355 -
Everything posted by Cris with no H
Twinmotion Plugin + Sync
Cris with no H replied to Tom Klaber's question in Wishlist - Feature and Content Requests
The biggest problem with concentrating on OpenGL is that it is being deprecated. Slowly. These developers are going to have to re-write a lot of code in a couple years. Vectorworks is already working on the problem to stay ahead of the game. So. You can either write for the latest OpenGL and see it wash away, or you can future-proof with code for the replacement render engines. I agree, though, that a good stop-gap would be to have a better export option to get textured models into these other renderers. -
length of record fields in custom title blocks
Cris with no H replied to Cris with no H's topic in Workflows
I suggest making it a high priority. The TB Manager has only so much space, so now we have to arrow through pages to get to fields. Very inconvenient, and being able to winnow these multi-line fields down to single-line fields would be eminently helpful. And, of course, the TB Manager could use a GUI makeover. Srsly. -
Until 2017, one could get a multi-line field generated for titleblocks by appending # to its name. Deleting the # sign turned it back to a single-line field. Now though, my fields seem to be a mix, with most of my custom ones being multi-line (but not all of them!) and this prevents me from simply tabbing through to the next field. Frustrating. How do I turn these fields back to single-line fields? Anybody know? Help and scouring the forum has been no use thus far. Cris w/ no H
Never used LPS Pro, but LW can email your stuff, too. C
I think he means rotation in 3D space, Kevin. I agree this could be a bit more user-friendly, Echo, but you can rotate 3D symbols. The only catch is that they can't be hybrid symbols (with the rare exception of Lighting Instruments in Spotlight, which have special controls for that). If you go into an orthagonal view - front, top, side, back, whatever - you should be able to use the simple Rotate commands and tools right out of the 2D workspace. Make sense? What you mention with hinges is what I did with a model of the new Jeep Truck, about six months ago. The hinges are all identical, but sit at varying orientations. Cris Dopher
Wish I'd seen this topic in January. I have a whole library of wheelchair and ADA clearance symbols, including 3D wheelchair, w. or w/o occupant. I look foward to poking through the new library Justin.
Scott, that is exactly what I've done at GPJ. And we count a lot of truss! Of course, I added other useful bits to my record. Things like truss color, purpose (set, lights, mothergrid, etc), position name (whatever that chunk of truss is going to be referred to, not necessarily a Lighting position), and booleans for pre-hung and sleeves/shrouds.
Is there a way to round off dimensions in a worksheet?
Cris with no H replied to Cris with no H's topic in General Discussion
I'm attaching a file showing my problem. Schedule of softgoods. It's the Length I need to round off. I'd like them to round up, but I'll settle for no fractions, at this point. DIMENSION ROUNDING TEST.vwx -
Still being frustrated by this. It might work in regular worksheet cells, but doesn't seem to work for database cells. -
Display Grid in 3D
Cris with no H replied to zoomer's question in Wishlist - Feature and Content Requests
DC, wouldn't the Section Line tool give you the A-------------------------A you're talking about? -
Path of Travel Tool
Cris with no H replied to Jim Smith's question in Wishlist - Feature and Content Requests
Looks a lot like the Spotlight cable tool. -
dual monitor irritation
Cris with no H replied to jnr's question in Wishlist - Feature and Content Requests
Odd. I don't have this problem you're describing. Whichever monitor I use the Dock on is where the main drawing window opens (and I can use the Dock from either monitor, of course.) . As long as I open from the same monitor, my palettes don't wander. Switching monitors means manual rearrangement, of course. I wonder if something is interfering, like using Spaces, Mac OS restore windows functionality, or something like that. -
List All Classes in file
Cris with no H replied to Jonathan Pickup's topic in Resource Share - Vectorscript
Great script! Thank you! -
So it seems it really was as simple as specifying both layers in the criteria. For some reason, I always thought the criteria was exclusively an AND operation and that specifying two layers would result in nothing. My criteria line looks like this: =DATABASE((((L='HOUSE') | (L='FOH')) & ((R IN ['Seating Section']) | (R IN ['Event Planning Record'])))) So I guess the | symbol works as an OR function.
Does anybody know why Project Files are so much smaller than .vwxw or .vwx files? The moment I do a "save as..." vwx, the file size doubles, sometimes more. Even backups are bigger than the project file, and I'm used to those being stripped of their 3D geometry to save file size. Cris Dopher
TKA, that's not quite it. That looks like it's using =L in the database header of column K. I need to specify the Criteria for the database row as something like "look only on layers 5 and 7 for all objects with Platform &/or Deck records". the records part I have figured out. But the way of specifying a list of records doesn't work to specific a list of layers, too.
Ah.... I will have to try that Boh. Thank you! TKA, that's pretty much the scenario. Needing to pull data from multiple (layers / classes / records / types /etc) take your pick. And combinations of those multiples. I sense myself headed down the rabbit hole of worksheets, but boy it sure has come in handy lately, except that some of my longer worksheets could be more compact by using a multiple data scenario like this.
So I've figured out how to specifiy more than one record in my database criteria. But I can't seem to specify a list of layers. For instance, I want to pull data from Seating Sections spread across 3 layers. In this way I exclude the seating sections on other layers I don't want to count. Any advice?
Title pretty much asks it all. I am frustrated by the returned length of softgoods and want to be able to round (up, preferably) so that we order whole units of softgoods. 24 feet, rather than 23 feet 9.5". The pipe-and-drape object in particular returns lengths that are not the drawn (desired) length, presumably deducting the diameter of the end poles. So. For this and many other uses, it would be helpful to have more control over the dimensional readouts in my worksheets. Advice?
ELEPP, i don't see why not. Have you had some success with this by now?
rendering in a viewport might be better, but it doesn't contribute to efficiency. On the design layer, I can continue to make changes as Renderworks plugs away and it will restart the render when a resource is changed. It is just quicker on DLs. However, I've found a workaround, thanks to Selin's first comment: I set up a RW Style that this time includes edges, just set to 0 pixels. Voila.
This is not a viewport. This does not make me very happy, @Selin. This should at least be a preference.
