Hi, fairly new to Vectorworks, here. I downloaded the house file from one the theaters I work at, which was created in an older version of VW (not sure what version) and I converted to 2022. The file came with its own custom library for the units in inventory.
When I place certain lighting fixtures in my drawing (particularly ETC source 4 fixtures), the symbol does not show up. In the case of a S4 26 degree, for example, I just get the slash that would normally be across the barrel, but no fixture. This happens whether I select the symbol from the custom library or the Vectorworks library. When I close the file and try it in a blank file, just selecting from the Vectorworks library, it works fine.
The symbol thumbnails in the resource manager look correct, but when I open the Lighting Symbol Maintenance window and select one of the corrupted symbols, I can see a blank image where the symbol should be.
Is this a problem with loading older files into VW 2022? Did I mess something up when I was asked to replace/merge light info record? I've tried redownloading the file completely but I keep having this issue.
Screenshots:
