Kian
    9
Everything posted by Kian
  1. If anyone else comes across this issue and it isn't any of the above.....check that you've actually selected annotation and not crop when double clicking the viewport for dialogue box. It was a late night!
  2. @Jack2022 Really appreciate the time taken to write this out. Although I am a bit confused on something. When you use the circle method to type in the coordinates for the internal origin, why not just change the coordinates in the georeferencing dialog box to match the Revit ones? The reason I'm asking is because I tried to coordinate a model with Revit using the dialog box and it didn't work before, I just don't understand why? I can't wait for this to click but I've been going over all available info for months and still twisted up!
  3. As the title suggests, I have created some landscape areas with mixed planting. Changing the landscape area factor does nothing to the quantities. Is this a bug and when can we expect it to be fixed if so? It seems like a pretty fundamental feature to not be working correctly.
  4. Was this issue ever fixed? I'm having the same problem whereby the landscape area increase factor isn't working in 2023. I may have to go back to 2022 which isn't ideal. I'm also having problems in older files (2021) where the rate change doesn't even effect numbers.
  5. I've noticed on a few projects when importing Revit files that various files aren't aligning with each other. I know Revit has it's own coordinate system and this can cause problems sometimes. As a side note, a video tutorial of how to best align revit and vw files would be very useful as currently I haven't found collaboration the easiest. TIA
  6. Did you ever manage to find a solution for this? Experiencing the same issue myself and it's not even a big file! Thanks
  7. Kian
    Kian
    Cheers Pat
  8. Having the same issue....anyone?
  9. Kian
    Kian
    I'm having a major problem on the latest VW2022. After duplicating and editing plants as per my workflow in 2021 (duplicate style then change name/info to suit) , now all plants are showing as having the same data attached i.e all the information is the same except the name. Can someone please help as it appears I've just lost a days work. Many Thanks
