Tismacfan.
Distributor-
33 -
Everything posted by Tismacfan.
graphical legend, Keynotes and callout tool
Tismacfan. replied to Tismacfan.'s topic in General Discussion
Thanks for your answer Pat. The reason I ask is because a customer has a lot of these "legends" on sheet layers and he wants to get them so he can quickly print them. -
Would there be a way if I use the callout tool and place this as legend (keynote) to retrieve the contents of this keynote, legend into a spreadsheet or graphical legend?
I would like to use the formula =SURFACEAREA('RIGHT NET'; 'min height from base=..') in a worksheet, but as a value, I want to refer to a cell from which I want to retrieve the slab thickness. Can these formulas refer to other cells, or other cells within other worksheets?
Is it possible to make a data tag for a wall, where I can have the name of the placed texture with the texture tool So yes how can I do this?
These are 2 walls with material with a texture. The red texture is aplying by the texture tool. So can I have al list of the name of the used textures in the inner component?Wall and Texture.vwx
Hello Pat I have walls with multiple components. So I want a worksheet with the surface area of the inner component in one column, this can be done via the formula = surfacearea('right net'), and in the other column, I would like to see the name of this texture from the inner component. It could be that the inner component has a texture with the name A, but that I use the texture tool from the basic tools to place a different texture on that inner component, for example, texture B, so that I then see the name of texture B in the worksheet
Hello On this forum, I saw a video on how to set up project sharing with a server. But I can't find him anymore someone who can help me give the link, please?
Hello A wall consisting of several components, of which one component is load-bearing. How can I get this component in a different color through data visualization in my drawing based on the load-bearing field value. Tanks for the Info. Pascal
How can I intelligently create a BIM model in timber frame construction Thanks P
Hello Pat I have another quaestion for this script. How can i select parametric object which are in a wall with this script please mvg Pascal
After updating my mac to monterey 12.3.1 i have problems with my stair I select the stair and i go to settings. Then i get my beach ball for a very long time. The only solution is force stop VW this was not a problem in the 12.3 P
Vectorworks G-serie shutdown remotely?
Tismacfan. posted a question in Wishlist - Feature and Content Requests
Is there a possibility to shut down a Vectorworks G-series remotely. Suppose my colleague who works from home via VPN forgets to close the vectorworks, can it be released from the office, for example? -
Apple macOS 12 Monterey Compatibility - Feedback
Tismacfan. replied to JuanP's topic in News You Need
No it is nog possible to log in in the upper-right corner. Its a dutch version 2.1 on a mac. And the strange thing is it is not by every Mac user. So I think it must be something in the settings of the preferences. Could it be resolved by delete net.netmetschek2022NL.plist? -
Any idee how it comes that when you start up Vecotrworks 2022 you not able to login, so you can not use the VSS libraries. Is there a workflow to solve this? -
It is one drive. Everything is setting as the buy the new computer. -
I have a hard drive with a name with Macintosh HD, with a space in it. I can install VW 2022 So I don't think this wil resolved the problem Pascal -
Some customers get the message not enough disk space on mac, but when you look at it there is plenty of it. how can this be solved to instal 2022 on a mac? Pascal -
ok but it can not be the workflow to every 15 minutes restart Vectorworks It often happens with Monterey en the M1 chip -
When we use Vectorworks 2022 with Monterey, sometimes we get withe spots in the drawing. You can not select them and they doesn't disappear anymore. Is therefore a solution? -
What can be the problem, when i have al light with a color, it gives the color in the designlayer when i choose shaded. When i choose a rendworkssytle it becomes white. The same happens in my sheetlayers. Is this a kind of setting and where can i find these?
After installing vectorworks 2022 and Monterey 12.1 I notice that sometimes the menu bar is blocked, I can't open any menu anymore, which makes working with Vectorworks impossible. In 2021 this will not be a problem. is this a known bug? How to solve. -
How can i make a DV so i can put all the objects which has not an ifc label in red Thanks P
- 1 reply
- 1
In the future not only be able to put a texture on an object, put also can use it to put a fill color to it Pascal
you can duplicate the label and put it in another class, label 1 can you set on an angle of nord orientation and label 2 in a other orientation. No can play with the visability of the classes in the designlayer or sheetlayer greets Pascal
