jonathan
    2
    Never
Everything posted by jonathan
  1. best results are if you print to file through laserwriter as you can control the dpi, page size, colour matching etc this allows you to print (plot) at what size your plotter driver will allow going through pdf writer allows only 288 dpi and max size 1100mm x 1100mm or there abouts best method for plotting from bureaus etc around and ditributing to clients also allows to keep electronic file records, pdf files generally significantly smaller than original can't be altered etc set up multiple page documents to avoid file opening/down load fee
  2. the marquee tool only works with rectangles the only way to use it on oblique ojects is to rotate them to be square with w,y polygons require multiple rotates it would appear obvious that polygonal marquees can be created
