barnaby
    6
Reputation
2 Neutral
Personal Information
  • Location
    United Kingdom
  1. I'm looking to create a symbol for an extension substructure that we use all the time. It uses a couple of different wall styles & a slab. The idea is to insert the symbol & change the width & length of the extension either with grips or the object info pallette, & the walls & slab all be adjusted accordingly. Back in the day, I had a similar thing in AutoCAD as a dynamic block. I tried to insert a door that has the functionality I'm after, i.e. you can click on a grip to resize it or type in the width & height from the object info palette. I thought I could edit that to learn how to do it but it doesn't seem to be that straightforward!
  2. Hi, This is a tricky question to verbalise clearly but I would like the sheet title in my drawing border to auto populate, dependent on the sheet drawing type or drawing area, plus some custom text. So say: Line 1 of text - If drawing type is "A" then a piece of text says "Plan". I'd like this to be based a preset list of drawing types. Line 2 of text - If drawing area is "GA" then a piece of text says "General Arrangement". I'd like this to be based a preset list of drawing areas. Line 3 of text - Just something I type in like "Location Plan" for instance. I hope that makes sense!
  3. Hi, does this service pack remedy the delay with Redshift GPU rendering, which has a long pause when used for the first time in each session?
  4. Hi, I'm not sure if I'm getting the same problem, when I am inserting doors & windows with glass in them, I am getting random rectangles drawn on the floor right next to the object, as shown in the attachment, could this be part of the same issue? In the screenshot, this is particularly visible on the curved bay window in the lounge but also on the sliding folding doors at the rear & all the other windows.
  5. Hi, I spotted this change on 2022 but it seems that for some of the windows & doors, the options for 'Insert' & 'Offset' are greyed out so can't be changed. The current option for insert is set to 'Core Compon...' but I can't seen any more text than that. Is there a way to change this so the options aren't greyed out please?
