fsung
63 -
Never
Posts posted by fsung
quote:Originally posted by Jacques:If the temperature of the G5 gets too high, the system will enter sleep mode to stop the cpu from burning out...Do your fans come on full blast when it renders?
No. The CPU temps are usually in the 135-140? F (56-60? C) range, and never gets above 155? F (70? C); the fan does spin up occasionally, but it never hits takeoff speed, like it occasionally does in Photoshop.
My G5 is going to sleep in the middle of rendering an animation.
I'm probably overlooking something obvious, but other than setting the sleep setting in the Energy Saver CP to "never," And why is it even going to sleep in the first place? Shouldn't the fact that it's rendering keep the thing awake?
TIA.
2.0 G5 Dual
OS X 10.3.7
VW 11.1
quote:Originally posted by propstuff:Grant,I bought Julian Carr's AnimationWorks add-on for VW for this reason.It makes animations easy.C4D will give you better and faster renders that VW/AW, but for a lot more money than the cost of the plug-in.cheers,N
Thanks for the tip on AnimationWorks, PropStuff!
I was 27 sheets into what would have been a 300+(!) sheet animation when I saw your post and decided to check it out. Downloaded the demo, installed it, spent all of three minutes plotting the camera path, hit "preview", and voila!!
Couldn't whip out my credit card fast enough, and I must say, it'd be cheap at twice the price.
ATTENTION NEMETSCHEK: YOU ABSOLUTELY NEED TO LICENSE THIS PACKAGE AND INCORPORATE IT INTO RENDERWORKS!
[Disclosure: I am not paid or otherwise compensated for any product recommendation I make.]
Figured it out. Someone switched workspaces.
"Batch Print" is not available on one of the office computers: it simply doesn't show up as an option in the "File" menu. How do I make it available?
quote:Is rendering more proccessor or ram intensive, by which I mean; should we be focusing on a faster computer, or a more memory robust one?
Both. Other things being equal, a faster processor will complete the render more quickly than a slower one, however, given two systems with identical processors but differing amounts of RAM, the system with more RAM will (usually) complete the render more quickly than the one with less RAM.
As Peter noted, rendering times are significantly faster on a dual processor setup because RW is multi-processor aware (at least for Final Quality, Custom, and Artistic RW; OpenGL is graphics card dependent so it doesn't get the same boost).
That being said, adding RAM will definitely reduce rendering times. I recently added 1GB to my 2,0 G5 Dual (raising it from 512 Mb to 1.5 Gb), and have seen my rendering times drop dramatically. For example, a 10 sec. Artistic RW animation that took a bit over 3:10 (3 hours, ten minutes) with 512Mb RAM installed took just over 36 min. after adding the additional Gb. (I've noticed that since adding the extra RAM my page outs have dropped to almost nothing, so my guess is that having more RAM available reduces the need for VW/RW to use Virtual Memory.)
quote:Originally posted by Danielj1:The 3D locus shows up on the screen rendering, but not in an exported image. It's an issue if you take screenshots, but if you go the export image file route the problem disappears.
So they won't appear in an animation, even though they appear in the individual sheets?
Note that the author says that the ATI Rage card does not support monitor spanning, and warns not to try the "fix" on ATI Rage-equipped iBooks.
Dave,
I sent the file to Nemetschek on 12/22/04, as requested, but have yet to hear anything back. In the meantime, I've given the file to colleague who runs VW 11 (Win), and he can render it without a problem.
I've rebuilt the file from scratch in VW 11. There are 10 round-top windows in the building, and if any one window is set to between 4'-0" and 4'-5 1/2", the darn thing crashes when I try to render in FQ or Artistic RW. If I export the file to VW 10, then open it in VW 10 and run a FQRW, it renders without a glitch.
Three further notes:
a) the rendering crashes regardless of the sash operation;
b) the rendering only crashes if the top shape is set to Round;
c) replacing the window symbol (e.g., from Andersen to Marvin, or from W And AFFW508 to Win FG RND 3W 2850) and tweaking the settings does NOT resolve the issue.
