flowerpower
23 -
Reputation
1 NeutralPersonal Information
Occupation
Garden Designer
Location
Bristol, UK
Recent Profile Visitors
Plant Tags unavailable and greyed out
flowerpower replied to flowerpower's question in Troubleshooting
Ok. Great thanks for the info. Having had more of a look it seems more flexible now in how you want teh tag to look which is good. -
Hi Tom Eureka!!! Thanks so much for pitching in to help. I think I saw you posted this same fix on the other thread where someone was having similar issues. I tried it then but I don't think I fully understood and changed the Species/data section arrows rather than all the arrows in the Tag section so it didn't work. So I need to do this for all my plants then? I don't really understand why this was changed from 2022? But it's working so I can now crack on. Thanks again, I'm so relieved. Flora -
I'm up to date now with VW2023 S7. Unfortunately the problem still exists. I wonder if the file has corrupted somehow. I downloaded 2024 yesterday to see if the Plant tags would work in that and it didn't.
Hi Nikolay thanks for responding - I just saw your post. My VW 2023 is SP3. I didn't realise there were other updates? I ll look for them now and see if that makes a difference. Best wishes Flora
Help please. I've been using various versions of vecctorworks VW 2022 and more recently VW 2023. My issue is that Im trying to finish a planting plan but I can't use the plant tags - they are all greyed out in the OIP, I'm so frustrated. I can't see what I've done differently. Is this a bug or has my design file corrupted? I've searched around and seen 2 other users asking for help on this a while ago but I have no idea if they resolved it. I've never had this problem before. I downloaded VW 2024 yesterday in the hope that maybe solve it and it hasn't. Im starting to think I may have to do all the labels manually. Flora
Did you manage to fix this? I have a planting plant to get out to a client. I've not had this problem in 2022 either. Slightly panicking too.
Plant data and tag information greyed out in Object Info
flowerpower replied to EmmaLa's question in Troubleshooting
Did this fix it? I have the same problem in VW 2023 and am going to try this solution now. -
That sounds very logical. I didn't know you could choose where to search. Thanks very much for helping Tom W, I'll give that a go.
Help please. I want to generate a plant report /list for the nursery. I am using VW 2022 for this design. The issue is that I generated a 'plant syle for the landcape areas' as part of the concept presentation plan. I don't actually want those plants. I created duplicate shaped beds with the actual planting plan. I have turned off the 'concept plants' but Vectorworks still includes them in plant list which is really confusing and time consuming to eliminate. What can I do to get a pure list other than delete all the 'concept' beds.? Thanks
Brilliant! I found this old thread and the 'adjust flipped text' worked perfectly. Thank you as I was tearing my hair out trying to get my text to do the right thing!
Problems updating Vectorworks 2010 Update SP4
Hi Thanks for replying and all your help. it was such a simple solution - I needed to turn my laptop off and on again properly not just restart it. Then teh VW recognised the SP4 pack no problem. Sorry for being a bit daft. Regards FP -
Hi thanks for replying. It is the installation not the downloading. I tried installing as administrator and that didn't work. It seems to suggest the issue is the proxy settings at Vectorworks end of things. -
Hi Its been a very long time since I used my Vectorworks 2010 software. I have loaded it onto my laptop ok. I am having problems updating it with the VW 2010 SP4. Every time I try to update it, an error message come up. Attempting Vectorworks 2010 update to SP4: update fails with the following message: "Server responded: <title>404 Not Found</title> An unexpected response was received from the web server. This could be due to a proxy server intercepting the connection. Please contact support for more information." Please can someone help me/ Many thanks FP.
Custom Title Block - text wrapping How?
flowerpower replied to flowerpower's topic in General Discussion
No Bill I havent tried it the other way - thanks for the tip.
