Stephan Moenninghoff
  • Content Count
    767
Posts posted by Stephan Moenninghoff
  1. You need to check "Ridimensiona oggetto" and then make it stretch. You don't need to use a Marionette any more for this, did you know? You can use two rod bearings (as blue symbols) and an extrude (also a blue symbol) and interiorcad will reshape the extrude to fit the width. No clothes and no clothes hangers (yet), obviously...
    • Like 1
  2. 2 hours ago, Daisy Y said:
    Thanks Nicolas! The first point helps a little, it lets me edit the frame that goes round the outside but it doesn't allow me to create a detail style of door I can apply to different units (ie, with mini sub rails that divide up the door creating a sort of grid look over the door). Perhaps this isn't a possible feature available yet?
    Can you show us what you have in mind? Maybe we can integrate it or maybe you can already do it.
  3. 10 minutes ago, Daisy Y said:
    @Stephan Moenninghoff Thank you for the previous reply! I'm having another issue, I'm saving symbols within symbols (ie. the symbol of a drawer type within the symbol of a full cabinet) and when I close my program and reopen the file it has converted the symbols (drawers) within the main symbol (cabinet) into a group and so lost its symbol nature and ability to edit symbol capabilities. I'm also getting this error message when opening the file, " Some object connections are broken in the current document" , asking me to repair items. I'm not sure why this message is appearing or if it's anything to do with my symbol-within-symbol issue.
    That's interesting. I don't think converting drawers into symbols is a good idea, they need to live inside the main symbol as groups/plugin objects. You can attach the file here if you like and I will have someone take a look.
  4. 21 hours ago, Daisy Y said:
    @Stephan Moenninghoff I want to use a leg on my cabinets that isn't in the standard library of parts that came with the software. How do I go about adding this? The leg is a Hafele part that comes as a foot shaft and foot plug top.
    Links to the parts here:
    https://www.hafele.ie/en/product/plinth-foot-top-section-m10-screw-through-mounting/000000fb0003ab5f00020023/
    https://www.hafele.ie/en/product/foot-and-shaft-section-for-adjustable-plinth-feet-plastic/63796331/?MasterSKU=0000001c0001b63f00020023
    Will I need to model something up myself to represent these and then add that as a part in my part library? Or is there a place to download this product and upload it into my library?
    Hi Daisy, it's easily possible with interiorcad's built-in "Edit / Adapt Fitting Libraries" command. Go to interiorcad and then Fittings:
    From the next dialog, you choose feet and mounting plates (and, if required, accessories and / or glides).
    When you choose each command for the first time, interiorcad will create a new document with a sample fitting. When you save it, it will be placed in your user folder ( /Users/<your user name>/Library/Application Support/Vectorworks/2021/Libraries/Defaults/Custom Part/Leg Feet/Leg Feet - Custom.vwx) or, if you're on Windows in C:\Users\<your user name>\AppData\Roaming\Nemetschek\Vectorworks\2021\Libraries\Defaults\Custom Part\Leg Feet\Leg Feet - Custom.vwx (or Leg Mounting Plates). Edit the sample fitting geometry and replace the sample geometry with your own geometry. Add drillings if required. make sure you don't ungroup anything. Work inside the groups because there are Vectorworks Record Formats attached to the enclosing groups. If you do it like that you'll be fine. If it does not work, which is to be expected, because it never works the first time around, 😁 , upload what you tried here (the documents from your user folder) and I will have a look.
  5. Just now, Nicolas Goutte said:
    Not quite: group and thickness together must be unique.
    Only if you use the dialog (in the full version), right? I have found that using the spreadsheet it can be duplicated. Anyway, best to play it safe and not have a duplicate combination there. What I meant to say was: You can put anything in there. That column is not used for the current system any more. it is a legacy field.
  6. 1 minute ago, Ash said:
    I understand the need to add my first line. I just can do not have a clue how Texture and new material name is read by the program. I do not see my new line in the pop-up menu for materials and types. Please see attached and advise.
    1955757185_ScreenShot2021-01-27at12_45_14AM.thumb.jpg.289dbab3b828a8cba31f28797facf839.jpg
    Texture is the name of the Renderworks texture. The material name is in the first columns, under #Item-No. Thickness is also important because it will govern the physical thickness of each material in the model. You can ignore Group.
  7. 6 hours ago, Boh said:
    Thanks Stephan. Is there anything I can do to stop it? We don't use Interiorcad enough to warrant these classes popping up in every file. Cheers.
    We use these classes to create the grid surfaces between custom parts when we place fittings. Obviously, with most fittings, they go *between* two custom parts, so if we kept the custom parts visible, you wouldn't be able to place the fittings. These classes create the blue grids and at the same time grey out the parts proper. Users have got quite creative in the past with these classes, renaming them, making them visible, giving them different attributes etc. This could break the function, so we are creating these classes from scratch every time a new document is opened.
