Yes, I originally started with a Door Tag question. Then I asked about how to use the Edit Tag Data dialog to edit the Space Worksheet. Same issue, but neither work for me.
'The door will be created in whatever the Active Class is when you insert it."
Weird, but replacing the door and reselecting it again changes the Class.
I want to change the None class to something else. I select the door in the Resourse Manager but there's a ton of classes. Which is the general on you usually choose in the OIP?
Maybe you know the answer to this... How can I double click a Space Tag and have it edit the Space name? I double click it, the Edit Tag Data dialog appears, but it doesn't work.
The only way around the issue was to use the leader option and click twice inside the Space polygon.
I am now having the same issue with the Door Tag, they are landing everywhere, except inside the door swing.
cber,
I do the setting and it gets me a tag leader but the tag is still like 50' from the tag text and I can't move the tag inside the space. The issue is that if I flip or mirror a space it goes off the building.
My door tags pretty much appear inside the door object, but my Space Tags are all over. Whats the setting to keep them inside the Space object?
Thanks.
I love the "Edit Section in Place", sometimes also while jumping between saved views, but I get these minute long pauses while entering or exiting them. Does it have anything to do with the use of the wide flange tool and the like? They are so convoluted to use and edit.
It doesn't work with Custom Occupant Organization is chosen in the criteria, no items appear in the Worksheet.
When I select Occup. Organization in all the Spaces, the Worksheet will work.
Thanks, always!!
I'm getting zero items. What should I chose in this field?
I seem to have two kinds of Spaces. One does not have the Custom Occupant Organization field.
Can I have a column with just one of the three names I used in the Custom Occupant Organization (of the Space Object Info)? I cant find the settings for it.
I Edit Tag Layout
I add the text in Tag Layout
I define the Tag with Document Units
I get rounded results with 10" instead of 10'-2" and 9" instead of 8'-6"
Walls now have styles and when I change the class to GB-Low, so it will not show in Reflected Ceilings, the internal classes in the wall seem to override the general class I gave them.
