Yes I am using the plant data button. I've tried placing a plant in my dwg to see if it works, then selected the symbol for the plant and looked in object info and did indeed find the other info that was in the data base. So this is good.
When I close this drawing, or sometimes the program crashes it for me, when I reopen the dwg, and try to continue with creating the plant catalogue, it says there are no 2d plant symbols. After I exit the edit plant catalogue and go back in again, they appear, but some of the plants i'd created are not there. It is when I recreated the entry in the catalogue and used the same id it crashed the program.
in this dwg, it seems that the system folder was missing so I imported one from another dwg which meant that I had to rename the folders. I now have 2 system folders, but only one of them shows up in the top level which is empty and the other one that does not show up as a system folder contains the 2dsymbols and 3d and plant catalogue.
I'm only trying to create a mediterranean plant catalogue template to use in other drawings. This is really obscure and sooooo time consuming, it would have been simpler to just buy one from someone. HELP. Sorry if I'm a dunce.
