nicoloco
33 -
Calendar
Everything posted by nicoloco
Get the following error message when trying to cut and paste a Sheet Border from one drawing into another or when duplicating a Sheet Layer within a drawing. 'The "IP resources" file was not found' - VectorScript Message Any ideas? Using VW2010 SP3 (123041).
Has anyone managed to script a viable alternative? We would like a version of the elevation benchmarker as follows: - single line calling out the height (say left to right) - unfilled equilateral triangle sitting point down on the end of this line - above which are the y-coordinates (+00.000) ie. 23450mm above the origin would be +23.450 - an editable field for the text to the right e.g. 'Roof', 'Parapet' etc. We have an uneditable version of this on our drawings at present, but can find no way of automatically connecting a field to the Y-coordinates... Anyone set one of these up as a symbol?
Printer/Plotter Recommendations? - OSX Leopard, Vectorworks 2008
nicoloco replied to nicoloco's question in Troubleshooting
David, Thank you; will look into that. Has anyone else got any experience with any of the above plotters? -
Hi there, quick question: VW2008 SP3 As part of our office workflow, we have set up two types of files - 'Reference' (for live design data) and 'Output' (for drawing issues). The data from the Reference files is brought into the Output files via Design Layer Viewports. Sheet Layer Viewports are then used to arrange the data on the Sheet Layers of the Ouput files. Sometimes, we would like to override certain class settings within the Output files (for different issues for different reasons/client bodies etc.). ie. change all of the 'internal walls' to a dotted line for issue as a tenancy drawing. When we choose to override the classes in the Output file, the changes are shown on the Design Layer Viewports, but these changes do not come through to the Sheet Layer. Why not? Any help would be appreciated.
Anyone? -
Every time a reference appears in the right place, I clap...
Mike, Sorry, I don't agree with you. I can see the benefits of improved 2D snapping and the loupe (why not, yes please), but whilst this might make physical drawing faster, I am talking about the time spent setting up separate referenced drawings and working in an office workgroup environment where three/four users need access to a range of drawings simultaneously. The biggest timesaver for us would be not to have to re-set up our section/elevation/plan references everytime VW flakes out due to a rotated plan issue (even with SP3). This infinitely outweighs any increase in productivity due to being able to snap quicker, or being able to add complex shapes to one another properly.
When I say "I'd feel bad paying", I mean that I'd find it incredibly hard to justify the upgrade to the partners.
Further to the VW2009 UK 'launch', neither of the above are part of 2009. The 2D surface adding/subtracting does look a lot less buggy. So basically, 2009 is 2008 with a major bug fix...big deal. So we're going to stick with 2008 which by NNA's admission doesn't work properly until 2010 or 2011 when they've had time to make the most out of the Parasolid engine. Some issues: ? coordinate system still changes origin/orientation of data when rotating page. ? still no RAL colours...I think they got the message this time. ? no SLVP from one file to another (still a 2-step process Live Data > DLVP in another file > SLVP in that file...but apparently they have fixed the issue with the 'flattening' of layers/classes so that layers and classes in a reference come through to the SLVP in another file. ? the new Snap Loupe and Batch DWG functions look useful but not enough to warrant the upgrade. I'd feel bad paying for Parasolid just to fix things in VW that should already work. Doesn't feel right.
Going to a VW Presentation in London on the 24th so will be sure to ask lots of questions re: changes to the 2D drawing engine and whether VW2009 is true UCS or whether that is coming in VW2010. The other thing we would love to see is the ability to reference from a Design Layer in one file directly onto a Sheet Layer in another file. Having looked through the list again, I have to admit that Batch DWG exporting of separate layers looks very useful.
From NNA's documentation, all the 'improvements' to VW2009 seem to be centered around a new 3D engine. And wood screws... As a large architectural office which uses VW2008 for 2D drafting but has no intention of moving to BIM with 2009 (possibly the majority of users?), does anybody know whether the Parasolid engine will bring improvements or changes to the 2D data? Or is it a separate system altogether? We would like to see a solid Autocad UCS-like plan rotation feature, rather than the current situation where the plan rotation 'function' merely rotates all of the data in the file by resetting the origin and orientation; causing numerous problems when referencing. Am aware that this would involve a re-write of the legacy Minicad file structure, but was hoping that this would have been sorted out by now after 10 years. Otherwise, we see little reason to upgrade to VW2009 in order to get a 3D modelling engine which we will never use.
A proper 2D 'rotate page' tool which doesn't just reset the origin and orientation of drawing data would be nice... ...so we can actually use the program in our office to draw buildings.
Hi there, Here's what I think (and why Nemetschek should be ashamed of themselves)... ...when you rotate the page, you would expect to just be rotating a view around a fixed drawing (all the data in the same place), right? ...wrong, the rotate page command merely temporarily changes the origin and orientation of the actual drawing data. If you don't believe me, try drawing any object then copying that object into memory. If you rotate the page and then paste the object in place, you would expect it to come in on top of the original, but it doesn't...it comes in relative to the new origin/orientation. This explains why referencing doesn't work when a file is saved in rotated page view. They just made it easier to mess up your drawings...and when you ask them about it they say, "ah well, it was never meant to be an Autocad-like UCS system". Call it the 'lazy origin reset with admittedly pretty but ultimately meaningless animation effect tool' then! As you said, "I don't believe this is how it should be".
