Rok
    5
Reputation
0 Neutral
Personal Information
  • Location
    London
  1. Cheers Jim for that and for your prompt response. Rgds Kor
  2. Thanks Jim, I'm assuming you're saying that function isn't available in Fundamentals only to undo?
  3. Hi peeps, Any chance anyone can help, is there a way to rotate the UCS in Fundamentals (v2012)? I know there's a "rotate plan" command but I can't seem to find it. I'm therefore assuming: a) I'm blind and b) it's not available in Fundamentals. If it isn't, is there a way round it? Cheers Kor
  4. Is it possible to switch off layers or classes as in Autocad, whereby you simply go to a command and select layer off and you can simply go around your drawing with your cursor and highlight objects and they'll switch the layer they're on to off. I know you can do this the standard way by going to the layer/class table and switch them on/off there but I was hoping there was an easier and more visual way of doing this. Or maybe if anyone knows of any scripts out there that will do this. (I'm currently working of VW 2012 Fundamentals but we've also got VW Architect in the office if that's any better) Thanks in advance for any help. K.
  5. Heeelp...I'm new to 3d Vectorworks,...so that's my excuse.Now that that's out the way. ;-) I'm attempting to set up an axonometric from a true plan.The problem quite simply is,I can't...I don know how...I'm lost on how to do this. So far,I think I understand that you should be able to achieve an axo in Oblique Cavalier 45. But it doesn't work. The height (z)is correct but both (x and y) are too short. Principles of an axo, object drawn at 45 degrees,all lengths are true(x,y,z). Any ideas,would be cool. Cheers R ps.Forgive me, if it's really simple(please refer to my first paragraph).
