It sounds like you have started so I will be brief but if you would like to ask more then e-mail webforge@highway1.com.au
1. Create a new record format.
2. Add new fields to the record & save.
3. Draw an object.
4. Pick the object and from ObjInfo menu,
add info.
5. Create a worksheet.
6. In a cell type =('record name'.'field')
ie. substitute your own names
7. On the left side of the worksheet is
column of numbers. Right click on the
line which you are working.
8. Choose Database.
9. The criteria should be: Record, @#$%
is present (OK).
10. Recalc if needed.
11. Left click on the line number.
12. Add 'Sum', 'Sort up' or 'Sort down' to
the column letter.
13. The end. Continue adding as above as
required.
Regards
Trevor
quote:
Originally posted by pml:
Can anyone write a few paragraphs to help me with the basics of that listed in the subject line? I have gone through the manual and done a litle bit with attaching records, but it would seem that the manual is missing a few key pieces of information.
Any help is greatly appreciated.
