5,153 -
Everything posted by CipesDesign
cberg, there is probably some way to do it, but I just create my own in the VP Annotations.
Thanks Wes. Yes the stair tool has been through many many versions none of which can actually do everything that everyone wants. That's the main reason that I developed my own very simple solution(s). Additionally I really dislike the UP and DOWN arrow graphics and text in the Plug In and prefer to use my own . Graphics snob? Who me??
There are two ways that I use: 1) duplicate the stair and paste in place on the other layer, making sure to move up (or down) so that the stairs are exactly aligned in all views. 2) Place the stair on the lower of the two layers, then use a Floor (or slab) on the upper layer, with a portion cut out to show the stair below. The second method is closer to being anatomically correct but requires that the lower layer be "on" in the VP of the upper layer. Depending on what is on the lower layer this can be difficult. Sometimes the first method is just quicker and easier.
I have found that I can create Pads that are extremely close to each other, but not touching. The Pads should be surrounded by the same Boundary. Also, I often use other objects like Floors (slabs) or Roof Faces (yes I use Roof Faces for sloping walkways, driveways, etc) to cover the slight anomalies which the Site Model leaves due to non-intersecting Pads. This gives me the 3d visual presentation I'm after. I usually enhance or cover these shapes in annotations for clean 2d plan views.
Yes it's good to have a viable workaround, but the tool still needs to be fixed.
Newbie question : trouble with stories
CipesDesign replied to freejonah's question in Troubleshooting
This thread might be helpful (ignore the text in the alert that is embedded, just click on it and you will see the entire thread, not only that portion): -
Correction: the tool I mentioned is actually called the Mullion tool. In my (US; Architect) workspace it is in the Building Shell tool set. Sorry for the confusion! And just FWIW, I prefer to model these using extrudes as stated above. Ultimately it's easier to get what I want that way.
Yes, and don't forget that you can create Muntins either with the Muntin tool, or sometimes even easier by going to a frontal view and (in screen plane) drawing the Muntin configuration as a closed polygon, then extruding, then move into place in Top/Plan. Of course these can be selected with the window and made into a Symbol.
Dimensions are not right even though I am in the Annotation Viewport
CipesDesign replied to Nefertricia's question in Troubleshooting
One additional thought: it is possible to accurately dimension a 3d view, but the dimensions need to be in the Design Layer(s). When I do this I usually create a special Class for the dimensions so that I can control visibility in different views/Viewports. -
There have numerous problems reported with the Parking Space PIO, many of which seem to be errors in math (or math as it relates to programming?). I am hoping the engineers are fixing it, or perhaps starting over from scratch. Fingers crossed.
Also, FWIW, applying a texture (like grass) might help the appearance get closer to realistic.
Heliodon Causes Vectorworks 2020 To Crash
CipesDesign replied to Jacob Evans's question in Troubleshooting
I use one or more heliodon on every project and have never had this problem. Perhaps there is something else going on?? -
I will probably be tarred and feathered for this but.... I have never been a fan of 'Insertion' of any objects, with the exception of Doors and Windows. As you mention, initially every inserted object just sort of goes where it wants to, which forces the user is reposition, flip, etc. The advantage of cutting a hole in a roof is that I can have control over the exact location of the skylight in relation to roof framing members and placement at room centers or over other chosen object (eg: kitchen island). Not only does this give me accurate section views but also the ability to precisely dimension and callout the location so that framers/builders have total clarity as to my intent. Old school, but effective.
bc, FWIW, I usually prefer not to insert, but instead cut a hole and place skylights manually.
That's why I said "Sometimes". In cases where covering does not work, if needed, I Model the whole thing.
FWIW, Sometimes I find that I can simply cover the tapered (or narrowed) portion of the stair with a wall, using send to back, etc. Obviously not anatomically correct, but it achieves the intent graphically. [Easiest solutions = best solutions?]
Interesting to relook at this thread a few years later. I am now of the mind that it would good to be able to set any individual VP to Always Update. With many smaller projects this would save me a ton of time.
That’s weird! Have you tried restarting?
Or in annotations, you can trace over the curved surfaces and use a (subtle) gradient fill to give them some depth.
I also notice that the texture has rotated. Arg!
Looks like you are attempting to create a segmented roof(?). If so, it’s probably best to use Roof Faces. I would do the math first and also suss out how the thing will be built. Then create one segment (pie slice, or triangle) and carefully duplicate it to make the others. Usually I would then Group all the segments for a little more ease of handling.
FWIW, I often use a discreet Design Layer for Clerestory Walls (with windows). That will solve these sorts of visibility problems.
Ken, I still am unclear as to exactly what you are attempting to achieve... But I do notice a couple things which might help: when I open the VW's file there is one 2d/3d Symbol. However two things about it are not correct. First, the View is set to Top/Plan, but that's not a Top/Plan depiction of a door; it's a Front (or Rear) depiction. Second, you seem to have created the "door" geometry from a Hardscape Object. Why? Try opening and examining the file I attached. It might get you part of the way there. Door Leaf Symbol-2.vwx
Hi Ken, If you are able to upload a VW file and a description of the details of the door you need (like a picture) maybe myself or someone can take a look and try to help.
Try using one of the provided Custom Leaf options, then editing the 3d geometry to your liking. This might make it easier to understand the process. If you choose a Custom Leaf it will appear in the Resource Manager as a Symbol. Find the Leaf/Symbol in your file (not the Library file) and Option Click on it to Edit. Be carful not to move the geometry in 2d or 3d space. This will create alignment problems between the 2d and 3d.
