978 -
Everything posted by Diamond
Hi Jim, I use the framing member object for many things (besides traditional framing). In fact it is great to create Auto Hybrid objects by turning off the 2D component and just use the 3D geometry. When I set the span, the pitch remains the same. Not sure if it is a bug. When I set the length, the pitch of the object is changed. REQUEST: Can the length be set without changing the pitch? Thanks. TD
Smart cursor for editing tools
Diamond replied to Art V's question in Wishlist - Feature and Content Requests
Hi Jim, Just found an older post. I have been closely following what Affinity are doing with their graphics apps, and they are actively looking to port their Mac app to the iPad. I could see this interface working really well on an iPad Pro with Pencil. For Mac/PC use I would think it may be too slow (as opposed to keyboard shortcuts). That said, for those that use Wacom tablets, it might be very helpful. Also, for the reasons that people use iPads this interface could be helpful at times. An iPad for me generally slower, but I often feel more focussed and satisfied when I complete something on it. -
Thank you for confirming what I thought. Then is Vectorworks help incorrect? Or am I just getting confused by the wording? Thanks again.
Okay, thanks for the heads up. That was the answer I was expecting. PS I seem to have screwed up the thread. I deleted a doubled up post. Time to go restart my router!
Thanks Wes. That was sentiment relayed to me by my local distributor. The worksheet I have – it seemed to work fine in 2015. All set then!
Hi Jim, What types of things might be missed? Thanks for that.
Hi, Using Vectorworks Architect Australia, I have seen auto-classing in 2016 break in most cases. In 2015 it was mostly fine. Objects like stairs, spaces and terrain models, that previously worked fine, all broke. Hundreds of hours developing a class standard (based on VwArch.sta) for our studios to assist the newer Vectorworks users currently down the drain. Surely this can get sorted out in an upcoming SP? Hi Wes, I would be keen to know what this solution might look like? Thanks.
How do I cut, trim, or subtract a 2D group?
Diamond replied to Mark Taylor's topic in General Discussion
Hi Mark, Step 1. Modify > Clip Surface the circles from the rectangle. Step 2. Use the Split tool in the Basic Tool Palette. Look in the mode bar for options. In Line Split Mode down the centre for two pieces. In Line Trim Mode down the centre for one piece. Cheers. -
Hi, Does anyone know if, when a working plane is active, rulers show units relative to the working plane origin or to the drawing user origin? When I test this, with a working plane active, the rulers display units relative to the drawing origin, not the working plane origin. Vectorworks Help seems to say otherwise. What am I doing wrong? From Vectorworks Help… Based on the current measurement system, rulers make it easier to precisely create and place objects within the drawing. The 0,0 point on the rulers represents the location of the user origin, or of the working plane axes when using a working plane. The User Origin command moves the user origin relative to the internal origin, or moves the working plane origin to that of the layer (see Setting the User Origin). Thank you again… TD
Hi, I am willing to be proven wrong, but I am sure roof objects having components is the solution. It is just knowing how to use Vectorworks objects for a given purpose. What I recommend is to have a group of component classes. I name ours Component-Turf, Component-Earth, Component-Concrete, Component-Brickwork and so on. If you have more than one concrete type on the project (for example, one for walls, and another for slabs, or one with a different texture), then create more Component classes. Personally I think having separate component classes for wall and roofs (for example, Wall-Component-Brickwork, or Roof-Component-Framing) makes life confusing. In the real world, a material is a material no matter where you use it. Better to have them all under the one class heading. Also all of these classes can have the correct linetypes, fills, hatches and textures so that they appear correctly in Top/Plan, Section VP, and 3D render. Energy value ratings for each component can be assigned when you create a slab, wall or roof component style. Also each component can work in conjunction with your finishes schedules. Hope that helps.
Vectorworks Service Select cost
Diamond replied to Cadplan Architecture's topic in General Discussion
I concur on the education front. We have many students working for us in their gap years, and the hoops they have to jump through to get a Vectorworks education license can be nuts. -
Hi Jim, Can you please tell me any issues I might be causing for my team by creating a Vectorworks installer for our studios? The way I go about this is to do a clean install of Vectorworks on one machine, and from that create a disc image containing an Automator script that copies into the same respective location on each machine; 1. The Vectorworks app with our special sauce (that is, our templates and modified libraries), 2. Vectorworks preferences (from the users Library/Preferences folder), 3. Some files and folders from the user Library/Application Support/Vectorworks folder. As far as I am aware, this is the only way to be able to roll out correct line endpoint styles, and back up prefs for the whole team. Also makes it much easier to roll out to 30+ machines, allowing for a general studio support member to run the installer. Is there any way copying these user prefs could be causing problems on other machines? Is there another way to set user prefs without tainting them on a single machine first? Thanks. TD
Is there a known issue in 2016 with Cameras?
