3,099 -
Posts posted by shorter
On 4/7/2023 at 1:08 PM, Stel19 said:
Hi Pat, this is purely for my own studies for uni. One of our research questions reads as follows. "Are you aware of the document process status? How many statuses are there for different documents? (Such as drawings\ specs\models\manuals\documents)". The research I have been doing online just seems vague. I mean my basic question in a way is, do you need to follow the ISO 19650 status codes that can be used for any type of document or can you simply use the below?
DRAFT
WORK IN PROGRESS
INFORMATION
APPROVAL
TENDER
CONSTRUCTION
RECORD
COSTING
Thank you for your help!
Don't confuse 'Status' with 'Issued for'. Status Code is a uniquely ISO19650 construct that bears no relation to the actual use of the document, i.e. for planning, or for approval. For example, a drawing could be issued 'For Costing but the Status Code could be 'S2'. 'S2' alone is useless in defining the purpose of issue, so we woud normally back this up with a 'reason for issue' clearly noted on the drawing, if not in the revision/issue record too.
Note: the above is not an 'official' approach but the one that we adopt because of inadequacies in the status code system. We have a similar issue with revision/issue numbers. We would use P01, P02, for preliminary issue, and then T01, T02 for Tender Issue, and C01, C02, for construction issue. Other than P0n, etc, the other two are not catered for under ISO19650. If you are not careful it is possible to issue the same drawing twice with the same revision/issue number, but with different status codes!
- 2
Just now, Tom W. said:
Or even if it doesn't extend to floor in your volume calcs...
Which is why you need to turn it off, I suspect.
@lk642 you will find this oftens happens if you copy walls from one file to another or copy and paste from one layer to another, or if you have layer wall height or storey defined walls insode symbols. Delete Wall Peaks should fix the wall heights in these scenarios.
- 1
Exactly. If a window goes down to the floor, for example, do you include or exclude the bit of floor created by the window 'niche' in your area calculations?
Or do you mean:
DRAFT
WORK IN PROGRESS
INFORMATION
APPROVAL
TENDER
CONSTRUCTION
RECORD
COSTING
- 1
unable to reproduce, as is so often the case.
And ditto when processing the changes.
When you use the TBM to modify multiple sheets, in multiple files, at the same time, it updates references in the files being loaded.
Could we please have an option to suppress this?
Thanks.
Framing Member...
That’s what the ‘add prefix’ option is for when you import a DWG.
On 3/17/2023 at 11:08 AM, mahmoudsmonem said:
Thank you for your reply, I do completely agree, however that's a shared project between different people, and the way it is setup is to have layers for stories/levels rather for each drawing.
Not necessarily.
Use both layers and classes.
41 minutes ago, rDesign said:
I believe the only way to export to Revit 2021 from Vw is to export from Vw 2021.
This will break something.
- 1
Styles are not ideal tbh because they often conflict when referencing.
A simple tick-box 'Make Default' in the 'New Storey' dialog, when creating a storey and associating the storey levels, would be sufficient.
All this is showing it that out of the box, software rarely works as we need it and some thought and preparation of content and having a strategy matters more.
Sadly we find this is rarely the case and users end up confused by what 'should work' but doesn't because they have used content out of the box.
In their defence, Vectorworks engineers cannot possibly know what we need.
We have just spent over 300 hours building 500 objects for a client because the out of the box content, along with content from other sources like BIM Object and the NBS BIM Library, does not do what they need, and more importantly is not ISO19650 or COBie compliant.
8 minutes ago, line-weight said:
Part of my routine is to delete them all, when I am setting up a new file.
Me too.
9 minutes ago, line-weight said:What I want there to be is an absolutely clear distinction between:
- Storeys
- Storey level types (a level type, for example FFL) that might occur in any storey
- Storey level type instances (an individual instance of a level type, for example 2nd floor FFL)
Exactly. There are 'omipotent' levels that are always the same on all repeating floors (Vectorworks, show me a building type where this is routinely NOT the case) and instances, where we need to edit a bespoke level.
Sorry, I should add that the invisble record does not purge from the source file. It can be purged from the recipient file, ie the file into which the source file is referenced.
41 minutes ago, Tom W. said:
Will running Purge with 'Special record formats' enabled delete it?
No. Only rebuilding the file deletes it.
Further to the storey levels comment... Just tested in 2023 and one would 'logically' expect any storey level set by 'default storey level' to be editable when changing the 'default storey levels', or is that too obvious?
I have a 10 storey template model.
I have storeys.
I have storey levels set by our default ISO19650 compliant UK Residential project template, which annoyingly we still cannot import from another file... grrrrr
The storeys are for FFL, SSL, etc.
I want to change the SSL level for each floor.
The steps should be...
1 Select all storeys.
2 Click 'Default Storey Levels'
3 Edit Default Storey Level, e.g. SSL
4 VW edits the SSL level in all storeys selected.
- 1
We use a mixture depending on the file and the project.
A simple assignment of storey to a layer is good for minute adjustment of levels across the model, without using a plethora of storey levels, i.e. letting the storey define simply the FFL of each floor.
In reality once floor levels are set, they don't vary much and if you are dealing with large scale rwsidential, there are only a few different floor to floors we use whcih are dependant on brick dims. The ground floor level though often needs adjustment and this of course changes the entire model. You can avoid this though by going back to the old drawing board approach of modelling at 0m, but issue drawings stating that Ground Floor FFL = 0m = 35m AOD, etc, so if the ground floor FFL changes, the model remains where it is. You simply adjust the reference elevation and coordinate this with your consultants.
The inability to change all storey levels in all storeys, though, is an absolute pain on larger projects and more time consuming that adjusting layer elevation!
Creating a content library that simply sets walls to anticipate layer elevation and layer wall height is a very quick and reliable solution and avoids the issue @Ryan Russell mentions, I think, where the OOTB walls are looking for specific storey levels, particularly inside components and if they don't exist cause the wall to remain 2D, and this causes much confusion (we have had lots of supprt queries related to this one despite us saying 'don't use the OOTB content!').
2 hours ago, Nikolay Zhelyazkov said:
Maybe you forgot about the Title Block Border Styles or something similar?
Unlikely...!
The only objects left in the source file were symbols. Of course, it would not be beyond the realms of possibility for the invisible record format to jump on to a symbol, but there were definitely no title block borders in the file, to the extent that once we had copied the data from the file into a fresh file, by referencing and binding, the record format magically disappeared.
2 hours ago, Nikolay Zhelyazkov said:Is the TBB record the one that was referenced without you wanting it? If so, could you tell me the steps to reproduce this?
Yes. I would not be able to replicate it on demand.
You have to buy Revit, export IFC, imprt IFC, check Revit file and then issue. We offer this service if you are interested.
Having text vertical next to a wall
in Architecture
Posted
Convert Text to Polyline if it's signage or similar, i.e. something that will be built, and then extrude it.
