Hi all,
I have had the same problem with VectorWorks 10.1.2 printing text on "some" drawings backwards. There is nothing wrong with the fonts and nothing wrong with our HP 800ps plotter, so the fault must lie in VectorWorks and I think it does.
Some text prints perfect and some prints backwards even though they may be the same font and text size etc. The first way if found to get around the problem was to change the text with the problem to truetype polys. This will make the text a polygon and should print fine. Another way I found which I think further illustrates that VW, as the problem is if you select the text, which is printing wrong, and rotate it. You will find if rotated to an angle it will print perfect. Then if you rotate the text back to the correct angle it will print perfect?? Strange I know but it works.
I hope VW fix this problem soon as it might not happen all the time it is still quite tedious.
M.
