HI,
I am trying to create some simplified sections of a drawing that already has some detail in it. I am referring specifically to the walls.
I've created a wall style with components and I separated them in classes so that I can edit the visibility and attributes individually. I drew the walls and put them in another class named WALL-EXT.
When I make a viewport in top view and turn off the component classes it works just fine. I can see just two parallel lines with the thickness given by the class named WALL-EXT. Exactly what I want. However, when I make a section viewport and try to do turn off the component classes, the wall just disappears. If I leave them on, the section class overrides the viewport and makes the edges of the components as thick as all the other cut lines.
I also tried to 'Merge cross sections' but for some reason when I do that some random elements disappear from my section.
Is there anyone who might know how can I make my walls look like the ones in the top view viewport?
