addy
  • Content Count
    21
Everything posted by addy
  1. revision date.. would be good. Also P_Drawing Title does not get the name automatically from the drawing title. It only allows to put the field on all title blocks. I kind of what to make my own version of the drawing label tool but in a title block. Thanks
  2. would it be ":title" ":date"
  3. I did that but is does tell you how to add the date and time or document title. I want it so it updated it's self..
  4. Hi All, i'm trying to add the drawing and the date and time to my custom title block. I already have auto sheet layer naming and can link my records to my record format. What i'm missing is the suffix or prefix code for date and time and drawing title. I can not find it the VW manual. I'm using VW 2010 Can someone help please? Thanks Adriano
  5. Hi all I'm trying to render using the lee colour range and it's not working. I have had it working in the past. Have i done somthing to turn it off ??
  6. Thanks all fixed set to always
  7. Hi All When try and use the light tool i get an error that says (created light is not visible) I have recently updated to 12.5 on MAC Thanks
  8. addy
    Start Up
    Thanks All Now i have template and my document opens when Vw Starts.
  9. addy
    Start Up
    Hi All I am fairly new to VectorWorks so this may seem like a stupid question but i have to ask. How do you stop VW opening a new drawing or change the default drawing that VW opens every time the application is started using the icon from the doc. thanks Thanks
  10. U is the key i was looking for thanks. I have loooked in the work space editor but i can not find where to change the default keyboard shortcut from U. What is the tool called or what menue is under i am stumped.....
  11. HI All Can anybody help me with adding a shortcut to the Interactive scaling tool. If there is an existing short cut, what is is ? Im using VW 12 on a MAC Thanks
  12. addy
    Shadows and Mirror
    If looked through old posts and i couldn't find anything useful. I'm using version VW12 and most the posts out date this.
  13. Hi I have 2 questions. 1. Is it possible to have shadows with soft edges ? if so how is it done? 2. I have been adding a mirror finish to flooring and i wanted to difuse the reflective content so it was blury. Is the mirror tool best for this application ? Should i be using somthing like platic or phong. Thanks Addy
  14. I Changed to feet & Inches and proplem solved Thanks All..
  15. Hi Jtallen Can i email you my file Addy
  16. Z Hight is already set at 6m and lights are attached to lighting position FOH 1. Focus Point is on the ground plane.
  17. Hi When focusing lights, only X and Y positions move. The Z position does not change. Once rendered lights are parallel to the grond plane. Draw beem shows lights focued on focus point. How do you get lights to angle down on fucus poin???
  18. Not sure if this a Spotlight or Render Works question. Is it possible to have 2 or more lights with different lit fog densities ? E.G. Lights on rear truss to be heavy fog and lights on front truss to be light fog. thanks.. [ 01-31-2006, 07:08 PM: Message edited by: addy ]
  19. Hi all thanks for your speedy replies, all your advise has been great. Problem solved thanks
  20. Hi Im having problems with stepped angle lines when i render in full quality. I also need some help on printing in a higher quality, because these stepped lines are being replicated in my pdf's. If any body could point me to an artical or give a detailed explanation it would be most apprciated Thanks Addy
  21. addy
    Lecterns
    Hi Need a symbol of a lecturn, does anyone know were i could find one. Thanks
