporting 550mb of unfinished movie, this was openable with QT7 but not manipulatable.
Exported the file to VW2010 to find parts of the roof missing and not to be found in that file.
Reexported VW2012 to VW2011 and from there to VW2010 (roof stayed intact) exported VR 45mb
it is the best i can suggest, import the pdfs and create viewports which you are then able to annotate.
you can also ungroup your pdf back into lines
tried that already set to150, this was no problem in 2011.
OK set to 300 and I get a result. Components render by class does not work
(render does not show) and cannot be overridden in VP, when component attribute is set to choose texture,
texture will show but also cannot be overridden in VP. Does render by components work for anybody please tell me?
I also have found it impossible to get the render by components to work what is the trick?
And I am not to happy with the rendered view in a VP either
I made a slab style with concrete hatch fill for slab & edge thickening and put a 10mm floor cover with solid fill on top, mainly to hide the concrete hatch in plan but the hatch wins for some reason any ideas?
AR-works
in General Discussion
Posted
Bought the AR plug in, it is definitely a faster generator of 3D models then export VR object (which became useless) and the live section and layer/class selection gives it a nice extra.
The youtube video shows everything nicely happening on your desk, but the iMac cam is not suitable, meaning I do not get the model on the table, does anyone have success? Also I my magic mouse is useless for zooming I tried old mighty but only slightly better.
So anyone else splurged the $300?
