Content Count
35 -
Calendar
Everything posted by JGraber
Floating plant count datum while installing multiple plants
JGraber replied to JGraber's question in Wishlist - Feature and Content Requests
Basically, I want VW to count the number of plant objects that I am placing with the current plant tool session. Sometimes I'll have 20 plants in a row, but I want 21 to keep an odd number then I end up counting all of the plant outlines to figure out how many I have, instead, if there was just a small floating box near the plant tool that is showing how many plant objects are about to be placed it would be so much easier. -
As I am using the plant tool I'd like to be able to see how many plants I currently have placed on the design. So when I am clicking and placing multiple shrubs in a bed at like there to be a floating datum box or something in the resource browser that shows I have currently placed '5' shrubs for instance and it will increase or decrease until I double click to complete the plant placements. This would also be helpful when doing a planting line.
In VW 2015 I had a template file with hundreds of plant symbols and definitions. I had it to where there was a standard plant tag that showed up when the plant symbol was placed on the document. I believe I accomplished that by opening up the plant settings and choosing that tag attributes without choosing a specific plant. In VW 2016, I've tried that to no avail. With no plant selected I've changed the tag attributes, but then I get an error saying a non plant object was selected or nothing happens at all. I've added all of my symbols to the "Basic Template Plants" file. In VW 2015, I added them to the "Plant Defaults" file. Is there an easy way to change the default plant tag attributes for all the plant symbols in a file?
- 1 reply
- 1
Well I'm not sure what happened because I purposefully shut down the program and looked in task manager to see if it was opened before I ran the update.
I tried to install update, but had error and now it says this when trying to run the update "You have entered a Series E serial number, but C:\Program Files\Vectorworks2015\Vectorworks2015.exe is not a valid Series E version of Vectorworks. Please enter a different serial number, or select a different folder to update". And when I try to open VW it says SP4 on splash screen, but then says it is corrupt or missing files and asks me to reinstall. Has this happened to anyone else?
Just to update since I didn't receive any replies...I opened the template and found the last few symbols I created and deleted them. This has seemed to work so far.
I just updated to the newest SP2 build for 2013 and am having major problems with slow response times. I use Designer with Renderworks, but mainly use it for Landmark functionality. I created a template file to hold all of my plant symbols. In the previous build and in VW 2012 when I create a new file based on the template it would generate in a matter of seconds. In build 176329 it literally takes 90 seconds to generate the new file. All the while I get the Windows spinning circle and if I click the screen fades and it is not responding. Watching the processes in WTM I see that VW 2013 opens at about 150K used memory, but when the file opens it jumps to 370K and uses 20% CPU. The CPU stays at 20 the entire time. Worse yet, after it does open and I try to add a new plant definition to the template it now takes 6 minutes to add it if it responds at all. Just yesterday I was using the previous build and had normal response times. To test I opened the file in VW 2012 and had no problems with response. I welcome any suggestions.
Thanks, this works great.....I guess I need to get a list of all the shortcuts
Jeffrey I contacted Tech support so we will see what they say.
I thought I saw in a tutorial video that it is possible to select multiple objects without having to click-drag over the entire object similar to the click-left drag in Acad where you only have to touch the object and it will select it. It sure would be a lot faster for me if this feature existed. Does anyone know what I'm getting at?
I have restarted VW and the computer many times. This has been a problem since I installed 2009 a while back, but I've lived with it. Ozzie- thanks the Ctrl Tab works perfectly, which leads me to be even more confused with the menu commands not working at all.
I do have SP2...need to update profile Switching to another workspace does not work. I'll keep trying
Unless I forgot how to do this from VW 2008 to VW 2009 then something has to be wrong here. If I'm in full screen mode and have multiple open drawings and want to switch between them I go to the menu Window->Drawing1.vwx when I'm currently viewing Drawing2.vwx and vice versa if I want to switch what I'm viewing. Well, when I do this, absolutely nothing happens so I'm left minimizing one and enlarging the other. Is this happening to anyone else? Is there a command shortcut to scroll through open documents?
