I have just sent a Vectorworks file, saved as a PDF to an outside printer via email.
I was dissapointed with the print returned to me in regards to line weights.
Thin lines 0.2mm and less looked more like 0.3mm, all other line thickness and shading were ok.
Is this a problem with PDF or perhaps the printer?
Any ideas please - thanks
Ray
Thanks for the prompt response Peter and Kevin.
Peter if all else fails I will try a router.
Kevin, I followed the link you gave me and will try the instructions when I go back to the office.
thanks . . . . Ray
Need help getting my plotter to print. I've downloaded the gimp driver and I can select it. The plotter is connected to the directjet connected to the computer via ethernet crossover cable. No network.
In the printer list: what item do I select?: advanced, appletalk, etc.
I would like to be able to print directly from the computer.
thanks . . . . Ray