Any ideas what's causing the problem?
Everything that was working in 10.3.6 is working in 10.3.7 as well. Conversely, everything that didn't work in 10.3.6 doesn't work in 10.3.7, either.
OK, I'm stumped.
I installed VW 11.0.1 (Mac) on my 2.0 G5 Dual (512 Mb RAM, OS X 10.3.7) yesterday. I've been trying to render a file in FQ RW, the thing crashes every time I try it. (FQ RW handles it just fine 10.5.1.) Neither Open GL, Fast RW, nor Fast RW with shadows crash the thing.
I think I've isolated the problem to a pair of 4'-0" wide round top windows. If I reduce width of the windows to 3'-11 31/32" or change the top shape to an ellipse but leave them at 4'-0", the file renders without a hitch. The file will also render successfully if the window width is 4'-5 1/2" or greater, but not at sizes between 4'-0" and 4'-5 1/2".
What's going on? Why won't FQ RW allow 4'0"-4'-5 1/2" wide round top windows?
I just upgraded to VW 11 from 10,5, and I'm having the same problem with VW 11 crashing every time I try rendering in FQ Renderworks. This happens on every file I've tried.
No error messages, no spinning beach ball, no loss of mouse functionality, no other wonky behavior.
512 Mb 2 MHz G5 Dual w/ OS X 10.3.6
VW 11 w/ Architect, Renderworks
The Apple Crash Reporter log from the latest crash is appended below.
Date/Time: 2004-12-21 14:01:56 -0500
OS Version: 10.3.6 (Build 7R28)
Report Version: 2
Command: VectorWorks
Path: /VectorWorks 11.0.1/VectorWorks
Version: ??? (???)
PID: 569
Thread: 0
Exception: EXC_BAD_INSTRUCTION (0x0002)
Code[0]: 0x00000002
Code[1]: 0x0a9ca8a0
Thread 0 Crashed:
0 <<00000000>> 0x0a9ca8a0 0 + 0xa9ca8a0
1 VectorWorks 0x029e5528 0x2008000 + 0x9dd528
2 VectorWorks 0x029e609c 0x2008000 + 0x9de09c
3 VectorWorks 0x028ea364 0x2008000 + 0x8e2364
4 VectorWorks 0x028f5bc4 0x2008000 + 0x8edbc4
5 VectorWorks 0x028fa388 0x2008000 + 0x8f2388
6 VectorWorks 0x028ffcfc 0x2008000 + 0x8f7cfc
7 VectorWorks 0x02e343d0 0x2008000 + 0xe2c3d0
8 VectorWorks 0x028fcab0 0x2008000 + 0x8f4ab0
9 VectorWorks 0x028ff33c 0x2008000 + 0x8f733c
10 VectorWorks 0x028fd2b0 0x2008000 + 0x8f52b0
11 VectorWorks 0x02e343d0 0x2008000 + 0xe2c3d0
12 VectorWorks 0x028fdde0 0x2008000 + 0x8f5de0
13 VectorWorks 0x028ffd1c 0x2008000 + 0x8f7d1c
14 VectorWorks 0x02e33698 0x2008000 + 0xe2b698
15 VectorWorks 0x02e3379c 0x2008000 + 0xe2b79c
16 VectorWorks 0x02e33fd8 0x2008000 + 0xe2bfd8
17 VectorWorks 0x02e34d60 0x2008000 + 0xe2cd60
18 VectorWorks 0x028fe800 0x2008000 + 0x8f6800
19 VectorWorks 0x028ffd2c 0x2008000 + 0x8f7d2c
20 VectorWorks 0x02e33698 0x2008000 + 0xe2b698
21 VectorWorks 0x02e3379c 0x2008000 + 0xe2b79c
22 VectorWorks 0x02e33fd8 0x2008000 + 0xe2bfd8
23 VectorWorks 0x02e34d60 0x2008000 + 0xe2cd60
24 VectorWorks 0x028e71f4 0x2008000 + 0x8df1f4
25 VectorWorks 0x028e7568 0x2008000 + 0x8df568
26 VectorWorks 0x028e812c 0x2008000 + 0x8e012c
27 VectorWorks 0x02277598 0x2008000 + 0x26f598
28 VectorWorks 0x02277760 0x2008000 + 0x26f760
29 VectorWorks 0x02277838 0x2008000 + 0x26f838
30 VectorWorks 0x028a92ac 0x2008000 + 0x8a12ac
31 VectorWorks 0x028a799c 0x2008000 + 0x89f99c
32 VectorWorks 0x028b62d0 0x2008000 + 0x8ae2d0
33 VectorWorks 0x028b6034 0x2008000 + 0x8ae034
34 VectorWorks 0x028b6e10 0x2008000 + 0x8aee10
35 VectorWorks 0x02247018 0x2008000 + 0x23f018
36 VectorWorks 0x0206cc3c 0x2008000 + 0x64c3c
37 VectorWorks 0x0209d19c 0x2008000 + 0x9519c
38 VectorWorks 0x0209d1cc 0x2008000 + 0x951cc
39 VectorWorks 0x0209d1cc 0x2008000 + 0x951cc
40 VectorWorks 0x0206a354 0x2008000 + 0x62354
41 VectorWorks 0x0208c4ec 0x2008000 + 0x844ec
42 VectorWorks 0x0208bef8 0x2008000 + 0x83ef8
43 VectorWorks 0x02075d0c 0x2008000 + 0x6dd0c
44 VectorWorks 0x02089950 0x2008000 + 0x81950
45 VectorWorks 0x020896dc 0x2008000 + 0x816dc
46 VectorWorks 0x02073844 0x2008000 + 0x6b844
Thread 1:
0 libSystem.B.dylib 0x900074c8 mach_msg_trap + 0x8
1 libSystem.B.dylib 0x90007018 mach_msg + 0x38
2 com.apple.CoreFoundation 0x90191708 __CFRunLoopRun + 0x350
3 com.apple.CoreFoundation 0x90195e94 CFRunLoopRunSpecific + 0x148
4 com.apple.audio.CoreAudio 0x90732f80 _ZN10HALRunLoop9OwnThreadEPv + 0x104
5 com.apple.audio.CoreAudio 0x907391e0 _ZN9CAPThread5EntryEPS_ + 0x30
6 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
Thread 2:
0 libSystem.B.dylib 0x9001a4ac syscall + 0xc
1 ...ple.CoreServices.OSServices 0x906200cc BSD_waitevent + 0x2c
2 ...ple.CoreServices.OSServices 0x9061cac0 CarbonSelectThreadFunc + 0xb0
3 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
Thread 3:
0 libSystem.B.dylib 0x90016f48 semaphore_wait_signal_trap + 0x8
1 libSystem.B.dylib 0x9000e790 _pthread_cond_wait + 0x270
2 ...ple.CoreServices.OSServices 0x90627300 CarbonOperationThreadFunc + 0x50
Thread 4:
2 ...ple.CoreServices.CarbonCore 0x90309804 MPWaitOnSemaphore + 0xb8
3 VectorWorks 0x02123588 0x2008000 + 0x11b588
4 VectorWorks 0x02e64424 StartVerificationThread__16TLicenseVerifierFv + 0x604
5 VectorWorks 0x02e639f8 StaticStartVerificationThread__16TLicenseVerifierFPv + 0x28
6 ...ple.CoreServices.CarbonCore 0x903220d8 _MP_CFMTaskProc + 0x20
7 ...ple.CoreServices.CarbonCore 0x902c6d88 PrivateMPEntryPoint + 0x4c
8 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
Thread 5:
2 ...ple.CoreServices.OSServices 0x9061ef8c WaitForSyncDone + 0x4c
3 ...ple.CoreServices.OSServices 0x906129a4 RecvData + 0x2a4
4 ...ple.CoreServices.OSServices 0x906502ec OTRcvUData + 0x3c
5 VectorWorks 0x02125cc0 0x2008000 + 0x11dcc0
6 VectorWorks 0x021270a0 0x2008000 + 0x11f0a0
7 VectorWorks 0x02e57dec ReceiveQuery__16TSerialNumServerFP7TSocketR14TSocketAddressPbPUs + 0x7c
8 VectorWorks 0x02e583d4 StartThread__16TSerialNumServerFv + 0x154
9 VectorWorks 0x02e57808 StaticStartThread__FPv + 0x18
10 ...ple.CoreServices.CarbonCore 0x903220d8 _MP_CFMTaskProc + 0x20
11 ...ple.CoreServices.CarbonCore 0x902c6d88 PrivateMPEntryPoint + 0x4c
