Markus Dohner
36 -
Everything posted by Markus Dohner
The objects are EPS images that I import into VW 2013 or 2014, THis problem hasn't occurred in earlier versions all the way back to 12.5 Top/plan 2D elevations or plans See attached file in VW2014 Designer, 343KB. You will have to use the file or leave it open for 20 minutes before the eps images turn into gray boxes. Thanks, let me know what your thoughts are. -Markus
Dear listers, I design exhibition layouts with lots of images for years and this is the first time I'm having a problem with the images. After clipping them ( such as a teapot with paths around it and inside its handle) and converting them to Pshop EPS, I import them to VW. Then I scale them to whatever. Everything is fine, but after about 15 minutes of VW use these images turn into gray squares with Xs thru them. This never happened in VW 2012 or older versions, never at all, this problem stated with VW 2013 and still happening in VW2014. To get rid of the squares and return to the image I must restart VW. Then it happens, again, in 5 -- 20 minutes of use. Happens inside of viewports, in design layers, wherever. A real PITA. Happens on my iMac at work and my laptop at home, same problems. I'm attaching the before and after JPEGS for your input. And a screen shoot of my preferences, as maybe that will help. Any comments or help appreciated! Apologies for any cross-posting. Many thanks, Markus Dohner Art Institute Chicago VW2014 Designer 2014 27" iMac with 8G VRAM and 16G system memory
My colleague is trying to import a ACAD file that has numerous PNG image files attached. When imported into VW 2011 the images are replaced with boundary boxes and the images are missing. This file contains elevation views involving dozens of art object images. Is there a step in the import dialog that we should modify? Please help, we don't want to have to do this whole project in AutoCAD because of this problem with the images.
How can I scale a rectangle from the center in 2011? The shift+option keys work in version 2010 and 2009 just fine. Not so in 2011, any ideas? Cheers
Hi everyone-- I've got a really tough modeling project from a client who is designing "cave" for a children's museum. It's a faceted walk-in structure about 20 ft long 10 ft wide and about 7.5 ft high. Looks sorta like an old Air Stream motor home. To be made from common structural wood and masonite fill or similar. Any ideas where to start? Is this a project better for ArchiCad or SolidWorks or something else??
dear Datagrace-- Thank you for your responseI'd like to import update certain Filemaker fields into a given VW worksheet. In other words, I want the changes to flow one way--from FMP to VW. For example, at the museum I have a FMP db of all the special exhibitions display cases, containing the dims, colors, condition, etc. of each unique case. I'd like to get certain fields from a record set to update a VW worksheet. I know how to export using tab delimited format, however, I'd like to automate this step some way. I suppose that's what ODBC is about...
Hi-- Is there any way to bring fields from my FileMaker Pro 9 document into a Vectorworks 2009 document?? Also would be cool to link or reference FM doc so that the data in the VW doc can be updated easily. Any ideas / techniques out there?
Textures turning black and other fun things...
Markus Dohner replied to JeffPPI's topic in Rendering
I have had a similar problem. A student of mine created a design with graphic textures on his XP Pro in VW 2008. Some of the texture turn black, some are OK, and zoomed in its swaps different set with black. However, everything rendered perfect on my Mac G-4 in VW 2008 and 2009. More important, I was able to duplicate the XP Pro render problem in my Parallels XP Pro environment (on a MacBook) Weird? Any advice? --Markus Dohner VW 2009 Designer RW G4 OS 10.4 -
I'm trying to figure out an efficient way to extrude type on a curved wall, not unlike dimensional letters you apply to a wall for a display. Any ideas out there? Thanks.
Is there anyway to append --that is, bring in--classes from another VW document?. I want to maintain our office class standards and not resort to remaking the classes for a fresh document. Any ideas?
Establishing Office drawing standards--any tips?
Markus Dohner replied to Markus Dohner's topic in General Discussion
Thanks, this is all very useful info. Anybody else out there working in an office of 10 or so designers and PMs? On the layers matter, I use them like containers for objects with their own classes. That way I keep the layer count down, using them to isolate parts of the project. And I tend to put all things like elevations on one big layer and viewport them to sheets for printing, etc. 3D objects go on their own layer(s) too. -
I've been assigned the task of setting up an office of 10 designers and project managers on a common VW drafting standard. They all have their own levels of experience and ways of organizing their own drawings, however, we are running into unfortunate inconsistencies, duplications, omissions, etc in the drawings. Anybody out there have some tips or experiences? Any checklists of things to do out there?
I'm trying to find the optimum way to deploy WR for a small architectural design firm. Using VW12.5 and Windows. Would it be a good idea to use a server for this? That way all the reference master files are an a central machine, not on an employees? What are the things I should look out for (and utilize) in version 12.5 workgroup referencing. Is it more reliable? I remember past versions of WR were a little flaky. Thanks for the help-Markus Dohner, Chicago
I have a student interested in VW's BIM features. What are more important BIM features in VW assuming that there are some??
Hi Folks Does anybody know where I can get some more of those IES distribution files which came on the RW demo CD?? I'm looking for common lamps like PAR 30 NSP, and so forth. For an exhibit design project. Any ideas would be appreciated. Markus Dohner Chicago, IL
I'm having the same problem too. Exporting same scale as drawing using dwg format and ACad 4000. All my dimensions appear to have moved as one group about 80 feet odd to the left. What's up? Markus Dohner www.markusdohner.com
"error disposing of document -8986" on a LaserWriter
Markus Dohner posted a question in Troubleshooting
I have a VW 11.5 drawing that will not print on a Laserprinter (HP4000). This drawing was fine and printed without a problem until I got this message in the LaserWriter window: pictwpstops - got an error disposing of document = -8986 The drawing prints just fine when I convert it into a PDF or print it on an inkjet. I have a feeling this could be a fonts issue. Is there a way to flush out bad or corrupted fonts from a single document?? Markus Dohner Mac OS 10.3 VW 11.5 printing over network -
Help! objects have grayed out and can't be edited
Thanks Ion, Problem solved. I figured it out. It was a class that was inadvertantly grayed out. Real simple solution. I changed all the classes to visible. Thanks for the tip. Markus Dohner http:www.markusdohner.com -
Markus Dohner posted a topic in General Discussion
I have this peculiar problem I've never experienced before. About 75% of the object I have drawn and labeled with the freehand tool have become gray lines as though they are in the Gray Others option, but they are not. I can't click on them or edit them. The layer visibilty is set to Active Only. This is happened to the older object while the newer ones are just fine. I'll be glad to email file. Using VW 11.5, MacOS10.3.9, G-4 Markus Dohner Exhibit Designs -
Is there a way to make and use text style sheets a la Microsoft Word or QuarkXpress? Is there a third part VW plug in that can do this? I need to quickly style the text accross the whole document with point and click simplicity. Any ideas?
