978 -
Everything posted by Diamond
Unified View, always on please
Diamond replied to Christiaan's question in Wishlist - Feature and Content Requests
Hi, I also agree that layer views should be on by default, but it useful to turn off. Esp if settings are set to hide objects in Sheet Plane, which is the usual issue I find in our studios. Also aligh layers changes some snapping, and 2d creation modes. Also doesn't unified view override a design layers render settings. In older versions of Vw I remember using different render settings for different layers. I have been thinking of this lately, as I want to be able to save the render settings for design layers with flattened section VPs to trace over. That is, have the section / elevations in wireframe mode, but the section VP layer rendered in hidden line mode. Am I mistaken? -
Wrap geometry to surface
Diamond replied to Diamond's question in Wishlist - Feature and Content Requests
Hi Jim, Yes, that example of the option of warping the objects is a good one. I wonder if a 3D symbol could have an option to be warped, not just scaled. Back to what we were creating that has brought up this request. See the attached Render. We got around the issue by; 1. Drawing the 3 sizes of battens in plan and extrude. 2. Project an extruded 2D elevation of each batten size outline onto an extruded radius of the building footprint (because the footprint radius was consistent, in this case was possible. If we had an oval it may not have been). 3. Extract the intersecting surface. 4. Loft each surface to create a solid to be intersected with the each of the corresponding batten size extrusions. 5. Breath. Would have been much easier to be able to model this first, convert to auto-hybrid object, and generate the plan and elevation from 3D. Thanks. PS Julian Carr provided some assistance here. -
Good spot. I hadn't picked that up. Am I correct in thinking this is the closest thing Vw has to wrap? -
Hi, I don't believe it is possible to wrap (as opposed to projecting a flat surface) onto another 3D surface. We can do something similar with the "Text Along Path". Time we had it in our 3D toolset as well. Thanks.
ifc export of separate wall/slab components? how, if possible?
Diamond replied to gester's topic in Architecture
Hi Rob, I have had this question myself. Shouldn't the walls and slabs containing components be exported out correctly, and be able to be qualified in the IFC model? Do you know how the IFC file binds together objects containing separate classes? -
Backing up Gester (and the link), I think most of these are based on the proprietary system/equipment that is used by the surveyor. For the projects I have had this available, the system was by Leica, and had no Mac (or Vw) plugins to be able to view the survey. Leica has a PC app to view the overall point cloud accompanied by a panorama photo of each survey scan location, which is helpful (if you are PC based). The surveyor had a draftsperson modelling the existing geometry from the generated point cloud on AutoCAD, I believe via a Leica plugin. The only reason this was feasible in our case, was due to the remoteness of the site, the terrain angle being at 52?, and negating the surveyor having to revisit the site. Back to the point could file, maybe if NV partnered with Leica, we might be able to get around this in Vw. Is there an open standard for this kind of data?
Problematic Sketchup (SKP) and 3DS Files
Diamond replied to PVA - Admin's topic in General Discussion
Hi Jim, I believe the 3D artist have an issue editing the 3D model that is produced. Creating too much triangulation, even on the least settings in Vw. Also possibly the issue is that the textures are a challenge to apply the geometry created in VW? Thirdly, the issue could also be the issue I commonly have with issuing DWG files, where the third party is inexperienced, or lazy, to properly work through the files issued to them. In fact, in my experience, this is the more likely scenario. Unfortunately I know little of 3DS Max to be able to work through any challenges. I have sent you an email with the 3DS file we sent to them (For this project we ended up sending them the DWG files as well so they could recreate the model). PS Could it be that the FBX file seems to keep all of the texture data contained within the file, where as 3DS keeps the textures externally? Thanks. -
Hi Jim, This is a follow over from this post. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=200550Post200550 I couldn't see a wish list item for this, and so here it is. For section Viewports, not having a saved viewport cache makes the flattened VP setting almost useless. When it was announced, I thought it would solve so many issues. Especially for those that are not 3D literate?to be able to trace over a pre-setup flattened VP sounded great. Ideally it would be used as an outline trace tool for details and sections. But without the option to have a rendered hidden line version and is able to be saved in a consistent render state, it doesn't solve the issue it should have addressed. Is there a way that if the flattened section VP tick box is selected, and if Saved VP Cache is selected in the Document Prefs, then the section automatically is saved as a hidden line render, separate from the render setting for that layer? Thanks.
