1,330 -
Everything posted by Stephan Moenninghoff
You were on the right track. I don't think you need to do much sorting because the duplicates are all created in order. You need to target the relevant circles' indices. Each index is a poly vertex. Try the "every other" node.
- 8 replies
- marionette
- lists
(and 1 more)
Tagged with:
help developing production drawings for counter.
Stephan Moenninghoff replied to Bruno Sá's topic in Solids Modeling
Loft is your best bet. try creating the end top corners as lines, join using a NURBS curve and then shell to get the thickness. If you're going to send this to a CNC, stay clear of any Subdivision modelling as that will not give you the right type of NURBS surface in the end. You must use solids to create this. -
Multiple tabs open, original tab not responding
Stephan Moenninghoff replied to MartinFahrer's question in Troubleshooting
Just to add my 2c, I am seeing this issue regularly on clients' machines. I think it is Windows only. The saving issue appears to be such that the inactive tab is saved instead of the current tab. -
False/inverted colours rendered from RW background
Stephan Moenninghoff posted a question in Troubleshooting
Has anyone come across this? This is PC only. Re-rendering on Mac will create the background just fine. Image compression is set to PNG already so it can't be that. Nothing we do reverts this. I am seeing this on several clients' machines. I'm also logging this as a bug but if anything transpires here, I want to be able to use it as reference. Thanks for comments! test Visualisierung2.vwx -
Version 1.2
263 downloads
Features: Creates a two-dimensional dovetail detail using the standard method for dovetail joints. Available in German and English. Both objects inside the file. Known Issues: Go easy on the sliders! I haven't had the time to build in the appropriate safety-nets. Lousy bit of Marionetteering on my part here but there have been a few requests from local users and it works pretty well if you don't overdo it with the dimensions. -
JFYI interiorcad has an SVG export for 3D parts. Here's the "V" in interiorcad and as an SVG-file. The SVG has the routing contours inside the pockets, that's why the V is striped. We usually need it to export graphical information of 3D parts to third party software, in case it is needed. %22V%22.vwx Bauteil1_Haupt.svg.zip
user folder in dropbox/cloud?
Stephan Moenninghoff replied to grant_PD's topic in General Discussion
One more word on this: if two resources/files/plug-ins with the same name exist in both your user folder and your WGF, VWX will first pull resources from your user folder, then your WGF. So, you need to make sure that you save new template files, resources or plug-ins to the WGF and delete those files from your user folder. -
Do not put your user folder in the DropBox. It will mess up activation and cause other issues. Use a workgroup folder for what you want. I have the same setup and sync all my settings, templates and other VWX-related resources in the WGF, which lives in my DropBox. It works flawlessly. HTH. -
Version 1.3
417 downloads
No need to keep different size TV symbols any more with this handy Marionette. The screen image is adjusted automatically to the size of the screen and standard screen sizes can be chosen from a popup-menu. Features: Generates a TV set at standard sizes or at a user-defined custom size The "Automatic Size" option will fit the maximum available size into the given Box ("Shelf"). Choose from different Images to be shown on screen Add a frame in black gloss or aluminium Option to use surround light (aka "Ambilight") Wall mounted (centre of box) or free standing Can be used inside an interiorcad cabinet and will automatically adjust its size to the available space inside its box -
I really like having the Valve but I needs it to be smarter. Could an option be added that portions of networks joining after the Valve are not affected? The Valve currently disables too much and could be used much more often if this was possible: In this case I want the dialog to pop up only if the valve before it has been enabled. Currently, the Valve kills my entire network downstram of it. Is that necessary? Could the Valve please also disable controls in the OIP? If a control comes after a Valve, this would be an elegant way of hiding it. Thank you!
Ah, I like a good modelling challenge. Here's another take. Hope it helps! Knife.mp4
Why does my section viewport render like this?
Stephan Moenninghoff replied to jtempleton's question in Troubleshooting
@jtempleton did you extrude open polygons or polylines to make objects? They can cause this. -
Renders Turning Black Once Updated
Stephan Moenninghoff replied to corbinhand's question in Known Issues
@Jim Wilson I think it's gone. I haven't seen it since SP2. Thanks! -
Yes, only the mapping.
Think so. It's been a while. I had a quick look inside the wrapper and it looks like this: Feed the values in according to the node description. You may have to string several of these together.
@Nuno Antunessee my reply to this thread, it has an object attached with some texture manipulation that should answer all your questions:
@Nuno Antunescheck out my Box objects. I am resizing the texture to fit to the lid for example. Does this help? Box.vwx
VW 2020 Suggestions
Stephan Moenninghoff replied to taoist's question in Wishlist - Feature and Content Requests
I can only comment on the auto-cutout for countertop wish: That is entirely possible with the full version of interiorcad. You can group a routing contour with a sink symbol and have it behave like a window in a wall: Cutout.mp4 -
Cabinet Drawers
Stephan Moenninghoff replied to khumenny's topic in Wishes Granted / Issues Resolved
Is this the "Custom Cabinet" you are referring to? You can click inside a segment and adjust its size as shown in the screen shot.There are more advanced options in the full-blown version of interiorcad. Some videos here.