12 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
PPC Thread State:
srr0: 0x0a9ca8a0 srr1: 0x0208f030 vrsave: 0x00000000
cr: 0x44002242 xer: 0x20000000 lr: 0x034c9754 ctr: 0x0a9ca8a0
r0: 0x0a9ca8a0 r1: 0xbfff81d0 r2: 0x0075d680 r3: 0x0a7f8b20
r4: 0x00003e85 r5: 0xbfff81b0 r6: 0x00001000 r7: 0x0090506d
r8: 0x0a7f8dec r9: 0x00000005 r10: 0x004dd000 r11: 0x004dd000
r12: 0x0a9554b0 r13: 0x00000003 r14: 0x0a952ec0 r15: 0x090506d0
r16: 0x0000000c r17: 0x0000000f r18: 0x00000000 r19: 0x00000000
r20: 0x00000008 r21: 0x00000060 r22: 0x00753e98 r23: 0x00754100
r24: 0x00753948 r25: 0x007546e0 r26: 0x0ab44600 r27: 0xbfff8570
r28: 0x00000002 r29: 0x0a9ca8a0 r30: 0x00000000 r31: 0x00000000
Binary Images Description:
0x1000 - 0x9fff VectorWorks /VectorWorks 11.0.1/VectorWorks
0xb5000 - 0xb58c2 Plug-in Support PEF binary: Plug-in Support
0xbc000 - 0xc3833 OpenGLLibrarypwpc PEF binary: OpenGLLibrarypwpc
0xc3840 - 0xc426b OpenGLUtilitypwpc PEF binary: OpenGLUtilitypwpc
0xc4270 - 0xc4629 OpenGLMemory PEF binary: OpenGLMemory
0x287000 - 0x2d29b1 CarbonLibpwpc PEF binary: CarbonLibpwpc
0x2d29c0 - 0x2eacad Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia
0x2ec1f0 - 0x2edf7b Apple;Carbon;Networking PEF binary: Apple;Carbon;Networking
0x3100e0 - 0x310171 CFMPriv_AGL PEF binary: CFMPriv_AGL
0x3104b0 - 0x310562 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation
0x310750 - 0x310805 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue
0x310a20 - 0x310ac3 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime
0x310b40 - 0x310bb7 CFMPriv_System PEF binary: CFMPriv_System
0x310e60 - 0x310f30 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound
0x310fb0 - 0x311083 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels
0x311160 - 0x31121b CFMPriv_Help PEF binary: CFMPriv_Help
0x311220 - 0x3112ea CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox
0x311380 - 0x311456 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering
0x3114c0 - 0x311593 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture
0x311620 - 0x311705 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices
0x311780 - 0x311856 CFMPriv_OpenScripting?MacBLib PEF binary: CFMPriv_OpenScripting?MacBLib
0x311930 - 0x3119ee CFMPriv_Print PEF binary: CFMPriv_Print
0x311a10 - 0x311add CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI
0x311b60 - 0x311c42 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition
0x311cc0 - 0x311d93 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore
0x311e10 - 0x311ee3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices
0x311fc0 - 0x312082 CFMPriv_AE PEF binary: CFMPriv_AE
0x312090 - 0x312155 CFMPriv_ATS PEF binary: CFMPriv_ATS
0x3121d0 - 0x3122a7 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync
0x312330 - 0x312413 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent
0x312490 - 0x31256a CFMPriv_HIServices PEF binary: CFMPriv_HIServices