Hi, Yes, not having a saved viewport cache saving it's render state is really annoying. If I do use it, I tend to convert a copy of the Viewport to linework. When it was announced, I thought it would solve so many issues. Especially for those that are not 3D literate?to be able to trace over a pre-setup flattened VP sounded great. But without the option to have a rendered hidden line version and is able to be saved in a consistent render state, it doesn't solve the issue it should have addressed.
DWG Export Viewport - Convert to 2D in Model Space
Hi Pat, Thanks for that. I use that process regularly for 3D SLVPs. Is there a way to do that with SLVPs in Top/Plan view? Thanks. -
Hi Jim, Importing I have stopped importing our in house Sketchup files as the results were so bad. A guide to achieving good results would be great. Exporting We have reverted to exporting out FBX files, which only seem to need tweaking to textures. Whenever we export out 3DS files, our 3rd party visualisation artists end up redrawing the whole model. Thanks. -
Hi Jim, I want a Sheet Layer and it's viewports to be converted into lines and hatches when exported?not the whole design layer. And not contained within a cropped reference as they do now. The why; -We have to issue drawings of airport tenancy fitouts to consultants that contain only a single tenancy (out of hundreds). As you can imagine, the base airport plans are massive, and confuse the daylights out of the consultants when they explode the base plan in AutoCAD. All they have then is a massive plan and no idea where there base drawings have gone to. -This issue is the same for plans and section detail SLVP's, that when exploded are a mess of linework over all of the other SLVPs (now in Model Space) that were part of the original Sheet Layer. -Also, when we issue these files, we have literally hundreds of drawings to issue in a set. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=59874 This is a related post, but the work around only seems to work for rendered VP's. Thanks.
Diamond replied to Diamond's question in Troubleshooting
Crickets... The resounded silence is deafening! I guess that is because it doesn't work the way I want it to. A wish list request then. -
Ha! Good one. I crack me up! Confounded auto correct on the iPad. I am sure I meant parts. But if you did want a travelling circus with any announcement, I think you need to look into the competition.
Hi Jim, I seem to remember watching parrots of an Apple WWDC 2014 session regarding how the GPUs are broken up "Harnessing the Power of the Mac Pro with OpenGL and OpenCL". It started to put me to sleep, but I had thought it did matter what port a screen is plugged into, depending on the software requirements. I will go back and watch as a reminder. Having been almost exclusively a PowerBook/Macbook Pro user, am keen for the possibility of moving to a serious workstation. Am commonly modelling huge sites in Vw, and getting into C4D/After Effects. Obviously more processors are generally more important for these apps, than multiple GPU's, but an iMac seems like a short term fix. iMac hardware (generally higher end laptop spec) is simply not the server grade stuff that the Mac Pro is. Also seems wrong to throw out a monitor (as part of the iMac) every three years or so. Maybe the speed jumps we all desire, just aren't there at the moment. We have the top of the line iMac in our studio, and besides very large OpenGL and Renderworks renders, it doesn't seem much faster than my 3 year old MacBook Pro. Maybe that is because the i7 in my MBP is very capable. But the biggest issue I out of memory challenges, and they happen equally on both machines. Looks like I will be waiting until Vw can use all the memory it can, and until then my MBP will do just fine.
Hi Jim, When Vw couples screen redraw with the graphics card, I imagine the second GPU would still be helpful in driving a 4k display? One card for the display, one card for Vw? Or is the second card unnecessary for that as well? Thanks. PS Are retina graphics coming any time soon?
Space Tool Unit Tolerances
Diamond replied to cberg's question in Wishlist - Feature and Content Requests
Good stuff. Our studio thanks you in anticipation. -
Hi, I wondered if anyone can assist. I had thought in older versions of Vw, when Vw used to export a DWG into Model Space that all of the contents of the SLVP was converted into a truncated group of line work. It appears now that the SLVP creates a reference with a crop object that, when exploded, shows the whole contents of a the referenced design layer. When we issue DWG's, third parties explode these VP's and get a mess of line work instead of being able to edit a single detail in isolation. Has anyone found a way around this? Thanks.
Hi Nicole, This is an old post, but I will weigh in again... Regarding the renaming of files, we often receive DWG files named in Chinese characters. Vw English doesn't like to import these files, we we just rename them in the Finder (on Mac) and they import fine. Once we import them, we find many of the Chinese characters come out as question marks. This is because the AutoCAD end are using SHX fonts which are not a font at all--they are a linetype that Vw can't read. If text has been written using a SHX font, as far as I am aware, there are no work arounds to get text into Vw (I would imagine it would be the same for both Vw English & Chinese). For Chinese characters that have been written in a TrueType font, these need to be substituted on import for Arial Unicode MS, as this will give the highest probability of being able to render the Chinese text. (You can choose others, but I have gone for a K.I.S.S. approach). Unfortunately, this font does not render bold or italics, so if you want to display English in bold or italics you would have to use a combination of Arial Unicode MS, and Arial, or any other normal English font of your choice. Anyone else have any thoughts? Thanks.