  8. Great example and -finally- fully supported by interiorcad 2021. I have set a frame up for you with a standard pre-supplied profile. You can find the profile now in your document under interiorcad > profiles. It is not a plain profile yet. You need to edit the 2D component of the profile and change the polyline to become square instead of profiled, whilst keeping the dado. You need to edit both the profile and the counter profile (the one with the - C suffix). You NEVER use the counter profile. It is used by interiorcad automatically when you set the joint for stile and rail to "counter profile".
    You can add the profile to your user folder. We will soon add it to the dialog under interiorcad > Fittings > Edit / Adapt Fittings Library but it already works if you go through the Finder / Explorer.
    Let me know if this works for you!
  9. 10 hours ago, mgebel said:
    I am assuming that the InteriorCAD algorithm is dropping the bezier due to the lack of universal support for bezier curves in many WOPs?
    That's the issue here. CNC equipment expects only arcs and corner vertices. This is the same across the board, from the smallest model-building CNC to large nesting CNCs in the furniture industry. interiorcad automatically converts beziers to arcs when a custom part is created from a curve. If you want higher fidelity, your best strategy is to draw the primitive again, using only arcs and corner vertices.
  10. Excellent summary of board types, @mgebel.
    To add  to that:- there are seven board types with only three different patterns.
    1. Solid type
      1. Solid Wood
      2. Glass
      3. Plywood
      4. Laminated Wood
    2. Composite type
      1. Melamin Faced
      2. Veneered
    3. Standard
    1. The first group can not receive edge banding or any covering at all but has variable thickness. This means you can adjust the thickness of these materials in the OIP.
    2. The second group receives edge banding but not coverings. You should not set the thickness of the coverings to 0 in the Master Data setup because it will not render well. Any thickness you assign to a covering will not be added on to the material (as @mgebel already pointed out) so, give it at least 0.1 of a mm.
    3. Standard Materials like chipboard or mdf expect to be either edge-banded or coated or covered/veneered. All coverings will add their assigned thickness to the total thickness of the finished material. So, if you have an 18mm board and you add on 0.5mm on both sides, you end up with 19mm finished thickness.
    @Habitat43 you do not need to go to such lenghts if you want to simply explode a cabinet object. Just ungroup the cabinet. The first ungroup will decompose the cabinet into custom parts. All custom parts are still intact and can be assigned a material, edge banding, fittings etc. They cannot be reshaped as a cabinet any more, that's all. This is a great way to overcome any limitations of the cabinet object without destroying cutting list or cnc information. If you want to go further, first make sue that "3D Details" is disabled for the cabinet in the OIP before you ungroup the top level cabinet (because that will get rid of all physical representations of coverings and edge bandings.). Then, ungroup and then, ungroup again. You end up with generic solids that can be easily textured (but have no meta-information any more)
    A more recommended workflow is to use the Search and Replace command in the cabinet dialog which you can apply to just textures, ignoring the material data .The Search dialog will automatically list all materials and textures that are being used for the edited cabinet.There is also a standalone command unter the interiorcad menu to search and replace all cabinets in the document. That's even faster than decomposing  and manually assigning the textures.
  11. 56 minutes ago, Habitat43 said:
    @Stephan Moenninghoff hello! Asking for a quick advice. What would it be the easiest and fastest way to change the texture of a cabinet? Thanks!!
    Textures and materials are one entity in interiorcad. Each material has a texture and a thickness assigned to it as well as a 'material type' So, we discriminate between  melamin faced, solid wood, raw, etc.
    In order to change a texture, you must define the texture for the material used for construction. This is necessary to ensure that cutting lists are always up-to-date and no material can be assigned that is either anonymous or has the wrong constructive thickness. Go to interiorcad -> Master Data -> Boards and define your materials there. Likewise for edge banding and coverings/veneers.
    On a second note we do realise that we are thinking too much like a joiner/cabinet maker rather than a designer and we think a future version might support double-clicking a texture in the Resource Manager and just pouring that texture over the entire cabinet, even before a proper material gets assigned. This is very much an experimental idea tough and not guaranteed to be implemented.
  12. 2 minutes ago, Habitat43 said:
    If you put it in social media would be nice if you could tag me
    Of course. Let me have your social media links please!
    Quick question, I'm doing the crown moulding using the extrude along path, do you think is an easier way to do it?
    That is fine but maybe you are not using the EAP to its full potential in this case? You can convert the path to a NURBS before you start and then place a working plane at the end. You can actually click on the end point of a NURBS curve with the WP tool and the WP will be placed perpendicular to the path. Then, you draw your profile on the WP and when you perform the extrusion, you check "Fix Profile".
    • Like 4