0x3125e0 - 0x3126c0 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis
0x312750 - 0x312836 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices
0x312910 - 0x3129e7 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore
0x3129f0 - 0x312ab2 CFMPriv_QD PEF binary: CFMPriv_QD
0x312bb0 - 0x312c99 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis
0x1008000 - 0x16160a9 RenderWorks PEF binary: RenderWorks
0x16a7000 - 0x16a791c VWLibrary8C0 PEF binary: VWLibrary8C0
0x17e5000 - 0x17e5fff com.apple.aoa.halplugin 2.4.1 /System/Library/Extensions/IOAudioFamily.kext/Contents/PlugIns/AOAHALPlugin.bundle/Contents/MacOS/AOAHALPlugin
0x2008000 - 0x301b5fa VectorWorks PEF binary: VectorWorks
0x301b600 - 0x3051761 MSL_All_Carbon.Shlb Rel PEF binary: MSL_All_Carbon.Shlb Rel
0x3051770 - 0x30faada OpenDWGLib PEF binary: OpenDWGLib
0x30faae0 - 0x367cc61 SMNMTLib PEF binary: SMNMTLib
0x367cc70 - 0x3858173 SMNurbsLib PEF binary: SMNurbsLib
0x3858180 - 0x3a26a51 SMHWTransLib PEF binary: SMHWTransLib
0x3a27000 - 0x4029c38 DWGdirect Library PEF binary: DWGdirect Library
0x5fdb000 - 0x6015fff com.apple.audio.SoundManager.Components 3.8 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x607f000 - 0x60bbfff com.apple.iSightAudio 6.5.2 /Library/Audio/Plug-Ins/HAL/iSightAudio.plugin/Contents/MacOS/iSightAudio
0x6df7000 - 0x6df9183 MovePage PEF binary: MovePage
0x6dfa000 - 0x6dfd6e7 Resize PEF binary: Resize
0x6dfe000 - 0x6e0109b Shear PEF binary: Shear
0x6e02000 - 0x6e0ad07 Eyedropper Tool PEF binary: Eyedropper Tool
0x6e1d000 - 0x6e29d2f Offset Tool PEF binary: Offset Tool
0x6e2a000 - 0x6e2ba2f Trim Tool7? PEF binary: Trim Tool7?
0x7920000 - 0x7925687 ExtrudeAlongPath PEF binary: ExtrudeAlongPath
0x7926000 - 0x792ae07 Textured Prop PEF binary: Textured Prop
0x792b000 - 0x7937ef3 AlignDistributeLib PEF binary: AlignDistributeLib
0x7938000 - 0x794411b EditShader?P PEF binary: EditShader?P
0x7945000 - 0x79611a3 ExtendedProperties PEF binary: ExtendedProperties
0x7973000 - 0x7a53283 GeometryLib PEF binary: GeometryLib
0x7ab9000 - 0x7ac3c17 RenderSettings PEF binary: RenderSettings
0x7ac4000 - 0x7b3db0d VectorScriptEditorPrefsEditOpen?@ PEF binary: VectorScriptEditorPrefsEditOpen?@
0x7b51000 - 0x7b62227 VS SharedLib PEF binary: VS SharedLib
0x7b63000 - 0x7d39ac7 XMLLib PEF binary: XMLLib
0x7d81000 - 0x7d8645b HelixSpiral PEF binary: HelixSpiral
0x7d9f000 - 0x7dae4af FramingMember PEF binary: FramingMember
0x7dd1000 - 0x7ddfd8f TaperedExtrude PEF binary: TaperedExtrude
0x7dfa000 - 0x7e05847 Duplicate Along Path?]%D PEF binary: Duplicate Along Path?]%D
0x7e06000 - 0x7e07c73 TapeMeasureTool?g PEF binary: TapeMeasureTool?g
0x7e08000 - 0x7e0ced3 Protractor Tool???@ PEF binary: Protractor Tool???@
0x7e21000 - 0x7e2782f Duplicate Symbol In Wall PEF binary: Duplicate Symbol In Wall
0x7ee8000 - 0x7f9384a Workspace Editor?? PEF binary: Workspace Editor??
