Bruce F
  • Content Count
    30
Community Reputation
0 Neutral
About Bruce F
  • Rank
    Greenhorn
Personal Information
  • Occupation
    Architect
  • Location
    Atlanta, GA
  1. From previous saved file version I try to change door settings before insertion and get script error Error: _4254 _4291 - Array ALLOCATE end < start: _4280 Error: _7804 - ENDGROUP statement missing. Error: _7804 - ENDSYM statement missing. Error: _7804 - ENDGROUP statement missing. Error: _7804 - EndContext statement missing. What does it mean? Can it be fixed with VW PI Editor?
  2. So I track it back to a corrupted file. Where's the corruption? Can it be fixed, or just abandon it and return to an earlier version? And how does corruption happen anyway? Thanks, Bruce
  3. Hate to talk to myself, but.... I have started crashing VW every time I try to insert a door in a wall. How would you fix this?
  4. Didn't work - it crashed VW update as well... Before you read this I'll run VW2008SP3 - maybe that will be the answer... I get the following message when trying to change door PIO settings: Error: _4254 _4291 - Array ALLOCATE end < start: _4280 Error: _7804 - ENDGROUP statement missing. Warning: _7804 - Name already exists. __NNA_Door_Symbol Error: _7804 - ENDSYM statement missing. Error: _7804 - ENDGROUP statement missing. Error: _7804 - EndContext statement missing. Sadly I'm not practiced at Vectorscripting - what to do? However, sometimes VW crashes instead, with this bug report (just repaired permissions with Disk Utilityi) Date/Time: 2008-07-28 12:36:18.703 -0400 OS Version: 10.4.11 (Build 8S165) Report Version: 4 Command: VectorWorks Path: /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/MacOS/VectorWorks Parent: WindowServer [65] Version: 13.0.1 (83388) (???) PID: 236 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000000c Thread 0 Crashed: 0 net.nemetschek.vectorworks 0x00a271d4 __darwin_gcc3_preregister_frame_info + 10632476 1 net.nemetschek.vectorworks 0x004ac0cc __darwin_gcc3_preregister_frame_info + 4885524 2 net.nemetschek.vectorworks 0x00a6f630 __darwin_gcc3_preregister_frame_info + 10928504 3 net.nemetschek.vectorworks 0x01122ed8 IwSolutionArray::Dump() const + 656992 4 net.nemetschek.vectorworks 0x01139484 IwSolutionArray::Dump() const + 748556 5 net.nemetschek.vectorworks 0x0039eab4 __darwin_gcc3_preregister_frame_info + 3782140 6 net.nemetschek.vectorworks 0x0039f51c __darwin_gcc3_preregister_frame_info + 3784804 7 net.nemetschek.vectorworks 0x003a4ac4 __darwin_gcc3_preregister_frame_info + 3806732 8 net.nemetschek.vectorworks 0x0039eb38 __darwin_gcc3_preregister_frame_info + 3782272 9 net.nemetschek.vectorworks 0x0039f51c __darwin_gcc3_preregister_frame_info + 3784804 10 net.nemetschek.vectorworks 0x0039fb70 __darwin_gcc3_preregister_frame_info + 3786424 11 net.nemetschek.vectorworks 0x00d6f614 IwObject::operator delete(void*) + 2654624 12 net.nemetschek.vectorworks 0x00241320 __darwin_gcc3_preregister_frame_info + 2350696 13 net.nemetschek.vectorworks 0x00258abc __darwin_gcc3_preregister_frame_info + 2446852 14 net.nemetschek.vectorworks 0x01de4bbc typeinfo name for kd_block_encoder + 505316 15 net.nemetschek.vectorworks 0x00c53fd8 IwObject::operator delete(void*) + 1493860 16 net.nemetschek.vectorworks 0x0029aaa8 __darwin_gcc3_preregister_frame_info + 2717168 17 net.nemetschek.vectorworks 0x00d75578 IwObject::operator delete(void*) + 2679044 18 net.nemetschek.vectorworks 0x01127524 IwSolutionArray::Dump() const + 674988 19 net.nemetschek.vectorworks 0x01139484 IwSolutionArray::Dump() const + 748556 20 net.nemetschek.vectorworks 0x003a11f4 __darwin_gcc3_preregister_frame_info + 3792188 21 net.nemetschek.vectorworks 0x0039e744 __darwin_gcc3_preregister_frame_info + 3781260 22 net.nemetschek.vectorworks 0x0039f51c __darwin_gcc3_preregister_frame_info + 3784804 23 net.nemetschek.vectorworks 0x0039ffc8 __darwin_gcc3_preregister_frame_info + 3787536 24 net.nemetschek.vectorworks 0x003a1280 __darwin_gcc3_preregister_frame_info + 3792328 25 net.nemetschek.vectorworks 0x0039e744 __darwin_gcc3_preregister_frame_info + 3781260 26 net.nemetschek.vectorworks 0x0039f51c __darwin_gcc3_preregister_frame_info + 3784804 27 net.nemetschek.vectorworks 0x0039f7bc __darwin_gcc3_preregister_frame_info + 3785476 28 net.nemetschek.vectorworks 0x00d7755c IwObject::operator delete(void*) + 2687208 29 net.nemetschek.vectorworks 0x00d7781c IwObject::operator delete(void*) + 2687912 30 net.nemetschek.vectorworks 0x00d78854 IwObject::operator delete(void*) + 2692064 31 net.nemetschek.vectorworks 0x0072c7cc __darwin_gcc3_preregister_frame_info + 7508756 32 net.nemetschek.vectorworks 0x00c39c2c IwObject::operator delete(void*) + 1386424 33 net.nemetschek.vectorworks 0x00310dc4 __darwin_gcc3_preregister_frame_info + 3201292 34 ...torWorks.ExtendedProperties 0x0967cff0 GS_Kludge + 100 35 ...torWorks.ExtendedProperties 0x096766c4 CallObjectEventHandler(CallBackBlock*, long, char**, long, long&) + 