MNewland
    9
Reputation
3 Neutral
Personal Information
  • Occupation
    Designer
  • Homepage
    http://web.mac.com/menewland/iWeb/MENewland/Welcome.html
  • Hobbies
    All Design
  • Location
    Oregon
Recent Profile Visitors
  1. I have a similar problem, but with the text appearing condensed horizontally, like in the opening of the The Matrix, in all the detail symbols in a file. However, when I edit the symbol and one of the misbehaving callouts, adjust its font size, for example, all the callouts correct themselves, not only in the particular symbol, but in all symbols in the file. Then when I reopen the file it's fixed. However, it's doesn't always stay fixed.
  2. With over twenty years professional experience in architectural design & document production using Vectorworks, I'm available for freelance design (limited to residential work), drafting, 3d modeling and/or BIM (unlimited to project type or field). I'm very well-organized, work systematically, quickly and efficiently, dedicated to quick turnaround and superior graphics, and charge hourly on a need-to-use basis. I use Asana to manage workflow and Dropbox and/or Google Drive for file sharing. Please visit www.newland.works to see samples of my work and my resume. Thank you! Email: menewland@mac.com
  3. Hello. I'm a local Vectorworks user doing freelance work. Since I currently have several clients, I am not seeking full-time employment, but I'm available to lend a hand on a project-by-project basis with roughly 15 hours per week availability. I'd be happy to meet to discuss possible collaboration. If so, it would be good to get a better idea of your work. Please let me know what your website is, if you have one. Work samples and my resume may be viewed at www.newland.works. Sincerely, Martin
  4. Hi. Is there a way to generate a report of PIOs in a file that are not on a design layer? The report tool seems limited to reporting PIO instances, ones actually placed on a layer. In particular, I have a file of hundreds of imported plant symbols and I want a report of these without having to place each one on a design layer. The report should look like a plant schedule with its typical fields. Thanks.
  5. Great help! Thanks?just create a symbol that embodies all your classes in a source file and reference to that. Brilliant. M.
  6. Well, that's not referencing, that's just importing. Hum . . . I guess this is something to add to the Wish List. Thanks for your response, though. M.
  7. In v2011, is there a way to have classes referenced to or from a single source file. Workgroup Referencing seems to work only with layers, symbols, and viewports. It sure would be useful to have a class standard that is the source for all other classes in other files?with the option to customize the class definition in a working file. Of course, class standards are available when you create a new class, but that's not the same thing as referencing.
  8. I am using VW12.5. You're probably right about the same shortcuts, which makes sense. Thanks!
  9. I am creating keyboard diagrams for the the Standard and Classic as well as Architect and Classic Architect workspaces. Does anyone know what the difference is between the Standard and Classic workspaces? I imagine the shortcut keys may be the same between Standard and Architect, the only difference being added tools and menu items available to the latter, but I don't know. I am hoping there's a simple answer, otherwise I will have to check each workspace, tool by tool, menu by menu, to note differences?very time consuming! I will make my diagrams available once done. Thanks!
