Connie
  • Content Count
    6
    Never
Community Reputation
0 Neutral
About Connie
  • Rank
    Greenhorn
Personal Information
  • Occupation
    Designer
  • Location
    Charlottesville Virginia
  1. Thanks, everybody. I feel clearer about the setup, but I still have a few questions about how some things will work. For example: I have an existing wall drawn from the E-wall class. I insert a window symbol into it from the N-window class, which breaks the wall. If I want to display the existing plan. I turn the N-window class off, but the break in the wall still shows. My solution is to insert a section of wall into the break from the E-wall class so that the wall will look continuous. Is there an easier way to do this?
  2. Is there a way to break a symbol's association with a wall without having to drag it out of the wall? I'd like to be able to select a door or a window without also selecting the wall it is in.
  3. I see this referenced in a posting from 2000. Does it still exist in VW 10.5? If so, where is it?
  4. I'm doing a house renovation project using version 10.5. I've drawn an existing floor plan and now want to create new classes that show both the areas to be demolished and the new configuration. Eventually the info will be separated into a demolition plan and a new floor plan, but some of the existing plan configuration will be shown where work isn't being done. What's the best way to set this up?
  5. Connie
    Stairs
    Hello All, I am using VectorWorks Architect Version 10.1 . I am trying to do some simple stair layouts for a custom railing design. I want to create this in 3d and detail some elevations. I am having a problem with the automatic stair layout tool. The stair I want is not there. Do I need to create my own custom stair? Any other hints would also be appreciated. Thanks, Connie
  6. I AM ATTEMPTING TO SET UP A CUSTOM TITLE SHEET. I HAVE EDITED THE STANDARD ARCHITECTURAL .MCD FILE WITH MY NEW SHEET. WHEN I LOOK IN THE RESOURCES MANAGER, I CAN SEE THAT MY NEW SHEET APPEARS! I CAN INSERT THE THING, BUT IT IS NOT SCALING PROPERLY. HOW DO I GET THE THING TO SCALE? I AM ALSO FAMILIAR WITH ATTACHING THE SHEET BORDER RECORDS AND SUCH. CAN SOMEONE PLEASE GO INTO MORE DETAIL ON THIS? I AM TRYING TO GET THE ISSUE MANAGER TO WORK FOR EASE OF REDLINING. THE BOOK AND THE INSTRUCTION CD'S ARE VERY VAGUE ON EDITING FOR A CUSTOMIZED BORDER. IT COULD ALSO BE MY STUPIDITY AS WELL. ANY WORDS OF WISDOM WOULD BE GREATLY APPRECIATED. RESPECTFULLY, CONNIE DEATHERAGE