108 36 ...torWorks.ExtendedProperties 0x096767b8 EPEmoduleImp::HandleObjectEvent(long, char**, long, long&, CallBackBlock*) + 120 37 ...torWorks.ExtendedProperties 0x0967868c PluginLibraryMain(long, void*, long&) + 2176 38 ...torWorks.ExtendedProperties 0x09675d60 plugin_main + 72 39 net.nemetschek.vectorworks 0x0072b16c __darwin_gcc3_preregister_frame_info + 7503028 40 net.nemetschek.vectorworks 0x0072b3b8 __darwin_gcc3_preregister_frame_info + 7503616 41 net.nemetschek.vectorworks 0x002d7830 __darwin_gcc3_preregister_frame_info + 2966392 42 net.nemetschek.vectorworks 0x00c30998 IwObject::operator delete(void*) + 1348900 43 net.nemetschek.vectorworks 0x00c34ba8 IwObject::operator delete(void*) + 1365812 44 net.nemetschek.vectorworks 0x00be6820 IwObject::operator delete(void*) + 1045420 45 net.nemetschek.vectorworks 0x00bea3a0 IwObject::operator delete(void*) + 1060652 46 net.nemetschek.vectorworks 0x0021badc __darwin_gcc3_preregister_frame_info + 2197028 47 net.nemetschek.vectorworks 0x00bcc90c IwObject::operator delete(void*) + 939160 48 net.nemetschek.vectorworks 0x00c43b34 IwObject::operator delete(void*) + 1427136 49 net.nemetschek.vectorworks 0x007eb3f0 __darwin_gcc3_preregister_frame_info + 8290104 50 net.nemetschek.vectorworks 0x007eb4fc __darwin_gcc3_preregister_frame_info + 8290372 51 net.nemetschek.vectorworks 0x0018bc1c __darwin_gcc3_preregister_frame_info + 1607524 52 net.nemetschek.vectorworks 0x00044664 __darwin_gcc3_preregister_frame_info + 266668 53 net.nemetschek.vectorworks 0x0009a5b4 __darwin_gcc3_preregister_frame_info + 618748 54 net.nemetschek.vectorworks 0x000927cc __darwin_gcc3_preregister_frame_info + 586516 55 net.nemetschek.vectorworks 0x0010f670 __darwin_gcc3_preregister_frame_info + 1098168 56 net.nemetschek.vectorworks 0x000e6b5c __darwin_gcc3_preregister_frame_info + 931492 57 net.nemetschek.vectorworks 0x001376d4 __darwin_gcc3_preregister_frame_info + 1262108 58 net.nemetschek.vectorworks 0x000e6e34 __darwin_gcc3_preregister_frame_info + 932220 59 net.nemetschek.vectorworks 0x001119c4 __darwin_gcc3_preregister_frame_info + 1107212 60 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 61 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 62 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 63 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 64 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 65 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 66 net.nemetschek.vectorworks 0x000e9520 __darwin_gcc3_preregister_frame_info + 942184 67 net.nemetschek.vectorworks 0x01d72a34 typeinfo name for kd_block_encoder + 37980 68 net.nemetschek.vectorworks 0x00140c30 __darwin_gcc3_preregister_frame_info + 1300344 69 net.nemetschek.vectorworks 0x000907b8 __darwin_gcc3_preregister_frame_info + 578304 70 net.nemetschek.vectorworks 0x0013df88 __darwin_gcc3_preregister_frame_info + 1288912 71 net.nemetschek.vectorworks 0x0011e7c8 __darwin_gcc3_preregister_frame_info + 1159952 72 net.nemetschek.vectorworks 0x0011da34 __darwin_gcc3_preregister_frame_info + 1156476 73 net.nemetschek.vectorworks 0x0007c1f8 __darwin_gcc3_preregister_frame_info + 494912 74 net.nemetschek.vectorworks 0x000f8688 __darwin_gcc3_preregister_frame_info + 1003984 75 net.nemetschek.vectorworks 0x000f7ad4 __darwin_gcc3_preregister_frame_info + 1000988 76 net.nemetschek.vectorworks 0x0007b9b8 __darwin_gcc3_preregister_frame_info + 492800 77 net.nemetschek.vectorworks 0x000031ac start + 812 78 net.nemetschek.vectorworks 0x00002eb0 start + 48 Thread 1: 0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b29c mach_msg + 60 2 com.unsanity.ape 0xc0001bf4 __ape_agent + 296 3 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 2: 0 libSystem.B.dylib 0x900061ec syscall + 12 1 com.apple.OpenTransport 0x9aff45a0 BSD_waitevent + 44 2 com.apple.OpenTransport 0x9aff9360 CarbonSelectThreadFunc + 176 3 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 3: 0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480 2 com.apple.OpenTransport 0x9aff4e94 CarbonOperationThreadFunc + 80 3 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 4: 0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480 2 com.apple.OpenTransport 0x9b000f58 WaitForSyncDone + 76 3 com.apple.OpenTransport 0x9b007e88 RecvData + 676 4 com.apple.OpenTransport 0x9b008154 OTRcvUData + 60 5 net.nemetschek.vectorworks 0x01b6a01c haspregnew + 6320 6 net.nemetschek.vectorworks 0x019630e4 hasp + 16196 7 net.nemetschek.vectorworks 0x01963718 hasp + 17784 8 net.nemetschek.vectorworks 0x01963bac hasp + 18956 9 ...ple.CoreServices.CarbonCore 0x90bc4794 PrivateMPEntryPoint + 76 10 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 5: 0 libSystem.B.dylib 0x9002c3c8 semaphore_wait_signal_trap + 8 1 libSystem.B.dylib 0x90030eac pthread_cond_wait + 480 2 ...ple.CoreServices.CarbonCore 0x90c024b0 MPWaitOnSemaphore + 184 3 net.nemetschek.vectorworks 0x01146088 IwSolutionArray::Dump() const + 800784 4 net.nemetschek.vectorworks 