mar schrammeyer
385 -
Posts posted by mar schrammeyer
I created a named notes layer placed a keynote, erased the note
when placing a keynote annotation chose the named layer location instead of default
on the selected sheet layer create a viewport of your note layer
this vp can be placed on any sheet
you can edit your workspace, to show navigation palette under windows/palettes
strangely it was removed from there last upgrade?
For the the magic mouse is a 3rd party app available called mmiddle which allows centre click for panning
I am trying to learn something by editing files created in earlier versions but I continually crash, specially trying to copy and paste in new file
often crashing while editing (poking around trying to understand) also opening files in 2019 all nodes are stacked one on top of the other but opening in 2018 they are stetched way out
see screen shots both taken in top plan
Since I upgraded from VW2015 to VW2018 & 2019 two weeks later I try to educate myself in Marionette
after downloading some files and opening in VW2019, I found when trying to edit an object all the nodes where stacked one on top of the other
(bit of an headache to unravel )
but opening this file in 2018 everything is nicely spread out and a bit easier to understand.
Can someone maybe confirm this glitch this is file 6 of the marionette tute try in 2018 & 2019
Clone your existing HD to an external drive and work from that till The Day
I Work on a 2017 4K imac from a Thunderbolt external drive while mI have upgraded the imac to Mojave
a work around would be bootcamp & W10
1
I had a similar problem with text (1) and call out (option 1) but this was only in one workspace
advice from OzCad (if you edit the workspace and remove then add back these shortcuts, it will work again. Sorry for the inconvenience.)
1
First call-out text in subsequent call-outs a @#$ nuisance solution first call-out a space,
delete call-out and start each new call-out with delete
all my work is in 3D
Render with hatch fantastic but see picture..
is this for everyone or just me
use design layer viewports
Most crashes happen (for me) when clicking the eyedropper tool.
Anyone similar experience?
Thanks very much for all answers
regards
Hi all, we had someone changing some text on a pdf produced by our office with vw2012 does anyone know how this can be prohibitted, no idea what program was used to achieve this.
regards
The walls that not follow the AEC (fit walls) command are referenced I am not to familiar with referencing but that seems to be the problem. I was able to manually fit the walls to the roof
yes I run 2009 on XP via VM Fusion so I can make my VR objects since 2012 or so they became to big so if I need one I export to a 2009 file etc.
Windows XP on a Mac either Bootcamp or Virtual box
Is this what you're after? I managed it by 3D manipulating the wall and also the fit walls to object worked.
yes I have this window popping up still in 2014
display image??
Cannot open the file either asked Ozcad for clarification.
OK had confirmation from Ozcad we cannot open student files with pro
Opened the file with 2012 viewer and it appears that the object is original a generic solid which looks faceted, so if that original object could be edited to be smooth..
I would create 3D loci from those site points you measured, select all and create site model from AEC menu and use VW help
Thinking about a new monitor - looking for advice.
in General Discussion
Posted
Secondhand 2009 27” imac with target display