0x7fad000 - 0x7fb305b Purge PEF binary: Purge
0x7fb4000 - 0x7fb5f07 Guides PEF binary: Guides
0x7fb6000 - 0x7fbacab Fit To Objects PEF binary: Fit To Objects
0x7fbb000 - 0x7ff1aaf CheckSpelling PEF binary: CheckSpelling
0x7ff2000 - 0x7ffe513 TrueType To Polyline PEF binary: TrueType To Polyline
0x7fff000 - 0x800b8db ExtrudeAlongPathMenuUndoGenerat?(j?(i?(x@??1?(i??(j`?(w?on VOrbit Animator PEF binary: ExtrudeAlongPathMenuUndoGenerat?(j?(i?(x@??1?(i??(j`?(w?on VOrbit Animator
0x800c000 - 0x801328f TaperedExtrudeMenucalize - Appli?(i?(x@??1?(i??(j` PEF binary: TaperedExtrudeMenucalize - Appli?(i?(x@??1?(i??(j`
0x8014000 - 0x801dbaf HelixSpiralMenu PEF binary: HelixSpiralMenu
0x801e000 - 0x802868f Export Quicktime Movieze - Appli PEF binary: Export Quicktime Movieze - Appli
0x8029000 - 0x802bbaf Orbit Animator PEF binary: Orbit Animator
0x802c000 - 0x8047fdf Path Animator PEF binary: Path Animator
0x8048000 - 0x8097f1f Digital Terrain Modelingon PEF binary: Digital Terrain Modelingon
0x80a9000 - 0x80aea53 Roofer PEF binary: Roofer
0x80af000 - 0x80c3e57 FitWallsToRoof PEF binary: FitWallsToRoof
0x80d6000 - 0x8127337 RoofFramer? PEF binary: RoofFramer?
0x814a000 - 0x814fcaf Sun Position PEF binary: Sun Position
0x8150000 - 0x8151377 Align Layer Views PEF binary: Align Layer Views
0x88e60000 - 0x88e6cfff com.apple.agl 2.5 (AGL-2.5) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x89c71000 - 0x89c72fff DVComponentGlue /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0x8b0c0000 - 0x8b788fff com.apple.QuickTimeComponents.component 6.5.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x8c390000 - 0x8c3d1fff com.apple.QuickTimeFirewireDV.component 6.5.2 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFirewireDV
0x8fe00000 - 0x8fe4ffff dyld /usr/lib/dyld
0x90000000 - 0x90122fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x90190000 - 0x9023dfff com.apple.CoreFoundation 6.3.5 (299.32) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90280000 - 0x904f9fff com.apple.CoreServices.CarbonCore 10.3.6 (10.3.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90570000 - 0x905dffff com.apple.framework.IOKit 1.3.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90610000 - 0x9069afff com.apple.CoreServices.OSServices 3.0.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x90700000 - 0x90700fff com.apple.CoreServices 10.3 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90720000 - 0x90787fff com.apple.audio.CoreAudio 2.1.2 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x907f0000 - 0x907f9fff com.apple.DiskArbitration 2.0.4 /System/Library/PrivateFrameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x90810000 - 0x90810fff com.apple.ApplicationServices 1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x90830000 - 0x9089ffff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90910000 - 0x90983fff com.apple.DesktopServices 1.2.2 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x909f0000 - 0x90b4bfff com.apple.Foundation 6.3.5 (500.56) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90c30000 - 0x90c4afff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90c60000 - 0x90cc2fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x90d00000 - 0x90d1bfff com.apple.SystemConfiguration 1.7.1 (???) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90d40000 - 0x90d40fff com.apple.Carbon 10.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x90d60000 - 0x90d6bfff com.apple.opengl 1.3.6 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x910b0000 - 0x91101fff com.apple.bom 1.2.5 (63.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x912a0000 - 0x912bdfff com.apple.audio.SoundManager 3.8 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x912e0000 - 0x912f7fff com.apple.LangAnalysis 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x91320000 - 0x913defff ColorSync /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x91460000 - 0x91473fff com.apple.speech.synthesis.framework 3.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x914a0000 - 0x91509fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x91560000 - 0x91619fff com.apple.QD 3.4.65 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91670000 - 0x916a8fff com.apple.AE 1.