81 -
Everything posted by ashot
Thank you everyone. So the Final Answer for this question: for the Text field in Worksheet the "decimal numbers in worksheets have a precision of max 13 digits. and that the number of digits in the Text field is the Total number of all digits referenced from the numerical field, including all decimal places (whole part + fraction part).
Does anyone know if Text in Worksheet Cell has a limitation for the length when it shows digits? @Pat Stanford Please see attached VW file. In my project I need to read Latitude and Longitude of my stakes in two different columns formatted to show either 9 or 12 Decimal Places Digits. Then I am trying to use Concat function, but first I need to understand why the TEXT format in the last column trims and rounds my 12 digits number into 8 digit maximum?Test TEXT length in Worksheet.vwx
Pat please explain how you make VW to use NVIDIA card versus low power built in graphics. Is this for laptop only, or can be set for desktop Apple Studio for example.
@propstuff can you please attach a VW sample file the final pillow product with Tassel & texture
Lighting tutorial NOT related to Spotlight
ashot replied to MGuilfoile's topic in General Discussion
Thank you Pat, I got it worked with Cropped Perspective ! Excellent ... -
@Elite Exhibits Thank you for your attached file 408346396_LightsEmitter.vwx When looked at Saved View 111 Can you please explain what is the screen rectangle with handles to resize? It is not a Viewport or Camera Viewfinder, it is a 2D window (picture in picture)? How can I replicate the same on any other file? @Pat Stanford and others, maybe someone else can explain ... -
Memory leak is still a real problem in Dec 28 2023 Here is a test for VW team: Blank start, newly installed Designer VW 2024 Batch Convert - Convert in Place e.g. message shows conversion of Files 350 of 3736 Memory RAM usage by VW2024 - from the 1-st file conversion RAM started at 2GB on 350 file usage slowly increased to 14GB (Real 22GB, Virtual 429GB) in the end for 3153 file VW hangs with 192GB real RAM memory on my new silicon machine with RAM 192GB with 4TB Internal hard SSD Disk Please advise!
Fit Windows To Roof
ashot replied to KIT KOLLMEYER's question in Wishlist - Feature and Content Requests
To get a sloped top use OIP Top Shape: Sloped, may include transom if needed) use Rise: (for example for roof pitch 4:12 for 5ft wide opening you need to use 5x4" = 20" then play with handles just as described in previous messages. To make perfect fit play with Elevation instead of manual dragging -
Hi Erminio, can you please tell me what utility you used fo rmemory usage shown on screenshot?
@michaelk Do we need to copy to Custom Keyboard folder - all versions: e.g. VS 2023.vs VS 2023_6.vs VS 2023_4.vs or just the latest is enough: VS 2023_6.vs
I helped my partner with this issue while I spent few days in search of this problem. It is related only to Mac OSX settings for Keyboard Under Accessibility option. Just turn off all keys including Full Keyboard Access key, and you will be back to normal. (When it is on, it overtakes Space bar to activate keyboard access) If you are using any of the Accessibility/Keyboard Access options try them one by one to figure our which one is causing any other problem for you.
Connection for ODBC and Filemaker for Vectorworks on Intel Mac has the same problem, I could never solve it for years. on my Mac ODBC works with Filemaker directly, without any problem, but it never worked for sharing with Vectorworks. The Error screenshot shown above is specific only to Vectorworks. After my I struggle I forced to use SQLITE. It works for Vectorworks and does not need ODBC part of Vectorworks.
As of July 2023 (VW SP6) I want to share my solution for a problem when Database General Notes.txt or XML can not be located such as in this screenshot The solution I finally found was to use a command: Text / Reconcile Notes... and then choose the current Database with .xml extension in my user Folder. Before getting my final answer I spent hours and days reading on VW forum. Thanks to David Hamer who helped me with UUID, but the solution was just to Reconcile Notes.
Today is July 2023 and I hit the same problem described above. The solution I finally found was to use a command: Text / Reconcile Notes... and then choose the current Database with .xml extension in my user Folder. Before getting my final answer I spent hours and days reading on VW forum. Thanks to David Hamer who helped me with UUID, but the solution was just to Reconcile Notes. If you want to know more about UUID, read the forum topic below: P.S. The problem with the loading the current Database shown on screenshot below:
Hi Michael, Yes I know one workaround to copy into blank file, run wall frame tool and paste back to original file. If I try any other suggestions in the same original file - there was no success running wall frame tool without warning message and no clue what to do to overcome the limit. I just wanted to know what is the limit for layers when I run wall framing tool. Thanks in advance for any help from Nemetschek VW team.
Any ideas, what is a limit? in my case I have only 49 listed in framing layer lost while in a file there are more: design and sheet layers as: DL = 51 and SL = 17 Is there any solution to choose the Layer I need but missing from the list? I tried to change the name for alphabetical order, then ID order and to bring first to show in the list - nothing works. Any idea?
"Any data shown in a worksheet using a =Record.Field formula is two way editable in either the worksheet or in the Object Info Palette." Hi Patrick, Are there exceptions to your statement? for example Why I can not change the value in a Worksheet for a Stake Object ='Stake Object'.'Z Value' Also I can not find any Record value for regular XY coordinates, like = 'Stake Object'.'X Coordinate' instead I have to use Functions Object-General Data such as: =XCOORDINATE =YCOORDINATE both without =Record.Field option (I can use Easting and Northing, but it is not the same as YX Coordinates)
The script works fine for DoMenuTextByName('Exterior Wall Dimensioner',0); However when I try to search in Library or Plugins, or just preferences, I can not find in any place the file with that name or any other name similar to Exterior Wall. VW Script Appendix H shows a list of commands, none of them even close to that name. (Nothing for Dimension or Exterior or Wall (just wall framer, that is all) https://developer.vectorworks.net/index.php/VS:Function_Reference_Appendix_H So, my question is How, Patrick, you were able to find out the right name of the file ? For my work I need to find a way to call the menu command under Modify>Convert> Stake Object from 3D Locus... Is there a way to do it?
