tdmaine
    18
Reputation
2 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. Twin Motion at least is a fixed cost / no subscription
  2. After importing a .DWG exported from revit the blue grid isn't visible and the marquee /selection color is white and invisible (in any mode) . Any tips where to change this back. It would be nice if importing a .dwg wouldn't change basic vectorwork settings. I tried reinstalling but these preferences/settings are still there . I can change the background color to black and see the white color of the selection tool.
  3. Thanks I have another question? Is there anyway to make the border of the marquee tool a color? Since importing this wacky DWG it's all white so invisible when you draw a box, lasso etc around objects . It works but the behavior doesn't seem normal. Aren't you supposed to see a light box when you select things?
  4. Thanks that fixed it! importing the DWG changed the working plane.
  5. After importing a dwg I have this cross feature I don't like and I don't understand the function/ Can someone enlighten me? Thanks!
  6. Thanks! Also there is no way to add varying slopes. If you google "roof crickets". you can see the function. Basically pitched flat roofs often have pitched smaller pie shaped elements at much higher grades to direct the water. I realize it's not the most important update but it would add functionality and realism .
  7. Hi I have installed 2023 and am trying to make a curtain wall schedule to accompany the window schedule. Is this at all possible? I noticed on the 2023 demo file viewports were used to make a schedule so perhaps not? It seems like an argument is missing on the filter so one could make a proper curtain wall schedule ? Thanks !
  8. Hi is it possible to output a tapered insulation plan to give to a vendor from the data computed and drawn by this tool? Ok I copied the roof and deleted everything but the insulation and now I can manually trim the solid in 4x8 sections. Is there an automated way to do this? Thanks
  9. Thanks! I see it clearly works with windows - any idea if it will work with curtain walls?
  10. Hi all is there anyway to create a window and curtain wall schedule that will not be in spreadsheet form so it can be added to the drawings and not look like a pasted spreadsheet?