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x916e0000 - 0x91773fff com.apple.print.framework.PrintCore 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x917e0000 - 0x917f0fff com.apple.speech.recognition.framework 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x91810000 - 0x9182afff com.apple.openscripting 1.2.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x91850000 - 0x91860fff com.apple.ImageCapture 2.1.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x91890000 - 0x9189cfff com.apple.help 1.0.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x918c0000 - 0x918cdfff com.apple.CommonPanels 1.2.1 (1.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x918f0000 - 0x9193efff com.apple.print.framework.Print 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x91990000 - 0x9199bfff com.apple.securityhi 1.2 (90) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x919c0000 - 0x91a33fff com.apple.NavigationServices 3.3.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x91a90000 - 0x91a90fff com.apple.audio.units.AudioUnit 1.3.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x91ab0000 - 0x91ac4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x91ae0000 - 0x91aebfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x91b10000 - 0x91b2afff libPDFRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPDFRIP.A.dylib
0x91b50000 - 0x91b5ffff libPSRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPSRIP.A.dylib
0x91b80000 - 0x91b93fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x91bb0000 - 0x91d45fff com.apple.QuickTime 6.5.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x92070000 - 0x92096fff com.apple.FindByContent 1.4 (1.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x920c0000 - 0x922a7fff com.apple.security 2.4 (177) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x92430000 - 0x92468fff com.apple.LaunchServices 10.3.5 (98.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92740000 - 0x92777fff com.apple.CFNetwork 1.2.1 (7) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x927d0000 - 0x92b54fff com.apple.HIToolbox 1.3.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x92d30000 - 0x92d80fff com.apple.HIServices 1.4.1 (0.0.1d1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x935d0000 - 0x938a8fff com.apple.CoreGraphics 1.203.26 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x939a0000 - 0x939b4fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x939d0000 - 0x939d4fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x93b50000 - 0x93bf3fff com.apple.audio.toolbox.AudioToolbox 1.3.2 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x94060000 - 0x94078fff com.apple.WebServices 1.1.1 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x945b0000 - 0x945b9fff libz.1.dylib /usr/lib/libz.1.dylib
0x94610000 - 0x9462afff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x94650000 - 0x946affff com.apple.SearchKit 1.0.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x94a30000 - 0x94af5fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x94b20000 - 0x94badfff com.apple.ink.framework 101.1.3 (55.10) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x954c0000 - 0x95ac6fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95b20000 - 0x95df0fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95e40000 - 0x95eadfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x95f00000 - 0x95f20fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x968d0000 - 0x969b2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x96a20000 - 0x96ae2fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x96b40000 - 0x96b6efff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib
0x96bf0000 - 0x96c7ffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96cb0000 - 0x96d9efff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x96e80000 - 0x96e90fff com.apple.vecLib 3.0.2 (vecLib 3.0.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97510000 - 0x97518fff libbsm.dylib /usr/lib/libbsm.dylib
Computer specs for RenderWorks
in Rendering
Posted
I had a problem earlier with 4'0-4'5 1/2" wide round-top windows crashing FQ and Artistic RW. Other top shapes render fine in the affected range, as do round-top windows narrower than 3'11 31/32" or wider than 4'5 17/32".
Note that this was only a problem in VW 11 running in OS X 10.3.7. They rendered without a hitch in VW 10.5/OS X 10.3.7 and in VW 11/XP Pro.
