alexmootv
29 -
Reputation
13 GoodPersonal Information
Location
United States
Recent Profile Visitors
Hi, Is there a way to assign and clear cable numbers for multiple design layers at a time? I have a drawing with 61 design layers so far and it would be really nice to be able to bulk create and clear cable numbers across the drawing set rather than having to go into each design layer. This normally comes up when I add a device after assigning cable numbers, and I want their numbers to be sequential. I then have to go to each layer one by one and clear all cable numbers and then reassign all cable numbers layer by layer. Thanks in advance, Alex
Thank you @Nikolay Zhelyazkov. This works. My confusion. So, to summarize for myself and anyone who stumbles upon this later: To create an adapter within the resource manager go to the resource manager Adapter Symbols>Default Adapter. Make a duplicate of Default Adapter. We can name it "Custom Adapter". Edit 3D component of Custom Adapter. Then double click on the adapter object nested within the symbol. Now you are editing the adapter. Use the textbox tool to drop a textbox anywhere. The ConnectCAD Text Link Data propery will be displayed in the Object Info pane. Thanks, Alex
Hi @Conrad Preen, Following up on this. I just tested this, and it does work as you described on an actual circuit. The rub is that once you edit the schema via text, the visual editor then shows anything after the three g's as the suffix which is unexpected behavior. So, this does solve my problem. Much appreciated. It also highlights some room for the visual editor dialog box to be polished, very minor, however. Thanks, Alex
Hi @Nikolay Zhelyazkov, I currently don't have the time to setup a scenario and screen record it. Maybe someday I can follow back up with this. For now, to reproduce what I am talking about, take a blank file, go to the resource manager Adapter Symbols>Default Adapter. Make a duplicate of Default Adapter. We can name it "Custom Adapter". Edit 3D component of Custom Adapter. Use the textbox tool to drop a textbox anywhere. Type in some random text so the textbox persists. While that textbox is selected, look at the Object Info pane. You will notice that ConnectCAD Text Link Data is not available to a normal textbox inside of an adapter. Thanks, Alex
Hi @Conrad Preen, I tried this the other day and it did not extend the number generator like I had hoped. Instead, it just added a suffix of g. Does this work on your end? Thanks, Alex
Hi All, I am currently using the cCAD2 cable label schema that is defaulted in ConnectCAD. However, it has one big scalability issue, in that for that schema the unique number generator appears to be limited to 3 numbers, meaning at most you could have 999 cable IDs per signal type. This is a problem for me as it does not scale for larger systems. For things like device names, I include the room number and a sequential number to help mitigate any scalability problems. i.e Server 109.1 where "Server" is the device type, 109 is the room number, and 1 is a sequential number of "Server" per room 109. For cable IDs however, I haven't come up with a good solution to allow for scalability. Ideally each ID is unique and short. I don't really need it to have socket information or device information on the cable label. All of this to ask, is there a way to increase the unique number generator size beyond 3 digits or does anybody else have a preferred schema that helps combat the scalability issues of a sequential number? Maybe a sequential number that is unique to each room of the source device? i.e N109.587 where N is the signal, 109 is the room, and 587 is a unique number within that room. This starts to break down with IO sockets on each end. Any ideas? @Conrad Preen Thanks in advance, Alex
Hi @CharlesD, Following up here. I did some digging and finally found where I grabbed the special textbox from that lets you bind to data from the Adapter object that is not in a record. If you navigate to C:\Program Files\Vectorworks 2023\Libraries\ConnectCAD\Adapter there is an Adapter.vwx file that has some SFP adapters in its resource manager. If you find the symbol "EB30HD2T-LN" it has a textbox in the middle of it that on first glance looks like a normal textbox except that at the bottom of the Object Info pane there is a section labeled ConnectCAD Text Link Data. If you click the "Is linked text" checkbox it then allows you to bind it to the symbol name, make, or model. Or create a custom schema. I have no idea how to give a normal textbox these properties so the only thing I know to do is to copy the textbox into other symbols and use it. While linking to records works, this is linking directly to the object data. There has to be a better way that I don't know of to do this @Conrad Preen. -Alex
Hi @CharlesD, I'm a bit late to the party on this. Like everyone, I've been extremely busy. Thanks for showing an example of how this works with something like an E2. I have messed with adapters in pretty much the same way you are showing. I currently don't use them for cards as I just haven't had the time to finish vetting the process and what it may impact in our workflow, such as circuit worksheets. I suspect I will move that direction eventually. One of the downsides I have found, not any fault of ConnectCAD, is the reality that large frames will always end up being large even if they aren't fully populated. While this does standardize the size of a symbol for a device, sometimes it is nice to have the ability to make the symbol smaller if it's not fully populated. Currently I am just editing the instance of a device to give it the sockets I need rather than using adapters, but it's not the most elegant and then the cards don't show up in the BOM list. I'll eventually revaluate Adapters. I need to find the time. As far as Make_Model labels at one point I stumbled upon a way to bind a text field to the name of the symbol name which made managing that process easy. However, I can no longer figure out how to do that. Maybe @Conrad Preen knows. I feel like it wasn't a standard text field linked to a record, but a special ConnectCAD text object I had copied off of something else in the system that allowed me to do that. Thanks, Alex