0x01961c74 hasp + 10964 5 net.nemetschek.vectorworks 0x019620c0 hasp + 12064 6 ...ple.CoreServices.CarbonCore 0x90bc4794 PrivateMPEntryPoint + 76 7 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 6: 0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8 1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556 2 ...ple.CoreServices.CarbonCore 0x90bf73f4 TSWaitOnSemaphoreCommon + 176 3 ...ickTimeComponents.component 0x992d5804 ReadSchedulerThreadEntryPoint + 5300 4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 7: 0 libSystem.B.dylib 0x9000b348 mach_msg_trap + 8 1 libSystem.B.dylib 0x9000b29c mach_msg + 60 2 com.apple.CoreFoundation 0x907de9ac __CFRunLoopRun + 832 3 com.apple.CoreFoundation 0x907de2b0 CFRunLoopRunSpecific + 268 4 com.apple.audio.CoreAudio 0x91458524 HALRunLoop::OwnThread(void*) + 264 5 com.apple.audio.CoreAudio 0x914582c4 CAPThread::Entry(CAPThread*) + 96 6 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 8: 0 libSystem.B.dylib 0x9002c4b8 semaphore_wait_trap + 8 1 ...ickTimeComponents.component 0x997fad24 QTThreadWaitSignal + 100 2 ...ickTimeComponents.component 0x9935a960 audioprepThreadEntry + 96 3 ...ickTimeComponents.component 0x997fa9e4 start_thread + 84 4 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 9: 0 libSystem.B.dylib 0x90054388 semaphore_timedwait_signal_trap + 8 1 libSystem.B.dylib 0x90070be8 pthread_cond_timedwait_relative_np + 556 2 com.apple.audio.CoreAudio 0x914696ac CAGuard::WaitFor(unsigned long long) + 204 3 com.apple.audio.CoreAudio 0x914695bc CAGuard::WaitUntil(unsigned long long) + 304 4 com.apple.audio.CoreAudio 0x91467800 HP_IOThread::WorkLoop() + 852 5 com.apple.audio.CoreAudio 0x91467498 HP_IOThread::ThreadEntry(HP_IOThread*) + 16 6 com.apple.audio.CoreAudio 0x914582c4 CAPThread::Entry(CAPThread*) + 96 7 libSystem.B.dylib 0x9002bd08 _pthread_body + 96 Thread 0 crashed with PPC Thread State 64: srr0: 0x0000000000a271d4 srr1: 0x000000000200f030 vrsave: 0x0000000000000000 cr: 0x24002424 xer: 0x0000000020000004 lr: 0x0000000000a2716c ctr: 0x00000000003a5418 r0: 0x0000000000000000 r1: 0x00000000bfff50a0 r2: 0x00000000ffffffff r3: 0x0000000002d6eb40 r4: 0x0000000000000004 r5: 0x000000000fd347c4 r6: 0x000000000145cd10 r7: 0x0000000053004e53 r8: 0x00000000f05f6600 r9: 0x00000000003a5418 r10: 0x000000000038d2a0 r11: 0x00000000ffffffff r12: 0x000000000fa09a50 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000 r16: 0x0000000000000000 r17: 0x0000000000000000 r18: 0x00000000bfffb9ec r19: 0x0000000002aff3d8 r20: 0x00000000bffffac8 r21: 0x000000000e4d7a1c r22: 0x00000000025ad5dc r23: 0x00000000025ad5dc r24: 0x00000000bfff8300 r25: 0x000000001636a200 r26: 0x0000000000000000 r27: 0x0000000000000001 r28: 0x000000000fd347c4 r29: 0x0000000000000004 r30: 0x0000000002d6eb40 r31: 0x0000000000a2716c Binary Images Description: 0x1000 - 0x25b3fff net.nemetschek.vectorworks 13.0.1 (83388) (???) /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/MacOS/VectorWorks 0x2f67000 - 0x2f6ffff com.Logitech.Control Center.Scroll Enhancer 2.2.2 /Library/Application Enhancers/LCC Scroll Enhancer.ape/Contents/MacOS/LCC Scroll Enhancer 0x2f92000 - 0x2fabfff GLDriver /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLDriver.bundle/GLDriver 0x2fc3000 - 0x2fdefff GLRendererFloat /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x3808000 - 0x3fa6fff libRenderWorks.dylib /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/MacOS/libRenderWorks.dylib 0x476e000 - 0x47e9fff com.apple.GeForce3GLDriver 1.4.18 (4.1.8) /System/Library/Extensions/GeForce3GLDriver.bundle/Contents/MacOS/GeForce3GLDriver 0x7ae7000 - 0x7bf6fff GLEngine /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine 0x7f05000 - 0x7f07fff com.apple.PDFImporter 1.6 (???) /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter 0x897e000 - 0x897efff net.nemetschek.vectorworks.SectionLine ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/SectionLine.vwobject/Contents/MacOS/SectionLine 0x89d3000 - 0x8a37fff com.DivXInc.DivXDecoder 6.6.0 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder 0x8ae2000 - 0x8ae2fff net.nemetschek.vectorworks.fittoobjects ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Fit To Objects.vwplugin/Contents/MacOS/Fit To Objects 0x8ae5000 - 0x8af0fff net.nemetschek.vectorworks.aligndistribute ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/AlignDistribute.vwlibrary/Contents/MacOS/AlignDistribute 0x8afb000 - 0x8afcfff net.nemetschek.vectorworks.vwlibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/VWLibrary.vwlibrary/Contents/MacOS/VWLibrary 0x8c05000 - 0x8e3efff net.telestream.wmv.import 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import 0x8e74000 - 0x9028fff net.telestream.wmv.advanced 2.2.0.49 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced 0x906a000 - 0x90a9fff com.apple.QuickTimeFireWireDV.component 7.5 (861) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV 0x90b4000 - 0x912efff com.apple.applepixletvideo 1.2.16 (1.2d16) /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo 0x9282000 - 0x92befff net.nemetschek.vectorworks.ColorPalettes ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ColorPalettes.vwlibrary/Contents/MacOS/ColorPalettes 0x92f4000 - 0x933bfff net.nemetschek.vectorworks.DTM6InterfaceLibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6InterfaceLibrary.vwlibrary/Contents/MacOS/DTM6InterfaceLibrary 0x9376000 - 0x9557fff net.nemetschek.vectorworks.DWG Library ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DWG Library.vwlibrary/Contents/MacOS/DWG Library 0x9667000 - 0x966ffff net.nemetschek.vectorworks.editshader ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/EditShader.vwlibrary/Contents/MacOS/EditShader 0x9675000 - 0x9683fff net.nemetschek.VectorWorks.ExtendedProperties ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ExtendedProperties.vwlibrary/Contents/MacOS/ExtendedProperties 0x9694000 - 0x9713fff >net.nemetschek.vectorworks.GeometryLib ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/GeometryLib.vwlibrary/Contents/MacOS/GeometryLib 0x976d000 - 0x9865fff net.nemetschek.vectorworks.IFCLibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCLibrary.vwlibrary/Contents/MacOS/IFCLibrary 0x998b000 - 0x9992fff net.nemetschek.vectorworks.PDFUtilityLib ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/PDFUtilityLib.vwlibrary/Contents/MacOS/PDFUtilityLib 0x9999000 - 0x9a59fff DL61ACE /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61ACE.framework/Versions/A/DL61ACE 0x9aaa000 - 0x9adefff net.nemetschek.vectorworks.Plant Library ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Plant Library.vwlibrary/Contents/MacOS/Plant Library 0x9b11000 - 0x9b14fff com.yourcompany.Plug-InSupport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Plug-In Support.vwlibrary/Contents/MacOS/Plug-In Support 0x9b19000 - 0x9b1cfff net.nemetschek.vectorworks.rendersettings ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/RenderSettings.vwlibrary/Contents/MacOS/RenderSettings 0x9b21000 - 0x9b28fff net.nemetschek.vectorworks.TrueType ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TrueType.vwlibrary/Contents/MacOS/TrueType 0x9b2f000 - 0x9b87fff net.nemetschek.vectorworks.VectorScriptEditor ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/VectorScriptEditor.vwlibrary/Contents/MacOS/VectorScriptEditor 0x9c40000 - 0x9c46fff net.nemetschek.vectorworks.VSSharedLibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/VS Shared Library.vwlibrary/Contents/MacOS/VS Shared Library 0x9c4d000 - 0x9c8afff net.nemetschek.vectorworks.VCOM Provider Library ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Workspaces.vwlibrary/Contents/MacOS/Workspaces 0x9cd7000 - 0x9f74fff net.nemetschek.vectorworks.xmllibrary ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/XML Library.vwlibrary/Contents/MacOS/XML Library 0xa10a000 - 0xa10cfff com.apple.textencoding.unicode 2.0 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings 0xa12f000 - 0xa137fff net.nemetschek.vectorworks.ceilinggrid ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/CeilingGrid.vwobject/Contents/MacOS/CeilingGrid 0xa141000 - 0xa142fff com.yourcompany.DesignLayerViewport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DesignLayerViewport.vwobject/Contents/MacOS/DesignLayerViewport 0xa147000 - 0xa14dfff net.nemetschek.vectorworks.extrudealongpath ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ExtrudeAlongPath.vwobject/Contents/MacOS/ExtrudeAlongPath 0xa18b000 - 0xa1adfff com.yourcompany.ChainDimension ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ChainDimension.vwobject/Contents/MacOS/ChainDimension 0xa1bb000 - 0xa1c0fff net.nemetschek.vectoworks.helixspiral ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/HelixSpiral.vwobject/Contents/MacOS/HelixSpiral 0xa1c6000 - 0xa1cefff com.yourcompany.PDFPage ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/PDFPage.vwobject/Contents/MacOS/PDFPage 0xa1d6000 - 0xa1e8fff net.nemetschek.vectorworks.TaperedExtrude ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TaperedExtrude.vwobject/Contents/MacOS/TaperedExtrude 0xa1f1000 - 0xa1f6fff net.nemetschek.vectorworks.TextAlongPath ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TextAlongPath.vwobject/Contents/MacOS/TextAlongPath 0xa305000 - 0xa345fff net.nemetschek.vectorworks.Callout ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Callout.vwobject/Contents/MacOS/Callout 0xa388000 - 0xa3effff net.nemetschek.vectorworks.DTM6 Object Snapshot ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6 Object Snapshot.vwobject/Contents/MacOS/DTM6 Object Snapshot 0xa432000 - 0xa4b4fff net.nemetschek.vectorworks.DTM6 Object ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6 Object.vwobject/Contents/MacOS/DTM6 Object 0xa50b000 - 0xa531fff net.nemetschek.vectorworks.FramingMember ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/FramingMember.vwobject/Contents/MacOS/FramingMember 