markdd
3,393 -
Everything posted by markdd
You need to add a 2D component to the Symbol otherwise you will get the generic blue circle. YOu can turn the weight indicator off using classes. Once you have a Point load object you are happy with, save it as a Symbol and ensure you have "Convert to Plug-in object" checked in the Create Symbol dialog. The result will be a Red symbol that you can use whenever you like.
Have you looked inside the Label Legend symbol to make sure that the Text is above the sample Lighting Instrument symbol? It looks like it is only an issue with one Label Legend symbol.
Can you show an example image? It will help with working out what the problem is.
Schematic View doing nothing at all for me...
markdd replied to aamyot's question in Troubleshooting
Ok. Post the file or do a quick screen recording of your workflow and I’ll see if I can help. -
You should investigate the Rigging loads tool and the subsequent point load object. You can add symbols to this giving you the load indicated along with the clamp geometry. The resulting object can be saved as a plug-in symbol which you can add to your library.
The only I know how to do this is to name the object in the Object Information Palette in the Name Field at the bottom or to name the object using the Notes field. However, as of release 2024, there is now a statutory EntEquipUniversal (catchy title!) record that is attached to all entertainment objects by default. I believe the idea is that you can add fields to this record as per your particular needs and use that to populate a worksheet.
The answer is no. But it’s a great idea. I’ll put in an enhancement request tomorrow and see what comes back.
If you have worked with it before, then I see no reason not to. All they are checking for is that you know what you are getting in to. Make Sure you save the file before doing so. Then you can always go back with no harm done.
These are Parametric Constraint indicators and are meant to be there. You can make them invisible by going to Menu > View > Show > Show/Hide constraints. If you want to learn about constraints then you should take a look at the help file here. https://app-help.vectorworks.net/2024/eng/VW2024_Guide/Basic3/Concept_Parametric_constraints.htm?rhmapfs=true#CSH_456 Hope that helps.
Hi There used to be a filter in the old Instrument Summary that would allow you to do this and if I remember correctly there was an option to filter by viewport. In the new Equipment Summary, you can filter by design and sheet Layers instead, but at the moment, no viewport filtering capability exists. If you can get into Graphic Legends, then Viewport filtering is a synch.
I for one am delighted that the tooltips are not working - I have long asked for a way to turn them off.......!
Check the Insertion point modes when the Insertion tool is activated. You need to have it on the fourth "Insertion Point" mode.
Viewing/Hiding lighting device symbols for designing and viewports
markdd replied to jloganthomas's topic in Entertainment
Probably the best built-in way is to automatically Class them. This can be done automatically by using Spotlight Preferences and Classing By Instrument Type. I am sure other folk will have other ideas. Data Visualization could be another route if you set it up carefully. -
Just a thought. If you create your front texture with a 65% grey colour as opposed to white, then if you ramp up the glow value to 250% then you might get closer to the result you are after without the bother of using an area light.
I’m going to file a bug report on that. I think then you will be left with creating an area light ( as @bjoerka suggested) instead of a glow texture, and use the forward texture that you have created already, but with “cast shadows” turned off.
I don’t think so. However, you could make two textures added to two surfaces inside the light boxes. An inner surface could contain a glow texture purely for lighting at 250%. An outer surface with a “decorative” glow texture set to 100% and not to “cast shadows”. That way you should get the best of both lighting and realism.
Quickest way to find an intersection of solids surfaces?
markdd replied to line-weight's topic in General Discussion
The Analysis tool does this in two clicks. -
Please can you all file this as a bug too. This needs to get pushed forward to be fixed for the next service pack update.