@Nikolay Zhelyazkov Thank you for your reply. I did try copying everything into a new file and this fixed the problem for a few days. As of today, the bug cropped back up again. In addition, I now also experience a bug where any connection made from 2 devices with right facing sockets that are IO type now appear with one end of the circuits text labels upside down. How can I send you the file to have a look? And is this something that is possible for you to repair the file and send back to me? Copying all of these design layers into new files is turning into a huge time sink. Thanks, Alex
@spettitt I wasn't meaning to take over your post with the above issue. However, I think you will find with the current state of things sometimes Vectorworks overrides what you put in the workgroup files making the grouping not always work until this is fixed. I personally liked @spettitt idea of being able to add these categories in the workgroup with a special syntax. I believe he mentioned "Lighting(tab)=(return)". This way as we add new signals to our workgroup, we can just create those headings in the file. I would love to have the ability to do what @spettitt is suggesting above, but I wouldn't want it defined by Vectorworks. This would emply Vectorworks is able to think of every edge case which is impossible. I would want to create the hierarchy in our workgroup files. I also think the protocol vs. signal type is interesting as I face this often. However, I end up just making a new signal type for anything, even if it is ethernet. I think this could open up a can of worms however going to granular. If you did choose to start diving more granular however, the 7 Layer OSI Model, might offer some guidance as to how to structure things. https://en.wikipedia.org/wiki/OSI_model Thanks, Alex
Hi All, I think this has similar reference to my complaint of the new behavior in the below post @Nikolay Zhelyazkov. https://forum.vectorworks.net/index.php?/topic/101459-v2023-workgroup-signals-and-connectors-not-taking-priority/ As @spettitt mentioned, we also as a company define our own signals, that in some case share the same name as the default ones. What we currently do as a workaround since Vectorworks will not display the workgroup version if it has the same name as one in the app folder is to delete those files and mark some as read only. Below is the procedure to only show what is defined in the workgroup and not the default app group versions. We do this every time we do a new install. DELETE C:\Program Files\Vectorworks 2023\Libraries\Defaults\ConnectCAD\ConnectCAD_Database SignalTypes.txt ConnectorTypes.txt Create Empty file and Mark as Read Only In some cases, we have found another area that causes a problem, but isn't consistent. We now do this out of precaution as well. Sometimes this file already exists. Delete it first and make an empty one that is read only. C:\Users\Admin\AppData\Roaming\Nemetschek\Vectorworks\2023\Libraries\Defaults\ConnectCAD\ConnectCAD_Database SignalTypes.txt None of this helps with the grouping, which I would also like to make work. What it does do is ensure that what you define in your workgroup folders are actually displayed. Hope this helps, Alex
I've found a workaround of sorts, but the bug is still present. By selecting all of the circuits and from the right click menu pressing "send to back" does allow me to at least select the devices I need, but the overly large hitbox of the circuits is still present. This workaround only works, until I add a new circuit line and then the nearby devices and circuits are no longer selectable, until that new circuit is then also sent to the back. This is the only file I have exhibiting the overly large hitbox issue. By hitbox I am referring to the area used in programming for collision detection and selection of an object. https://en.wikipedia.org/wiki/Collision_detection Thanks, Alex
I am running into a bug where devices and circuits become unselectable, because the hit box for circuit geometry is extending well past the line. In the screenshot below you can see where my cursor is with the blue cursor I drew in after taking the screenshot. By clicking in that area, it selects the circuit line that is encapsulating the cursor. It then makes it impossible to select the nearby devices that I have circled in blue. This is happing throughout the entire drawing set to the point where I will have to scrap the entire file and start over from a new file. This Vectorworks file was a copy of another Vectorworks file that has since been expanded on. The original file does not show these symptoms, but the copied file (the one I will actually be using) does. @Conrad PreenAny ideas or workarounds? Have others experienced this? Thanks, Alex
Hi All, I wanted to start a discussion around the difference between rack depth and usable rack depth, in relation to the 3D view of racks in ConnectCAD. Currently, it seems that the specified rack depth is the total footprint of the rack when viewed from the top plan view. However, I most often use the 3D view to check the side isometric view of the rack for collisions of gear, airflow, and serviceability. Because of this, what I am really after is the total front rail to rear rail depth of the rack; the usable depth. Currently when I type in the rack depth in Vectorworks I add an additional 3" to the usable rack depth measurement. This allows for the 3D model to show me the correct depth from rail to rail. However, it then of course will throw off the footprint of the rack; the total rack depth. Curious if others run into this, and if @Conrad Preenand the team might be able to parametrically model this with the addition of "Usable Rack Depth". Thanks, Alex
Worksheet of Device Connections (Device Patch Sheet)
alexmootv replied to alexmootv's topic in ConnectCAD
Hi @robert1, Thanks for the input. I have visited the Developer Worksheet Wiki previously and tried to do evals on the circuits, but I kept running into Vectorworks limitations. Today, I revisited the topic with some inspiration from your post and messed around with data manipulation in Excel some more. Ultimately, I was able to build mostly what I wanted from the Excel Filter function, but it's not quite the automated process I would like. I am really wanting this to live inside of Vectorworks and update as worksheets do. Short of doing VBA scripts inside of Excel there is no way for it to automatically iterate through all of my devices and build a patch table for each one. Vectorworks, would have some ability to do this as it has context of each device. The functionality just isn't there however. I have attached a screenshot of what I wish I could achieve for every device in the drawing in an automated fashion. Effectively taking the wire schematics and turning them into a table format per device. Thanks, Alex