0xa552000 - 0xa58bfff net.nemetschek.vectorworks.General Notes ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/General Notes.vwobject/Contents/MacOS/General Notes 0xa5ca000 - 0xa639fff net.nemetschek.vectorworks.HumanFigure ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/HumanFigure.vwobject/Contents/MacOS/HumanFigure 0xa67d000 - 0xa694fff net.nemetschek.vectorworks.IFCEntity ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCEntity.vwobject/Contents/MacOS/IFCEntity 0xa6bd000 - 0xa6f2fff net.nemetschek.vectorworks.Keynote Legend ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Keynote Legend.vwobject/Contents/MacOS/Keynote Legend 0xa72d000 - 0xa76bfff net.nemetschek.vectorworks.Plant Object ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Plant Object.vwobject/Contents/MacOS/Plant Object 0xa7a0000 - 0xa7ecfff net.nemetschek.vectorworks.Space ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Space.vwobject/Contents/MacOS/Space 0xa836000 - 0xa83bfff net.nemetschek.vectorworks.TexturedProp ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Textured Prop.vwobject/Contents/MacOS/Textured Prop 0xa8cd000 - 0xa8cffff net.nemetschek.vectorworks.movepage ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/MovePage.vwplugin/Contents/MacOS/MovePage 0xa9f5000 - 0xa9f7fff net.nemetschek.vectorworks.TapeMeasureTool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TapeMeasureTool.vwplugin/Contents/MacOS/TapeMeasureTool 0xa9fc000 - 0xa9fdfff net.nemetschek.vectorworks.alignlayerviews ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/AlignLayerViews.vwplugin/Contents/MacOS/AlignLayerViews 0xacf2000 - 0xacf5fff net.nemetschek.vectorworks.Trim ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Trim Tool.vwplugin/Contents/MacOS/Trim Tool 0xae5a000 - 0xae68fff net.nemetschek.vectorworks.eyedropper ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Eyedropper Tool.vwplugin/Contents/MacOS/Eyedropper Tool 0xae73000 - 0xae76fff net.nemetschek.vectorworks.Shear ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Shear.vwplugin/Contents/MacOS/Shear 0xae7b000 - 0xae7efff net.nemetschek.vectorworks.protractortool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Protractor Tool.vwplugin/Contents/MacOS/Protractor Tool 0xaefa000 - 0xaefcfff net.nemetschek.vectorworks.guides ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Guides.vwplugin/Contents/MacOS/Guides 0xb0e2000 - 0xb127fff net.nemetschek.vectorworks.delMeTool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Callout Tool.vwplugin/Contents/MacOS/Callout Tool 0xb16f000 - 0xb183fff net.nemetschek.vectorworks.offsettool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Offset Tool.vwplugin/Contents/MacOS/Offset Tool 0xb18e000 - 0xb192fff net.nemetschek.vectorworks.resize ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Resize.vwplugin/Contents/MacOS/Resize 0xb197000 - 0xb19bfff net.nemetschek.vectorworks.TaperedExtrudeMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TaperedExtrudeMenu.vwplugin/Contents/MacOS/TaperedExtrudeMenu 0xb1a2000 - 0xb1a8fff net.nemetschek.vectorworks.duplicatesymbolinwall ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Duplicate Symbol In Wall.vwplugin/Contents/MacOS/Duplicate Symbol In Wall 0xb1c4000 - 0xb1c7fff net.nemetschek.vectorworks.IFCImport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCImport.vwplugin/Contents/MacOS/IFCImport 0xb1d0000 - 0xb1d6fff net.nemetschek.vectorworks.SunPosition ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/SunPosition.vwplugin/Contents/MacOS/SunPosition 0xb1dd000 - 0xb1e7fff net.nemetschek.vectorworks.extrudealongpathmenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/ExtrudeAlongPathMenu.vwplugin/Contents/MacOS/ExtrudeAlongPathMenu 0xb1f0000 - 0xb1f6fff net.nemetschek.vectorworks.helixspiralmenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/HelixSpiralMenu.vwplugin/Contents/MacOS/HelixSpiralMenu 0xb305000 - 0xb350fff net.nemetschek.vectorworks.Space Tool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Space Tool.vwplugin/Contents/MacOS/Space Tool 0xb39d000 - 0xb3dcfff net.nemetschek.vectorworks.General Notes Tool ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/General Notes Tool.vwplugin/Contents/MacOS/General Notes Tool 0xb423000 - 0xb44dfff net.nemetschek.vectorworks.Export3DSMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/3DS Import.vwplugin/Contents/MacOS/3DS Import 0xb480000 - 0xb4a7fff net.nemetschek.vectorworks.Export3DSMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/3DS Export.vwplugin/Contents/MacOS/3DS Export 0xb4d9000 - 0xb4e3fff net.nemetschek.vectorworks.exportquicktimemovie ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Export Quicktime Movie.vwplugin/Contents/MacOS/Export Quicktime Movie 0xb4ed000 - 0xb4f0fff net.nemetschek.vectorworks.obitanimator ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Orbit Animator.vwplugin/Contents/MacOS/Orbit