drawingguy
    9
Reputation
2 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. It appears that in 2025, the "All Layers Circuit Report" only generates a report for the currently active Design Layer. This forces me to go to each Design Layer and generate a separate "All Layers Circuit Report" Was this change intentional? Is there a way to generate the report for the entire project in 2025? Thanks
  2. @Nikolay Zhelyazkov, Apologies for the delay. I believe this was related to the grid spacing issue I posted about here I believe when I installed the latest update, it reset my grid/snap to 1/8" and then when I created a flag, it sized according to that grid spacing. Resetting that back to 1/4" matched the rest of my drawing. I'm hopeful that VW can disassociate the grid/snap settings with the sizing parameters of equipment symbols and flags. The grid should be a reference and not used for program calculations. That would be helpful to have as an additional parameter. Thanks
  3. I updated to Build 5 recently and continued working on a project. I've noticed that the cable flag text is much smaller then it was previously. How do I correct this? Thanks
  4. I believe I figured it out, however looking for confirmation. The "Device Builder" creates the spacing based on the grid/snap settings in combination with the "ConnectCAD Settings" connector spacing options. If you change the grid/snap spacing mid project and then use Device Builder, the spacing of the new symbols will be based on the current grid/snap settings. It may be helpful to disconnect the association between the grid/snap and the ConnectCAD device layout spacing so this doesn't happen in the future. If this is not supposed to function this way, or if I solved my problem via the wrong method, please let me know.
  5. I opened up CC today to continue on a file and now any new symbol I add is scaled differently (and much smaller) then yesterday. Any help would be appreciated.
  6. Good Morning @Nikolay Zhelyazkov, I've emailed you a sharepoint link to the file. Thanks!
  7. I was working on a CC file and all was well. As soon as I placed gear into a 3D rack, my reference grid shrunk and is no longer the size of my page. I cannot find a way to change the total LxW of the Reference Grid. Notice how the grid just stops short of the page bounds. Thanks
