Dexie
    175
Posts posted by Dexie
  1. I have been working on a drawing for some time with no problem.
    The attributes panel has just stopped working.
    If I choose any colour from the colour palette it does not appear in the attributes window which appears blank.
    If I select class style and class colour the colour does not show in the attributes panel but does appear if I draw something. If I then try and change the colour of an object it changes to black.
    It only happens in this drawing. Could it be corrupt?
    How can I fix it?
    Any suggestions would be appreciated.
  2. Every time I set the default sketch setting and create a new template. When I open the template to start drawing the sketch always returns to ROUGH. I have set the sketch setting I require as default in the resource browser and under View>Rendering>Sketch Options. and saved as template.
    But each time I open a the new template it reverts to ROUGH.
    It's driving me mad.
    If anyone has the solution I would be grateful.
  3. I have created a VW template that has resources that are in continuous use by a number of people.
    I would like to set a SKETCH style setting that we prefer to be the default.
    Whenever I open up the template it has rest the default to ROUGH.
    Is it possible to reset the default perhaps to our preferred sketch style or even to no sketch as the default.
    I suppose I could just change the setting for the ROUGH default to what we prefer.
    What I don't understand is why it keeps defaulting back to what it was.
  4. The iPad will be a hit I think. The price is almost the same as the B/W Kindle. And then there are all the Apps that can run on it.
    Amazon sells six digital copies on the e-reader for every 10 physical copies so I think Apple will have done their research.
  5. This is how the data comes:-
    372592.5,185037.5,93.66
    372592.5,185032.5,93.681
    372592.5,185027.5,93.698
    372592.5,185022.5,93.695
    372592.5,185017.5,93.69
    372592.5,185012.5,93.685
    372592.5,185007.5,93.68
    372592.5,185002.5,93.675
    372592.5,184997.5,93.669
    372592.5,184992.5,93.664
    372592.5,184987.5,93.659
    372592.5,184982.5,93.639
    372592.5,184977.5,93.616
  6. I am importing the data using Landmark > Import survey file.
    The data covers approx 1.5Km square and data is at 5m intervals.
    I normally get the data as dxf. but thought I would try the xyz data as it was a lot cheaper.
    The dxf data works well. It's just the conversion that is causing the problem.
  7. I have have downloaded some survey data from the Emap site which comes as an x,y,z text file. The file is 16Mb, so V large for a text file.
    There are approximately 650000 lines of data and I am having trouble importing it.
    I did a test on the first 1000 lines of data which took 15minutes to complete this import. Which means it will take over 6.5 days to import all that data if it works.
    Does anyone know why it takes so long. Vectorworks should be able to import thousands of pieces of data a second.
    Looking forward to any comments.
  8. I just spotted this on VECTORLAB which may do the job.
    "I wrote this procedure to process a layer of 2D polygons imported from a shapefile (.shp) . Each polygon had the polygon's elevation in an attached record. This procedure reads the elevation value to create a 3D polygon at the z height. This procedure could be made more useful; The procedure could ask for the record and field instead of constants. Also, the 3D polys are placed onto a new layer, but the 2D polys could be separated from the 3D polys more elegantly. By Frank Brault "
    http://www.vectorlab.info/index.php?title=3DPolys_from_2DPolys_with_elev_in_record
