Nicholas Beloso
    4
Everything posted by Nicholas Beloso
  1. Hey @line-weight It did work when I grouped the geometry and pushed-pulled it when inside the group window. I am surprised that such a basic toll is not working how it should. I will definitely get in touch with VW. I have this problem very often and it does interrupt the workflow. Thank you very much!
  2. Thank you for your answer,Benson. When I copy and paste the bench into a new file, the cursor selects the surfaces and I can extrude them with Push/Pull (alt+P). When I am working with the main file (that contains all the layers, classes, x-refs etc) the red rectangle that blocks the extrusion keeps appearing. Bildschirmvideo aufnehmen 2021-11-17 um 09.19.36.mov
  3. I am having a really bad time trying to extra a simple polygon. Every time I try to extrude a new shape a red rectangle shows up on the cursor. I've already moved ta the 3D near the origin as suggested by Tamsin and also checked layers-classes. What could it possible be? Bildschirmvideo aufnehmen 2021-11-16 um 10.19.00.mov
  4. I am having a really bad time trying to extra a simple polygon. Every time I try to extrude a new shape a red rectangle shows up on the cursor. I've already moved ta the 3D near the origin as suggested by Tamsin and also checked layers-classes. What could it possible be?