Hi Jim, I was going to write this in the Organisation Palette thread and realised it was better said here. Regarding my thoughts of the popups ideas, and how an element like that plays out a on the whole app: I am hoping that the whole interface will be refreshed soon to deal with retina screens. Also I think that the there needs to be a light and dark version, similar to what Yosemite is doing. I would prefer a dark, as it is easier on the eyes, but those that are change adverse, would probably want to stay with the light grey. I also I realise, UI design is hard, and one great idea can be cancelled out by another required element. Distilling any design down to its most essential ingredients is a tough challenge, but it is what all great designers / artists / storytellers / cooks do.
Organization Dialogue Box Improvements
Diamond replied to Andy Broomell's question in Wishlist - Feature and Content Requests
Hi Jim, That is where implementation needs direction by NV. I know that when some snap settings are left on (esp with sound on), the amount of high-lit objects (and noise) can be overwhelming. I think it needs be to understated yet obvious in any place it is used. Yes, I see it more as a tool tip type pop-up. Given the right implementation, it could possibly completely replace the OIP. But if it was a tool tip pop-up, I suggest that it needs to be refreshed to a (black/dark grey?) transparent overlay instead of the current yellow. Thanks. -
Hi AEB, Love the hover over the class idea. Very useful for checking in the fly. Tool tips already do something similar, so should be possible. On a slight tangent. Feel like this is an element that could be used in many areas across the app. What if the object info palette went down this path? Attributes palette? Could be a translucent grey hovering pull down menu. Or maybe there could a list of icon, and the necessary palettes pop out as a selected object is selected. Even though many use large screens these days, many also are on laptops. Would be a great way to get some desktop real estate back. -
Slab Object Dialogue Box Improvements
Diamond posted a question in Wishlist - Feature and Content Requests
Hi Jim, A couple of requests for the Slab tool. 1. When adding and subtracting components, can we please have Select/Deselect All boxes. 2. And in the Component creation window, can we please have a Duplicate Component box. To give you an idea, I am often using this object as a mass modelling tool for medium rise buildings. This means I can have 40+ components that take some time to create. Thanks. -
Model viewer and markup iPad app.
Diamond replied to VincentCuclair's question in Wishlist - Feature and Content Requests
Hi Vincent, This is part of what I was alluding to in my request for Mac OS X Yosemite Handoff integration for use when we are at our desks or heading out to the field. Also of use is to be able to add photos of site conditions for comment when we get back in the studio. I think the most interesting apps in this space are BIMx by Graphisoft, Avatron Air Stylus (www.avatron.com/applications/air-stylus/), and one that I have seen this morning reviewed by Architosh called Orthograph Architect (www.orthograph.net). All of this is going to come down to a decent interface implementation (If you have read any of my other posts, you will be able to tell that I am obsessed with UI design?!!). Can't wait to see what NV comes up with. What I do know is that this an 'area of intense interest' to NV (not that I can will quote my sources). Exciting times. PS Reflecting on this post, it might seem I know more than I really do. To clarify, the only thing I do know is that a key senior person at NV is interested in ideas of this nature, which is what Jim seems to be insinuating. -
Hi Jim, Contrary to logic for such a wealthy company, Apple runs very similarly to a small company, with staffing challenges similar to what you and I deal with every day. That said, they do have a huge cushion to keep them going for at least decade or more. Yep, what I am talking about is not easy. It is hard to gauge how serious these issues are. And I freely admit that the possibility of doing what I am saying could destroy NV. I hope there is a wise middle ground, that is able to get rid of the detritus added over the last 20 years, and be courageous and innovative to make tough decisions. Status quo is a dangerous place to be, and can end at the same place if not careful. Although I do not take a lot of note of what Bill Gates says, when referring to technology and it's impact on the world at large, one quote stands out; "Usually people overestimate what will happen over two years, and underestimate what will happen over 10". Interesting times. PS While I can make suggestions with challenges such as these, it is better for NV to sell us on the merits on their vision, as most of the technical challenges are unknown to me. Maybe based on the quote above, the dynamic app Vw needs to be can come as a series of clever and innovative moves over a period of years. I think this is what NV are attempting to achieve, but the noticeable jankiness of the aged detritus continues to concern?especially when compared to the likes of C4D, that will use every last ounce of power thrown at it.
