Marco Sirone
26 -
Reputation
2 NeutralPersonal Information
Location
Australia
Recent Profile Visitors
1,084 profile views
Thanks Tom! It was something so simple
Hey guys, Just wondering why the scale option is greyed out in my window id settings and how do I fix it?
I've tried this but still have the same issue once I close the file and open it again.
Every time I close my file and re open it, if I change anything that has to do with a window or door whether it be the width, height, door style or even the height of a wall that the door / window is placed in, it always changes the colour setting to blue and pink (As shown is attachment) which I think is the default colour. Is there a way where I can change the colour setting to what I want and it stay like that even after I close my file? Thanks.
Perfect. Thanks heaps!!
I was working on a design layer with the scale at 1:100 I changed it to 1:200 and the colour of my walls changed from yellow to white in floor plan, but if I was to change the design layer scale back to 1:100 or 1:50 it changed back to yellow. Not too sure what is going on, if anyone has any idea it'll be much appreciated! Thanks. I've attached the file with the design layer currently set to 1:200 if anyone wants to check it out or see if the same issue happens for them. WALL COLOUR ISSUE.vwx
1330375222_KIARASECTIONS.vwx
I do have save viewport cache turned on. I understand but most of my other files don't exceed 300MB and they work fine which is why I think that the file being 690MB is the reason for the lagginess, Ive closed VW and restarted a number of times, still have the same issue. Ill try attaching the file again hopefully it works. Thanks
My Vectorworks file for some reason is extremely large, Ive tried to attach the file but it keeps failing (I'm guessing due to it size). Im not too sure why the file is so large (690.5MG) but it makes working so slow and prone to Vectorworks not responding. Im thinking it could be an object or something but not too sure how to find the cause. I tried purging but that didn't help. If anyone has any idea it'll be much appreciated. Thanks
I don't have unified view option I think due to me using the architect version, I might be wrong but can't find that option
Im using 2023 version on an IMAC, I did upgrade Vectorworks to 2023 at the beginning of the year but this is the only file that seems to do have this problem, other files work fine
Hi all, I have a weird bug/glitch going on and not sure how to fix it. So when I go into 3D some Objects, walls and extrudes turn invisible but once I select them, delete them and undo the delete they show back up. Anyone knows what's going on? Ive attached a small video of what Im talking about. Thanks 1396677144_ScreenRecording2023-03-02at11_57_31am.mov
-UPDATE- Ive continued to work on the file, and just created a section and now it has become extremely laggy/slow just from zooming in and out while in the viewport. I'm not too sure what could cause this, Im working close to the origin, I don't think there's any objects that has a lot of polygons from what I know of and Ive restarted Vectorworks many times but still have not found a solution. Anyone have any suggestions? Thanks! Attached is the updated file. 1691253096_KIARAPROJECT.vwx
Hi all, Ive got an issue where every time I try to update a section viewport it either takes from 5 minutes if I update one at a time or sometimes over 20 minutes if I update them all at once. Not too sure what could be the issue but Ive attached the file if anyone could please have a look at it id greatly appreciate it! Thanks heaps! KIARA PROJECT.vwx
Hi guys, I was working on a project and randomly all my existing walls changed from a grey fill to a black fill and I'm not sure how this happened. I tried to draw a new wall which shows grey in the preview but once placed comes out black. I also checked the wall style setting and the fills have changed but I didn't change them. Anyone have any idea what the issue could be? Thanks 8 Cottonwood.vwx
