For numbering contours: A roundabout, and still manual, way I have found is to draw a polyline, change it from solid to a linetype that has text in it, import that to your drawing, edit the geometry in the instance in your resource manager so that the text inside the linetype is the same as your contour elevation, then change your linetype to your new edited linetype (I recommend renaming the changed linetype to whatever the contour elevation is). Do this for each of your 5' contours and then you'll have (unarguably too many linetypes) a line that looks like a labeled contour line.
