Bostonluke
    25
Reputation
0 Neutral
Personal Information
  • Occupation
    Landscape Architect
  • Homepage
    atwoodgroup.com
  • Location
    Boston
  1. I have just discovered that the oultlines for the "missing perennials" is connected to the None layer. I've never noticed this before. Is there a way to move this infor from None to Pwerennial, or at least one of the Plants-Component layers? Thanks. P
  2. OK. What other components should I look for? Thanks. P
  3. Thanks for the suggestion. However, I'm at a loss. I have two classes that are affected: Plant Material-Tree and Plant Material-Perennial. When going thru visibility, one class at a time, only the ticks came up when got to Perennial. I highlighted everything and clicked on the same class in Obj. Info. the program was churning and the outlines came up. However, when I did the same thing for trees, only the ticks remained. I went back to Perennial visibility and only the ticks were there. Can you suggest someothing else for me to try? Thanks. P
  4. Thanks for the suggestion. However, I'm at a loss. I have two classes that are affected: Plant Material-Tree and Plant Material-Perennial. When going thru visibility, one class at a time, only the ticks came up when got to Perennial. I highlighted everything and clicked on the same class in Obj. Info. the program was churning and the outlines came up. However, when I did the same thing for trees, only the ticks remained. I went back to Perennial visibility and only the ticks were there. Can you suggest someothing else for me to try? Thanks. P
  5. VW 2008 When I activate a class for my plants, the outlines disappear for plants already placed on the plan; all I'm left w/ is the center tick. Does anyone know why this is happening and how I can correct it? Thanks. P
  6. The two fonts I use are Verdana and Arial. It happens w/ both of them.
  7. when trying to export a pdf, I keep getting "There was an error processing a page. Bad font object or font descriptor object." and thus no pdf or sometimes only partial. What is this how do I fix it? Thanks, P
  8. Everytime I try to edit a plant description in plant preferences, VW freezes and I have to restart it. Does anyone know why it isn't working? Thanks. P
  9. Greetings - I have to Allow Blocked Content everytime I open VWHelp. Does anyone know of a way to avoid this? It's stored on my machine, so the usual Tools... Internet Options... Security... Trusted doesn't work. Thanks. Cheers, P
  10. Sorry, this is a dup - I previously posted this in the wrong forum: Greetings - When I try to add a plant, all I get is a tick. the graphic is visible in the resource browswer and on the plant preferences page, however, the graphic is missing when I try to edit the definition. How can I fix this and avoid it in the future? Thanks. Cheers, P