Diamond replied to simbob's topic in General Discussion
Hi Jim, I have also been having issues with cameras in SP1, 2 and now SP3. 1. Edit camera through sheet layer VP, change camera view to Top/Plan (press Command-5), then select Activate camera view. The camera number in Shape tab of Object Information Palette is renamed. 2. When camera is directly over/under view point. For example, camera height 3000/-3000 Look to Height 0 doesn’t work. Thank you for any clues as to how to fix this. -
VEVECTORWORKS 2015 KEYBOARD SHORTCUTS IMAGE
Diamond replied to mendezarcediego's topic in Resource Share - Templates
Great work. I know our team members will love it. Thank you Diego. -
Add the stair tool to this bug. Thanks.
When auto-classing is turned on, the Stair and Terrain Model objects autoclass to classes in the VwArch Standard, not my standard, even though my standard is the one selected. I know the stair tool did not do this in Vectorworks 2015. Thanks.
I think it would be good to have the option to tie them together, but it not be mandatory. I wouldn't want my Community Board ID to be tied to my day job. People often move between larger practices and becomes a challenge to manage. But for one man shops, I can certainly see the appeal.
Hi Jim, I have noticed there are auto-classing bugs with the both the Stair and Terrain Model objects when Auto-Classing is turned on. Have you noticed this? Thanks.
How to safely remove VW 2015 after VW 2016 is installed
Diamond replied to Dubman's topic in Architecture
I start the prefs from scratch for each release. So that isn't an issue. I was wondering if there were any cleanup scripts or other critical routines(?) that Vectorworks 2016 Installer was running. Thanks. PS I am ignoring that typo. Long day? -
Hi Jim, On installing Vectorworks, is there any danger in having a master Vectorworks application folder with custom templates/presets that I copy from server to machine? What about Vectorworks preferences as well? (For arrow styles etc?) (with the exception of the license registration pref files). We have many machines that need to be deployed and it hasn't been an issue for previous releases. Thanks. -
I have a workflow/class structure that overcomes this. More to announce soon-ish. Whilst I see the logical conclusion of this argument, part of the power of Vectorworks is it's 2D presentation strength. For hybrid 2D/3D schematic design, landscape, interiors and masterplanning nothing else can come close. If it did just go 3D all the way, why would I stick with it? Wouldn't ArchiCAD or Sketchup or some other be better solutions? PS Who is CSI and what is Omniclass class structure?
Hi, Additionally, I have been finding similar issues with slab objects that have a number of subtractions or additions applied to them. Thanks.
Hi again, To follow up, this is happening on both of our 10.10 and 10.11 machines. Jim, is there a estimated release date for SP3? Thanks.
Hi Guys, I had same issue with stair presets moved over from Vectorworks 2015. I have been in contact with my local distributor (after sending files, the bug was able to be reproduced), who in turn has been in contact with German devs. I was told this will be fixed for 2016 SP3 ANZ (Australia and New Zealand version). Cheers. PS Also auto-classing for this object seems to have broken with 2016 as well.
VW 2016 IFC export issues (that were not in VW 2015)
Diamond replied to TheatreG's topic in Architecture
Hi Gester, You make a good point regarding the non-editability of IFC. At a recent product demo for Solibri, a speaker noted IFC was the only file format that would be able to protect a studio's intellectual property. That said, architects have very different needs to the various consultants or suppliers that are engaged as part of the project team. Three points; 1. We sculpt the building to suit our designs. As a part of that, getting prelim versions of consultants models that we can edit in a format that Vectorworks can natively edit, cuts down the time taken in the design iteration process. 2. Bringing in IFC files from consultants for design review, clash detection etc slows Vectorworks to a crawl. Having Vectorworks convert IFC into a native format/geometry would take much of this grief away — rather than the mess of 3D polys that are currently created. 3. I am seeing more suppliers creating their product object libraries as IFC files. As architects we need to bring them into our files. But if Vectorworks either; creates rubbish IFC conversion; or due to Vectorworks place in the market, we only have the option of Revit, ArchiCAD or IFC; or if the original object is drawn in a less than satisfactory manner — we end up re-drawing it all again anyway. I understand the purpose of IFC to protect the I.P. of each team member, and control versioning etc, but if Vectorworks could read and export IFC natively, it removes much of the friction created by limited interoperability, without overstepping IFC's mandate.