Animator 0xb4f5000 - 0xb4f7fff net.nemetschek.vectorworks.TrueTypeToPolyline ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TrueType To Polyline.vwplugin/Contents/MacOS/TrueType To Polyline 0xb605000 - 0xb660fff net.nemetschek.vectorworks.SU2VW ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/SU2VW.vwplugin/Contents/MacOS/SU2VW 0xb6dd000 - 0xb920fff Xerces /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces 0xbb74000 - 0xbb91fff net.nemetschek.vectorworks.pathanimator ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Path Animator.vwplugin/Contents/MacOS/Path Animator 0xbba4000 - 0xbbabfff net.nemetschek.vectorworks.roofer ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Roofer.vwplugin/Contents/MacOS/Roofer 0xbbb2000 - 0xbbcafff net.nemetschek.vectorworks.FitWallsToRoof ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/FitWallsToRoof.vwplugin/Contents/MacOS/FitWallsToRoof 0xbbf5000 - 0xbc1efff net.nemetschek.vectorworks.Space Menu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Space Menu.vwplugin/Contents/MacOS/Space Menu 0xbc4b000 - 0xbc93fff >net.nemetschek.vectorworks.RoofFramer ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/RoofFramer.vwplugin/Contents/MacOS/RoofFramer 0xbcda000 - 0xbce3fff net.nemetschek.vectorworks.purge ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Purge.vwplugin/Contents/MacOS/Purge 0xbcea000 - 0xbd78fff net.nemetschek.vectorworks.WorkspaceEditor ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Workspace Editor.vwplugin/Contents/MacOS/Workspace Editor 0xbe77000 - 0xbea0fff net.nemetschek.vectorworks.checkspelling ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/CheckSpelling.vwplugin/Contents/MacOS/CheckSpelling 0xbeaf000 - 0xbeb9fff com.yourcompany.TextAlongPathMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/TextAlongPathMenu.vwplugin/Contents/MacOS/TextAlongPathMenu 0xbec2000 - 0xbf08fff net.nemetschek.vectorworks.Notes Manager Menu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/Notes Manager Menu.vwplugin/Contents/MacOS/Notes Manager Menu 0xbf56000 - 0xbf6efff net.nemetschek.vectorworks.IFCMenu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCMenu.vwplugin/Contents/MacOS/IFCMenu 0xbf97000 - 0xc013fff net.nemetschek.vectorworks.DTM6 Menu ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/DTM6 Menu.vwplugin/Contents/MacOS/DTM6 Menu 0xc067000 - 0xc06afff net.nemetschek.vectorworks.IFCExport ??? (1.0) /Applications/VectorWorks 2008/Plug-Ins/IFCExport.vwplugin/Contents/MacOS/IFCExport 0xcc2d000 - 0xcc2efff com.apple.aoa.halplugin 2.5.6 (2.5.6b5) /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin 0xf829000 - 0xf862fff com.apple.audio.SoundManager.Components 3.9.1 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents 0x11000000 - 0x11366fff SketchUpReader /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/SketchUpReader.framework/Versions/A/SketchUpReader 0x70000000 - 0x700fdfff com.apple.audio.units.Components 1.4.7 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio 0x8f4f0000 - 0x8f4f5fff com.apple.CoreMediaAuthoringPrivate 1.4 /System/Library/PrivateFrameworks/CoreMediaAuthoringPrivate.framework/Versions/A/CoreMediaAuthoringPrivate 0x8f760000 - 0x8f7a1fff com.apple.CoreMediaIOServicesPrivate 9.0 /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate 0x8f840000 - 0x8f86efff com.apple.CoreMediaPrivate 9.0 /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate 0x8f8c0000 - 0x8f961fff com.apple.QuickTimeImporters.component 7.5 (861) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters 0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld 0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib 0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib 0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.78 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib 0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib 0x90aea000 - 0x90b5afff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x90b70000 - 0x90b82fff libauto.dylib /usr/lib/libauto.dylib 0x90b89000 - 0x90e60fff com.apple.CoreServices.CarbonCore 681.17 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x90ec6000 - 0x90f46fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x90f90000 - 0x90fd2fff com.apple.CFNetwork 4.0 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x90fe7000 - 0x90ffffff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore 0x9100f000 - 0x91090fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x910d6000 - 0x91100fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x91111000 - 0x9111ffff libz.1.dylib /usr/lib/libz.1.dylib 0x91122000 - 0x912ddfff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x913dc000 - 0x913e5fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x913ec000 - 0x913f4fff libbsm.dylib /usr/lib/libbsm.dylib 0x913f8000 - 0x91420fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x91433000 - 0x9143efff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib 