We just upgraded to 11.5 and it seems that vectorworks is trying to get users to model in 1:1 scale and then print at 1:X scale. That's great, but there's problems with text at 1:1, no?
1) Standard text sizes (in points) do not work in 1:1. It's simply impossible to see the text when doing a building section. How are you supposed to do notes, dimensions, etc. at 10 PT when modeling in 1:1? If the answer is annotations in viewport, then that's slow because as drawings change a lot, going back and forth between sheet/design layer would be infuriating. Or are you supposed to stay at 1/4" or whatever scale you used in v10.5? That's my solution for now.
2) How do you get the 0,0 axis to show up so that you snap / reference it? We need to reference a lot of buildings from a master plan...
3) I've been trying to get the elevation markers to work. When I place them somewhere and check the "Auto-Set relative to Ref. Elev," I get some number based on the global 0,0 (for example -67'2.411").
How do you get it to a relative 0? I tried re-setting the grid 0,0 to the base of my drawing, but the marker kept at -67'2.411" So then I typed in -67'2.411" into Reference Elevation field...and that set the marker to 0. What if I moved my entire drawing around - wouldn't that screw up all the markers? Any way to make the markers work from a specified 0,0?
4) This is a general complaint on workgroup references: why do you have to do a layer link to move it around? Why can't the reference come in anywhere you like it to?
5) Another complaint: when you have multiple layers on your drawing, you should be able to switch to them via a keystroke+mouse click, like in photoshop. It's pretty time consuming trying to find out what layer something is on.
