Ok, I must warn you I am extremely new to this, but very willing to learn.
A while back, when I first started using VW, I was having difficulty with plotting drawings. The problem was: when I wanted to change the doc prefs to b&w only....... some of the lines would disappear. The work around resulted in the following script:
{====== BEGIN SCRIPT =======}
Procedure Swap;
Procedure SwapBGFG(h:HANDLE);
BEGIN
SetLS(h,2);
END;
BEGIN
ForEachObject(SwapBGFG,ALL);
END;
RUN(Swap);
{====== END SCRIPT =======}
I used the script to create a command that I would invoke prior to changing the doc prefs to B&W only. This has worked fine for months. The problem now is:
I would like to take it to the next level. I have been trying to figure out how to combine this script with the one that changes the doc prefs to B&W only.
I would then like to make it a command that i could invoke before plotting.
Any help / suggestions would be greatly appreciated.
Thanks,
Tom