0x91443000 - 0x914befff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x914fb000 - 0x914fbfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x914fd000 - 0x91535fff com.apple.AE 1.5 (297) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x91550000 - 0x91622fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x91675000 - 0x91706fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x9174d000 - 0x91804fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x91841000 - 0x9189ffff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x918ce000 - 0x918f2fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x91906000 - 0x9192bfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent 0x9193e000 - 0x91980fff com.apple.LaunchServices 183 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x9199c000 - 0x919b0fff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x919be000 - 0x91a04fff com.apple.ImageIO.framework 1.5.7 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x91a1b000 - 0x91ae2fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib 0x91b30000 - 0x91b45fff libcups.2.dylib /usr/lib/libcups.2.dylib 0x91b4a000 - 0x91b68fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x91b6e000 - 0x91c25fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x91c74000 - 0x91c78fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x91c7a000 - 0x91ce4fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib 0x91ce9000 - 0x91d26fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x91d2d000 - 0x91d47fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x91d4c000 - 0x91d4ffff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x91d51000 - 0x91e3ffff libxml2.2.dylib /usr/lib/libxml2.2.dylib 0x91e5e000 - 0x91e5efff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x91e60000 - 0x91f45fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x91f4d000 - 0x91f6cfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x91fd8000 - 0x92046fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x92051000 - 0x920e6fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x92100000 - 0x92688fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x926bb000 - 0x929e6fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x92a16000 - 0x92b04fff libiconv.2.dylib /usr/lib/libiconv.2.dylib 0x92b07000 - 0x92b8ffff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x92bd0000 - 0x92dfbfff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x92f28000 - 0x92f46fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x92f51000 - 0x92fabfff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x92fc9000 - 0x92fc9fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x92fcb000 - 0x92fdffff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x92ff7000 - 0x93007fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x93013000 - 0x93028fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x9303a000 - 0x930c1fff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x930d5000 - 0x930e0fff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x930ea000 - 0x93117fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x93131000 - 0x93141fff com.apple.print.framework.Print 5.0 (190.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x9314d000 - 0x931b3fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x931e4000 - 0x93233fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x93261000 - 0x9327efff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x93290000 - 0x9329dfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x932a6000 - 0x935b4fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x93704000 - 0x93710fff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x93789000 - 0x93789fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x9378b000 - 0x93dbefff com.apple.AppKit 6.4.10 (824.48) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x9414b000 - 0x941bdfff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x941f6000 - 0x942bbfff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x9430e000 - 0x9430efff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x94310000 - 0x944d0fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x9451a000 - 0x94557fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib 0x9455f000 - 0x945affff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x945b8000 - 0x945d3fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x945e4000 - 0x94604fff libmx.A.dylib /usr/lib/libmx.A.dylib 0x947a7000 - 0x947b6fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib 0x947be000 - 0x947cbfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x94811000 - 0x9482afff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x94831000 - 0x94b5dfff com.apple.QuickTime 7.5.0 (861) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x94c44000 - 0x94cb5fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib 0x9508b000 - 0x950a8fff libresolv.9.dylib /usr/lib/libresolv.9.dylib 0x965aa000 - 0x96651fff com.apple.QTKit 7.5 (861) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit 0x96c5a000 - 0x96c70fff libJapaneseConverter.dylib /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib 0x96c72000 - 0x96c92fff libKoreanConverter.dylib /System/Library/CoreServices/Encodings/libKoreanConverter.dylib 0x96ca0000 - 0x96caefff libSimplifiedChineseConverter.dylib /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib 0x96cb6000 - 0x96cc9fff libTraditionalChineseConverter.dylib /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib 0x97682000 - 0x976a1fff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x97db8000 - 0x97e79fff libGLProgrammability.