mar schrammeyer
387 -
Posts posted by mar schrammeyer
Thanks Islandmon found the prefs in users library/appl supp/VW/Settings trashed them and everything okay
thanks again for answering
G'day can anyone help me was annotating a VP & VW crashed from then on it is very slow to start up again it hangs on loading the workspace, trashed the workspaces & reinstalled those I used on my laptop no dice, wanted to trash my prefs but could not find them ?
If I log in as admin & start up VW it seems fine, any suggestions
thank you
try f7
save the file with new name?
do you have "display viewport cache" on in edit viewport window
we had screen flicker as a problem a year ago on a XP machine with newly installed VW2008, Julian Carr suggestion was mouse driver and it fixed the problem (disable in start up folder if I remember correctly)
My design layer notes only contains notes it does not interfere with any other design layers containing my model
I have my General notes on a design layer and use two Viewports to present General notes in two columns on a General notes sheet
Am no expert but I think QT Pro makes that possible
Can any one give me a pointer about editing section markers? in 2008 I choose my section marker & it would show unfilled not so in 2009.
So I unfilled them in their file but my marker @ the other end of line stays filled even when it is not filled in their own file and shows not filled in the OIP.
Also I cannot move the section marker text or at least I am not given a handle for it.
Thank you
Yes it started life as VW2008 file, I dont know, am spending to much time on this, it works properly in a new VW2009 file so maybe it is just translation glitch.
Thanks for replying.
In my live section with display setting "show wall components" ticked, I have no wall components showing. Can anyone help please? I think I ticked & unticked everything it was original a 2008 file
Yes, thank you
Thank you
I have still walls shooting of the screen when they are end butting any one else?
Thanks Jeffrey, here is an empty file with 2 VP on sheet after naming the VP the drawing label gave the file name
in VW2008 I would give my VP its name "Floor Plan" then when I put in a drawing label, when annotating it would display the VP title now VW2009 it gives the file name & I have to change the info in OIP any ideas how to get the former mode back thanks
Yes I have noted same problems some times specially after repeated edits, the whole object disappears specially with a polyline, changing the object to polygon gives me some peace some times otherwise close down & start again.
telepathic input no mouse needed
No you dont Architect will do
I see this happening after fit walls to roof command if the roof meets wall correctly it does not happen
is the roof layer set to grey in VP OIP?
There is also an issue with some microsoft mouse drivers you'll have to check some post back
some weeks ago some one suggested making date stamp a symbol & edit symbol as required that works perfect here as date changes only when required to change
Section Markers
in Architecture
Posted · Edited by mar schrammeyer
Set text size (menu bar) after selecting section line
