Nige Lites
    1
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Lighting designer
  • Location
    UAE
  1. First: Since installing the update from 11 to 11.5 I have been unable to export/import DWG. About 2/3 through the conversion (importing or exporting) I get an error message; "Vectorworks.exe has generated errors and will be closed by windows. You will need to restart the program. An error log is being created" Can't find the error log (is it a VW or WIN log, dunno) Same files successfully import/export on another machine that has not been upgraded from 11 to 11.5. Second: Did the usual stuff, shutdown and restarted Windows, closed all other app's, tried again, tried again with files that had imported/exported successfully before upgrade. Always the same result. Dug out the original CD-ROM to re-install, but that would not re-install because it saw a later version already installed. Well maybe re-installing the upgrade might help, got a new access URL downloaded the upgrade exe (first time I had installed 'over the net'), but the upgrade wouldn't install because I no longer had VW 11.01 as my application exe. Does this mean that I have to rip it all out (uninstall VW) and start again. Operating System = Win2000, VW=Spotlight Cheers, Nige.
