Ash
    37
Everything posted by Ash
  1. For "double click on grid snapping" method Uncheck "Show 3D Grid Axes"
  2. Can you please make the wrapper with English subtitles?
  3. I understand the need to add my first line. I just can do not have a clue how Texture and new material name is read by the program. I do not see my new line in the pop-up menu for materials and types. Please see attached and advise.
  4. Dear Nicolas, thank you for your help. In my XG library for Imperial Materials the data shows mm and m2. Also I am not sure if for Solid Wood I can find the right Group in the table. None of items in the Material table has a group or texture I want to use. All I need is a "Test Material 3/4" thick with Custom Texture". What will my first line be listed here instead the Chipboard 04 ...
  5. I am using interiorcad XS. In my case, what is the Path and how can I assign new material in >Boards ?
  6. 1) In my version of interiorcad XS the Settings does not have preferences. Instead it shows Version Info with User Settings/Path to XG Resource, Datea with Version, Plugins Path and Export User Folder Path. I do not have Preferences> Database to shoose a table. 2) Also in all XG folders the files are text files. What kind of file format do I need to create for Material to place here? All I want is to have a new Solid Material 3/4" thick without any edge bordering or veneer, to make only one texture and change it on a spot when the client demands, for the entire cabinet, provided I can also change the glass for framed doors.
  7. I am sorry, Woodychips, but I see your Texture for Door H295_ST22, but it is not a glass, no transparency, I see this:
  8. Please see attached VW file with interiorcad XS. It has only one cabinet shared by Stephan, please help to make it in Glass instead of Maple inside the framed door. I am trying NC- Transparent or Glass Texture/Material for Door, nothing changes. Shaker profiles.vwx
  9. Can Stephan explain why Extrablocks have five symbols but at the same time offer a shopping cart which is leading to a broken link on their main website?
  10. Cab anyone share a file just with one cabinet Door = Glass in wood frame (without muntins)
  11. for interiorcad xs user, please explain how to change the material and texture for a cabinet as one unit. I can't follow Stephan's statement, it is not possible "Go to interiorcad -> Master Data -> Boards and define your materials there. Likewise for edge banding and coverings/veneers." Please advice
  12. Thank you, Wes. The quick fix is not what I want. I really need to know how to revert Georeferencing in all my future documents but also be sure that all other tools work as before (like North Arrow orientation)
  13. See attached two files created in VW Designer 2020 SP3.1 In my document "Problem 1.vwx" - When I try to rotate the North Arrow in a Viewport, it refuses to listen and points back to vertical position (North). Changing angle in OIP flips back to 0. It works fine on Design Layer and on Sheet Layer. This happens only for Annotation in Viewport on a Sheet Layer. I suspected that the Georeferencing is a problem. Tried to Reset it, uncheck it - doesn't solve the problem. I started another a new blank document "No Problem Yet.vwx" - everything works fine. However, as soon as I opened the Document Preferences > Georeferncing > OK is activated, the problem with North Arrow in a Sheet Layer Viewport starts again. My real project document can not be recreated from the scratch, it has a month of my work. Is there a way to reset Georeferencing to get back control of the North Arrow in a Viewport? Problem 1.vwx No Problem Yet.vwx
  14. time frame between 15 to 25. Please anyone can explain in steps, how it is done.
  15. Is there any new updated 2019 version for all the above files? I downloaded the 2019 Wind, but can not find the update for the rest. Please advise.
  16. VW Designer 2018 SP2 on Mac-mini Error Loading Vision Plugin Library! Installed, Uninstalled, Re-Installed the latest update, deleted all preferences Nothing helps deleting folder RuntimeCashe and restating - doesn't help either
  17. Tools > Smart Cursor Settings > Grid > Show 3D Axis (uncheck)
  18. Thank you. Attached is final look of two tables. My old table is used for final print. Data follows your method and auto calculated in the first table above, then I manually enter the same data into old table for print. Last changes were: 1) Formula for Column Category: =IF((B2=1289), '1', (IF((B2=1240), '2', (IF((B2=1290), '3', (IF((B2=1291), '4', (IF((B2=1237), '5', (IF((B2=257), '6', 'oops'))))))))))) 2) Formula for Column Image (without SUM) =IMAGE 3) Format Column 'Image' Format Cell - Images - 2D Attributes - Fixed Points So far, I've learned that Site Model SnapShot can be UnGrouped. The Contour lines are separated. The total quantity of Polygons for Slopes in Triangulated Model was over 17,000. Every refresh of Worksheet took several minutes. So I decided to combine all polygons with the same color into one with Modify / "Add Surface" and then pay attention to total area, and if group is objects, not polygons, then carefully did conversion of few polylines into polygons. Final total polygons quantity became = 175, now much better and manageable. I hope this will help other people. Thanks to all forum users and special people like Pat Stanford.
  19. Thank you Patrick: Very nice work, I really appreciate your help. Many many thanks, I owe you big time. Please see attached, I wonder if there is a way to sort data in table, play with order of colors to match original table. Maybe I can pull data from new table and show them in old table. Any other idea for criteria. Is there a way to format "cell Pattern color" by assigning "FB index code"?
  20. I can't find a solution for this simple problem. I use a Slope Analysis from a Site Model with 5 groups of different slopes each colored in different color. Having 5 colored slopes and not being able to tell the square footage areas for each group is quite disappointing. The workaround is to trace over in VW or use other program. First method means that I use either 3D model top view or create a Snapshot and then in VW I trace over each colored zone. Very time-consuming task. Second method means I need to use Photoshop or "Image J" programs with Threshold Color function to measure each layer area. But it requires applying a Scale 1 pixel = to whatever is scale in foot. The result is inaccurate. So my question is: Is there any direct way to retrieve data from Site Model Colored Slopes into a Worksheet? Please help. see attached example, a) site model with colored slopes, b) separate traced over in VW to calculate area and c) same layer in Photoshop to measure area
  21. Crash after Crash after Crash - for the Latest Designer VW2016 on Mac latest OS 10.11.1 16GB RAM. Examples are plenty: simple crash on one blank document with one letter while trying to Export to DWG. Other times get some message such as "Operation aborted due to lack of memory".
  22. Hi Tim, could you please check the link for download, something is missing in the text. I tried full name like http://download2.nemetschek.net.s3.amazon.Tamsin-Slatter.mov nut no response from the server. Tx in advance.
  23. "The Grade tool can help to create proposed slopes, swales etc." Could anyone please give me a step by step overview of how to create new slope and swale using Grade Tool? e.g. how to make 4 different slopes in N-S-W-E directions on a given site model, say I want slopes to be 4:1, 1:1, 1:3 an 1:2 The video on youtube called "Site Modeling and Calculations" shows the slopes for case with Create pad from Grade Limits. In my case I need to have an elevated rectangular pad, I do not need an odd shaped pad resulting from the command above.
  24. Can someone give me a good example for use of some standard PATTERN fill? With all hatches, solid, gradient, tile and opaque color fill, I do not see a reason to use some of the fill styles, those 72 standard patterns? They are known for printing problems. The appearance of the patterns on the screen depends on a layer scale level, therefore they either print at a very poor quality if visible or become like solid color if they are too small on the screen. To compare final results I need to do some testing for settings in VW + print with Preview.app and also Adobe PDF. Too much work and no guarantee of results. Please share your experience.
  25. Yes, Patrick, you are right, the foot mark at the end of number is causing a problem. With Delete() procedure I cured the problem.
