G-Man
    5
    Never
Everything posted by G-Man
  1. The split tool is too indiscriminate. With Cmd-T you can prepick all of the items you want to trim. Split will cut all of the lines you cross. Split might force you to be more careful, but it's tedious and Cmd-T is faster.
  2. Even a simple check mark next to the sheet name would be an improvement. The lack of an indicator for the active sheet can be very frustrating when several people work on the same file. Something else that would be useful would be to combine the class, layer and sheet edit dialogs into a single table-like palette. That way one could see at a glance the full matrix of combinations and easily check classes and layers on or off to create/edit any sheet in a single place. [This message has been edited by G-Man (edited 01-04-2001).]
  3. Hey, Vectorworks gods: 1. World and local coordinates in both cartesian and polar units with the tape measure tool. Just reporting cartesian units is severely limiting. 2. World, local and polar coordinate entry options in offset dialogs (array duplicate, offset tool, etc.). 3. Radians. Useful for subdividing curves. 4. Reporting circumferential arc lenths in linear dimensions and radians, not just sweep in degrees or d-m-s. My benchmark for these is the Form-Z interface.
  4. It would also be helpful to be able to offset using polar coordinates. The tape measure tool should report polar coordinates and world/local coordinates as well, for that matter.
  5. Radians? I wish this thing could do radians. It makes placing things along arcs much easier.