T1100PS anyone? Any news?
VW2008 SP2 for Mac OS X slow printing to a HP T1100PS
nicoloco replied to ljiggins's question in Troubleshooting
Anyone figured this out yet? -
Found another problem printing from VW2008 to an HP DesignJet 800PS: ? when printing with transparencies, line weights close to the transparent object appear to thicken considerably.
nicoloco posted a question in Troubleshooting
Hello, Our office is (finally) about to buy a new Large-Format CAD Printer/Plotter. We currently use an HP DesignJet 800PS but this has recently started printing very slowly from VW2008, and I have seen other users on this board with similar problems (mostly with HP Printers it seems). In the absence of any guidance, can anyone recommend a reliable plotter for use with Mac OSX Leopard and VW2008? Here are our criteria: ? 30-35 Users ? Moslty used for CAD Drawings (mainly B&W but a number with colour fills) ? We would like to be able to print transparent blocks of colour accurately e.g. for shadows on elevations etc. ? We would also like to print occasional large-format presentation sheets in full colour and achieve a good level of colour matching with our screens. We have the in-house ability to create a colour-profile for a printer and would like to add this into a Photoshop/InDesign workflow. We are considering the following machines, but if anyone has any other ideas (even if to just say "that one's crap...avoid it like the plague") then they would be greatly appreciated. ? Canon imagePROGRAF 720 ? HP DesignJet T1100PS ? Epson Stylus Pro 9450 Thanks, Nick Wharton London, UK -
VW08 Workgroup References Unstable - Location Problems
nicoloco replied to nicoloco's topic in Architecture
Jeffrey. Thanks for the efforts. Will update and see if this fixes the odd behaviour. When you say 'best results' do you mean the source files must always be saved in true/absolute orientation otherwise the relative orientation will have been changed (and therefore the drawing will reference into a different place? In which case, why allow users to save the drawings in rotated plan view? Why not add an option which automatically rotate the plan back to true/absolute when saving? ie. getting rid of the possibility of 'human error', which WILL inevitably happen (especially in a big team) and has already cost us time and lots of arguing with one another. The best we have come up with recently is teaching users to hit Apple-5 then Apple-S... -
Any indication on timescale for this fix? In the meantime I have a fundamental question regarding the 'rotate plan' function in Architect 2008. It seems that when you use the 'rotate plan' function it changes the absolute coordinates of the drawing. ie. say you have a file an unrotated plan and you copy an object into the memory...then you use the 'rotate plan' view and change the angle of the drawing...when you 'Paste in Place', the object will come in relative to the new coordinates ie. not absolutely where it was. Isn't this what is happening to references when the source file is saved in rotated plan mode...ie. the coordinates in the source file have changed so the destination location will change? Seems like a fairly fundamental issue to me, which makes the new rotated plan function fairly useless in real life. Basically the 'rotate plan' function is little more than a temporary way to change the origin and orientation of the drawing. Ideally the program would be able to keep absolute locations intact when rotating the plan...is this going to be possible or will we have to ban either the 'rotate plan' or referencing functions in our office? (ironically the main reasons for upgrading to 2008 in the first place, and the only reason for paying the extra money for Architect...) -
Creating DWF (Drawing Web Format) files on a Mac?
Design Web Format. Different name, same problem. -
On a current project, we have been asked by a co-ordinating architect to issue our drawings in DWF format instead of DWG or PDF. We're working as part of a large team, most of whom are on PCs running Autocad. Is there anyway to create DWF files from Vectorworks (either directly or with a 3rd party plug-in)? Failing that, is there a program we could run on Windows XP (shudder) under VMWare Fusion in order to convert Vectorworks files (or DWGs?) to DWF?
p.s. hatches and opacity print correctly in VW2008. The problems seem to be restricted to patterns.
Also having the same problems with a HP Designjet 800ps. However, for us, the problem started with the upgrade to VW12. If we export drawings back to VW11 the patterns will print properly on the plotter. The only reason we were using patterns was to achieve colours unavailable in the VW9/10/11/12 legacy palette. Now that VW2008 can create any colour as a solid, we no longer have any use for patterns, so I would advise anyone else to banish them from their workflow.
Our HP Designjet 800PS will not print patterns properly in VW12 or later. The patterns 'move' to seemingly random locations upon printing. Exporting to PDF and then printing causes the same strange behaviour. We had used patterns previously to achieve colours outside of the rigid and shockingly small legacy VW palette. With the advent of VW2008, there is no longer any need for us to use patterns as we can make any colour we wish as a solid.
Thanks for the update and the effort. We are still experiencing the same behaviour and, as a previous poster noted, is costing us considerable man hours re-referencing all our drawings.
