Content Count
35 -
Community Reputation
0 NeutralAbout Ash
Rank
Greenhorn
Personal Information
Occupation
Structural and Civil Engineering
Homepage
ashot.me
Location
United States
Recent Profile Visitors
Interiorcad beginner questions
Ash replied to michaelk's topic in 3rd Party Services, Products and Events
I understand the need to add my first line. I just can do not have a clue how Texture and new material name is read by the program. I do not see my new line in the pop-up menu for materials and types. Please see attached and advise. -
Dear Nicolas, thank you for your help. In my XG library for Imperial Materials the data shows mm and m2. Also I am not sure if for Solid Wood I can find the right Group in the table. None of items in the Material table has a group or texture I want to use. All I need is a "Test Material 3/4" thick with Custom Texture". What will my first line be listed here instead the Chipboard 04 ... -
I am using interiorcad XS. In my case, what is the Path and how can I assign new material in >Boards ? -
1) In my version of interiorcad XS the Settings does not have preferences. Instead it shows Version Info with User Settings/Path to XG Resource, Datea with Version, Plugins Path and Export User Folder Path. I do not have Preferences> Database to shoose a table. 2) Also in all XG folders the files are text files. What kind of file format do I need to create for Material to place here? All I want is to have a new Solid Material 3/4" thick without any edge bordering or veneer, to make only one texture and change it on a spot when the client demands, for the entire cabinet, provided I can also change the glass for framed doors. -
I am sorry, Woodychips, but I see your Texture for Door H295_ST22, but it is not a glass, no transparency, I see this: -
Please see attached VW file with interiorcad XS. It has only one cabinet shared by Stephan, please help to make it in Glass instead of Maple inside the framed door. I am trying NC- Transparent or Glass Texture/Material for Door, nothing changes. Shaker profiles.vwx -
Can Stephan explain why Extrablocks have five symbols but at the same time offer a shopping cart which is leading to a broken link on their main website? -
Cab anyone share a file just with one cabinet Door = Glass in wood frame (without muntins) -
for interiorcad xs user, please explain how to change the material and texture for a cabinet as one unit. I can't follow Stephan's statement, it is not possible "Go to interiorcad -> Master Data -> Boards and define your materials there. Likewise for edge banding and coverings/veneers." Please advice -
Problem with Orientation of North Arrow in a Viewport
Ash replied to Ash's topic in General Discussion
Thank you, Wes. The quick fix is not what I want. I really need to know how to revert Georeferencing in all my future documents but also be sure that all other tools work as before (like North Arrow orientation) -
See attached two files created in VW Designer 2020 SP3.1 In my document "Problem 1.vwx" - When I try to rotate the North Arrow in a Viewport, it refuses to listen and points back to vertical position (North). Changing angle in OIP flips back to 0. It works fine on Design Layer and on Sheet Layer. This happens only for Annotation in Viewport on a Sheet Layer. I suspected that the Georeferencing is a problem. Tried to Reset it, uncheck it - doesn't solve the problem. I started another a new blank document "No Problem Yet.vwx" - everything works fine. However, as soon as I opened the Document Preferences > Georeferncing > OK is activated, the problem with North Arrow in a Sheet Layer Viewport starts again. My real project document can not be recreated from the scratch, it has a month of my work. Is there a way to reset Georeferencing to get back control of the North Arrow in a Viewport? Problem 1.vwx No Problem Yet.vwx
Ash changed their profile photo
time frame between 15 to 25. Please anyone can explain in steps, how it is done.
Is there any new updated 2019 version for all the above files? I downloaded the 2019 Wind, but can not find the update for the rest. Please advise.
VW Designer 2018 SP2 on Mac-mini Error Loading Vision Plugin Library! Installed, Uninstalled, Re-Installed the latest update, deleted all preferences Nothing helps deleting folder RuntimeCashe and restating - doesn't help either
