Charlie M
    7
Reputation
0 Neutral
Personal Information
  • Location
    NJ
  1. One method I have used is to create a new layer and link your plan onto the new layer. then set the layer opacity to about 60%. The printers handle this gray much better than setting the layer as gray and you don't need to worry about turning layer colors on and messing up the rest of your file.
  2. Thanks for the info... Has anyone had any issues with the "Graphite" family of fonts?
  3. I found that you need to set the line attributes to none, and then the part line styles of the doors and windows will show up correctly.
  4. Anyone else having issue with this font in 12.5? It worked fine in 12, but now it is adding spaces anytime you use a " when typing 5'-0" for example.
  5. Anyone else notice that with 12.5 the "Part Line Style" feature to doors no longer works and the door parts all have the same lineweight?
  6. I posted this in the Architect forum, but maybe it will get a bit more exposure here. I just created a titleblock and linked all my text to the correct record, and added some extra fields. Those fields won't show up in the Issue Manager, so I assume the record fields aren't linked to the issue manager so you can't add or delete fields. Is there a way to add fields and they can be used through the issue manager? Thanks.
  7. I just created a titleblock and linked all my text to the correct record, and added some extra fields. Those fields won't show up in the Issue Manager, so I assume the record fields aren't linked to the issue manager so you can't add or delete fields. Is there a way to add fields and they can be used through the issue manager? Thanks.
