sjm_htc
    4
Everything posted by sjm_htc
  1. Version 1.0.0
    57 downloads
    This file automatically creates classes and design layers. Then after these are created it can generate sheet layers with title blocks and viewports.
  2. Hi Marissa, I have created a new door style in the method you have suggested here. But when I try to edit the door style in the resource manager, it does not let me. More correctly I mean, it reverts back to original data after I have edited it and clicked OK. I am trying to edit a few of parameters in the data section. Please can you help? The door is not locked.
  3. Thanks both!! I didn't need to create a new node. The existing SetName node does what I need. Thanks @PatStanford for the heads up
  4. Hi all, I am trying to adapt a node I found on the forum which changes sheet layer sheet titles. I wish to adapt it to change sheet layer sheet numbers. What I have tried is to change 'object property index' from 159=Sheet Title to 158 which I hope is for the sheet number. I also changed the parameter from self.Params.sTitle.Value to self.Params.sNum.Value. Which I hope is the parameter name for the sheet layer sheet number. I think both are incorrect. I have uploaded a test file where I am trying to create this node. Below is the code I am trying to hack together to create the custom node for changing sheet layer sheet number. #Created by MFarrell 02/02/18 #modified to sheet number sjm 12.08.2022 @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'Change Sheet Number' ) this.SetDescription( 'Changes the Description value of a Sheet Layer' ) #Input Ports obj = Marionette.PortIn( vs.Handle( 0 ), 'hLayer' ) obj.SetDescription( "The input object" ) sNum = Marionette.PortIn( '' ) sNum.SetDescription( "Number of the sheet" ) #OIP Controls #Output Ports value = Marionette.PortOut('hLayer') value.SetDescription( "Handle to the layer" ) #BEHAVIOR def RunNode(self): #inputs obj = self.Params.obj.value index = 158 sNum = self.Params.sNumber.value #script value = vs.SetObjectVariableString(obj, index, sNum) #outputs self.Params.value.value = obj Batch Change Sheet Numbers_#2.vwx
