Sam Churzin
    6
Reputation
2 Neutral
Personal Information
  • Location
    United Arab Emirates
Recent Profile Visitors
  1. Thank you all for your suggestions. I've found the reason of that behavior. Generally these are custom symbols for d&b audiotechnik Y-series based on already existing symbols for J-frame and Y subs and tops. I only replaced 3D geometry of those symbols with DWG 3D geometry provided by d&b audiotechnik website and changed the dimensions values in attached records. I didn't pay attention to "Is Tilt Per Front" check box and my value for sub and top was "False". After changing the parameter of that checkbox everything is fine!
  2. Hello everyone! I've faced with strange a Speaker Array tool behavior. My subs and top are not at a zero point more other tops overlap each other. What is the reason of that? I've checked all my 3D geometry positioning in speaker symbols and frame symbol. Everything is at zero point. Any suggestions?
  3. Hello. I came across with one thing. I need to put a hoist between my speaker array and truss and I also need to have all of them as a system which can be calculated in a Braceworks. I can easily attach a hoist to the speaker array. Then I need to attach the high hook to the truss above. Is there any way to do it?
  4. Hello. I wonder is there any option for having hoists for tower trusses real looking. I need to have their chain going above the head block hooking sleeve truss from both sides