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x97ea4000 - 0x97ea5fff libGLSystem.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLSystem.dylib 0x97ea7000 - 0x97eb4fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x992be000 - 0x9a0d9fff com.apple.QuickTimeComponents.component 7.5 (861) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents 0x9a33e000 - 0x9a342fff com.apple.QuickTimeH264.component 7.5 (861) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264 0x9a5ec000 - 0x9a6bcfff com.apple.QuickTimeMPEG4.component 7.5 (861) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4 0x9aff2000 - 0x9b010fff com.apple.OpenTransport 2.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport 0xc0000000 - 0xc000ffff com.unsanity.ape 2.0.3 /Library/Frameworks/ApplicationEnhancer.framework/Versions/A/ApplicationEnhancer 0xc0200000 - 0xc0413fff DL61AGM /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61AGM.framework/Versions/A/DL61AGM 0xc0700000 - 0xc0734fff DL61ARE /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61ARE.framework/Versions/A/DL61ARE 0xc0780000 - 0xc079efff DL61BIB /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61BIB.framework/Versions/A/DL61BIB 0xc07e0000 - 0xc0805fff DL61BIBUtils /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61BIBUtils.framework/Versions/A/DL61BIBUtils 0xc0850000 - 0xc0af5fff DL61CoolType /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61CoolType.framework/Versions/A/DL61CoolType 0xc0d50000 - 0xc0df9fff DL61JP2K /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61JP2K.framework/Versions/A/DL61JP2K 0xc0e40000 - 0xc0ee9fff DL61XMP /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61XMP.framework/Versions/A/DL61XMP 0xc1040000 - 0xc155bfff DL61PDFL /Applications/VectorWorks 2008/VectorWorks 2008.app/Contents/Frameworks/DL61PDFL.framework/Versions/A/DL61PDFL Model: PowerMac3,5, BootROM 4.2.5f1, 1 processors, PowerPC G4 (0.0), 1.8 GHz, 1 GB Graphics: NVIDIA GeForce4 Ti, GeForce4 Ti 4600, AGP, 128 MB Memory Module: DIMM0/J21, 512 MB, SDRAM, PC133-322 Memory Module: DIMM1/J22, 256 MB, SDRAM, PC133-333 Memory Module: DIMM2/J23, 256 MB, SDRAM, PC133-333 Modem: Spring, UCJ, V.90, 7.0F, APPLE VERSION 0007, 7/31/2000 Network Service: Built-in Ethernet, Ethernet, en0 PCI Card: SeriTek/1S2 v. 5.1.3,11/22/05, 23:47:18, ata, SLOT-4 Parallel ATA Device: ST360021A, 57.27 GB Parallel ATA Device: PIONEER DVD-RW DVR-103 USB Device: Hub, Up to 12 Mb/sec, 500 mA USB Device: HP Color Inkjet CP1700, Hewlett-Packard, Up to 12 Mb/sec, 500 mA USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA USB Device: USB Receiver, Logitech, Up to 1.5 Mb/sec, 500 mA Thanks, Bruce
  5. I'm trying to create viewports that duplicate sheets in another file via referenced viewport, but find I can only show the design layers and not the annotations residing on sheet layer. Can this be done? Thanks
  6. I'm having a hard time locating textures in the VW2008 files - any suggestions as to where I should look?
  7. Bruce F
    Wall textures
    I'm having trouble finding wall texture resources. Can anyone point me towards them?
  8. Now I'm unable to get transparent glazing at sidelights and transoms of doors...any workarounds here?
  9. Just noticed my elevations are not showing french doors w/ transoms having clear glazing and there is no such settings options, while the window PIOs have glazing options in the settings. Am I missing something? Thanks
  10. If you look at #99611 you can see where I tried this, but the wall won't come down between the arches...
  11. I still get jamb planes that won't go away in plan or 3D using this logic. It does seem like it would work though. Maybe because they're more door-like. I've gone through all the door PIO options for visibility and the jamb line won't go away, with or without a gap-cutter(I tried one for the full 10'8" opening up to springline, and then get a header plane lind as well)...See attached for the conundrum
  12. I wish it would...The caps won't go away no matter what. I made what I want (attached) but it's no longer a wall but a 3D solid with an extrude for the column (that will not render solid in one strip of the column no matter what I do - using Renderworks final shaded). So I'm stuck not being able to get walls to act right. Thanks for trying Pat.