This is something that has haunted me since VW12 and now in 2008. 2 different scenarios...same result. Let's say I add 5 of a plant symbol to the design in a grouping, then I copy and paste that same grouping into another location. I then rotate the new grouping. And maybe I do this again a few times. Finally I want to change all the plants into a single group. When I click Change Plant Grouping....all the plant paths go haywire and none of the modified group placements are preserved. This is also the case if you mirror a group of plants and then try to combine all the plants in one drawing. Each groups to the original group shape. I will post a before and after pic showing the problem. I'm guessing this is something that cannot be corrected.
Major Autocad 2008 Import Problem! VW2008 Export Not Working!
JGraber replied to JGraber's question in Troubleshooting
I submitted a bug report for this and I was told this is a known problem with any computer running 4 Gb of memory. I took out 2 gigs and the import worked. -
JGraber posted a question in Troubleshooting
This is the first time I've needed to import an DWG into VW2008 since I upgraded a few months back and it was extremely unsuccessful. So I tried this both with the single file import and the batch import. I've also tried this with a 2008, 2007, and 2004 version DWG file. When I do a single import and choose a file.....nothing happens...except it shows in the bottom right corner that the "undo history cleared" was accomplished. It does not bring up any other import options like line weights or classes or anything. When I do the batch import...same thing happens...only this time a popup messages displays something like "are you sure you want to clear your undo history...yes or no". Absolutely nothing happens. Well, then I thought there may be a problem with other import types, but I tried a few and they import with no problem at all. Needless to say, all this is very frustrating. So then, I thought I better check the export function......once the export dwg is selected in the menu....nothing pops up. It is as if I didn't even select it. Well, I thought maybe my workspace has become corrupt somehow so I switched to the classic workspace and the problems persist. Am I somehow the only one with this problem? Please Help! -
Okay, I've updated to the latest SP2 and I still have problems. I'm wondering if it may just be my printer. Does anyone have a Designjet 500 running on Vista 64 bit? Are you able to print with opacity/GDI? I was able a few times to export as a pdf with GDI enabled, then print and it worked so I am wondering if it is just a VW issue. Also, it seems that there are just some general font issues with VW that restrict the font from being exported....I tried it with few fonts and text doesn't show up, but on some other fonts it does.
Okay, so someone told me GDI printing was fixed with SP2 so it must be my DesignJet 500 then because when GDI is enabled and I try to print to it the sending to printer popup box opens then closes immediately without sending a job to the printer. As soon as GDI is turned off, then it will print. Also, another weird quirk is when GDI is off, my architect font shows up fine, but when it is on...the font looks like arial. That is annoying. Finally, when I try to export to pdf or print to my Adobe PDF printer all of the text disappears from the design. I have tried this with GDI enabled and disabled and there is no change. Any suggestions are appreciated.
Bug in VW2008 SP2 with resource selection pop-ups
JGraber replied to Richard T's topic in General Discussion
This is happening to me for my plant selection list. It is annoying. -
Is there a way to put an arrow on the end of the plant tag line?
Scroll Bar for Drop Down Plant List
JGraber posted a question in Wishlist - Feature and Content Requests
I have added an entire catalog of plants for my area and to have use the little arrow at the bottom of the drop-down does not work well. I also don't want to have to use the plant settings box to choose one of the plants because it just adds another step. I thought this was available in VW 12.5. A scroll bar on the right side of the drop down would be great. -
I've installed an Architect TTF on my system to use in VW2008, but it seems that it doesn't like it for some reason. You can see in the photos that when I have text selected and am editing it, the font displays correctly, but as soon as I click off of the text it reverts to an Arial-like font. I have other TTF fonts that work fine. Anyone run into this issue? I have all the font mappings pointing to Architect and not another font.
I have the most recent build and am unable to print when GDI is enabled. As soon as it is disabled I am able to print, but I lose opacity settings when I do that.
I take it that even with SP2 the issue with printing in GDI mode is still not resolved. I have had no luck with it and I would like to print my objects at their opacity level.
For us the message does not always come up, but a good percentage of the time it does. I find that if I open task manager some of the VW functionality comes back but when I try to save it brings up the save box and it is blank so I can't see any of the buttons or anything. The unavailable resource error does popup up about 10 times or so before the program seems to freeze.
